Motors working then chatter before and after homing...
@wingtip no. You wouldn't need m584 in the homing files at all and you would only need movement for x y z.
ok i tried to home x and immediately got an error something about a G1 S1 so i immediately shut down the power before it got to the end stops in case it wouldnt stop... here is my current home x settings
G1 S2 Z5 F6000
Change the S2 to H2 and any S1 to H1 in your homing files.
That is another change between RRF2 and RRF3. The S is now used for laser power. So H is now used for homing moves.
ok, its working using this new reprap 3 coding , HOWEVER, i still have the same issues. The motors move the gantry just fine. But the moment i hit home x, the motors chatter a few seconds, then move to home and after the second hit of the endstops it chatters again for a few seconds then stops... it only does it during homeing... any other time the motors move nice and quiet as they should.
Video?
@wingtip said in Motors working then chatter before and after homing...:
How are you moving the motors when it works if it's not homed yet?
Do the axis move ok by hand with the duet powered off? (do it slowly)
In the gcode console, can you send M122 and M98 P"config.g" and post the results here?
@Phaedrux said in Motors working then chatter before and after homing...:
Video?
M564 S0 H0 ; allows movement of non homed axis for testing, and yes the axis move fine with the duet powered off. let me take a short short video
Sounds like your endstops may not be working.
The G1 H1 commands specify a max distance they will move trying to reach the endstop. When the endstop activates the movement stops otherwise the movement may continue to the limit of the axis.
Unrelated to that you have a command in your config.g file M574 Z1 S2 - that is invalid and not needed all at the same time.
From the docs:
Snnn 1 = switch-type (eg microswitch) endstop input, 2 = Z probe (when used to home an axis other than Z), 3 = single motor load detection, 4 = multiple motor load detection (see Notes).
While im waiting for the video to render, the code for the z axis is irrelevant right now as i have them unplugged. As for the comment about the endstops. both end stops trigger and can be seen in the dwc changing states... also, why would the motor chatter before it even moves and gets anywhere near the endstop...? You will see in the video and maybe understand better.... just waiting for my slow computer to render this so i can upload it to youtube and wait for it to process it , then post the link here...
I only mentioned it because the configurator often inserts that M574 Z1 S2 command even though it is incorrect.
It will certainly help to see the video. The only thing I have experienced like that affected all motor movements - not just homing.
Could you post the relevant homing file?
That is indeed strange that movement after M564 S0 H0 works fine, but homing behaves strangely. One thing that occurs to me is that it could be resonance due to the speed of the homing moves compared to the normal travel moves.
M122
M122
RepRapFirmware for Duet 2 WiFi/Ethernet version 3.2.2 running on Duet WiFi 1.02 or later
Board ID: 08DGM-917NK-F2MS4-7JKD6-3SN6K-9GU4G
Used output buffers: 3 of 24 (15 max)
Static ram: 23460
Dynamic ram: 73376 of which 76 recycled
Never used RAM 15168, free system stack 115 words
Tasks: NETWORK(ready,169) HEAT(blocked,200) MAIN(running,449) IDLE(ready,20)
Owned mutexes: WiFi(NETWORK)
Last reset 00:45:14 ago, cause: power up
Last software reset at 2021-03-03 20:03, reason: User, GCodes spinning, available RAM 15168, slot 1
Error status: 0x00
Aux0 errors 0,0,0
MCU temperature: min 22.2, current 29.6, max 30.0
Supply voltage: min 11.6, current 12.0, max 12.1, under voltage events: 0, over voltage events: 0, power good: yes
Driver 0: position 0, standstill, SG min/max 0/319
Driver 1: position 1600, standstill, SG min/max 0/7
Driver 2: position -2000, standstill, SG min/max not available
Driver 3: position 0, standstill, SG min/max 0/320
Driver 4: position 0, standstill, SG min/max not available
Driver 5: position 0
Driver 6: position 0
Driver 7: position 0
Driver 8: position 0
Driver 9: position 0
Driver 10: position 0
Driver 11: position 0
Date/time: 2021-03-03 22:39:09
Cache data hit count 3286832726
Slowest loop: 25.80ms; fastest: 0.21ms
=== Storage ===
Free file entries: 10
SD card longest read time 1.6ms, write time 79.8ms, max retries 0
DMs created 83, maxWait 634476ms, bed compensation in use: none, comp offset 0.000
=== MainDDARing ===
Scheduled moves 51, completed moves 51, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 40], CDDA state -1
=== AuxDDARing ===
Segments left: 0
Movement lock held by null
HTTP is idle in state(s) 0
Telnet is idle in state(s) 0
File is idle in state(s) 0
USB is idle in state(s) 0
Aux is idle in state(s) 0
Trigger is idle in state(s) 0
Queue is idle in state(s) 0
LCD is idle in state(s) 0
Daemon is idle in state(s) 0
Code queue is empty.
=== Network ===
Slowest loop: 186.63ms; fastest: 0.00ms
HTTP sessions: 1 of 8- WiFi -
Network state is active
WiFi firmware version 1.25
WiFi MAC address bc:dd:c2:89:a2:58
WiFi Vcc 3.43, reset reason Power up
WiFi flash size 4194304, free heap 21168
WiFi IP address 192.168.1.7
WiFi signal strength -58dBm, mode 802.11n, reconnections 0, sleep mode modem
Clock register 00002002
- WiFi -
Can you also post your homeall, homex, and config.g as they are right now so we're all looking at the same code?
I notice in the video that when you are jogging it around it's with very short small moves. Have you tried longer distance moves yet?
M98 P"config.g"
M98 P"config.g"
HTTP is enabled on port 80
FTP is disabled
TELNET is disabledError: Temperature reading fault on heater 1: sensor open circuit
home x is the only one im using at the moment.
i up'd the current from 1amp (1000mah) to 1.2amp (1200mah) and no change
What is the max rated current for the motors?
unfortunately at the moment i cant due to the huge mess lol... but months ago i was running it the full distance of 800mm no issues
Ill have to check as they came from openbuilds.com but from the config file you gave me they are now down to 800 mah and still chatter before and after homing..
Re-posting of your homeX.g file
; homex.g ; ; generated by RepRapFirmware Configuration Tool v2.1.1 on Sun Nov 03 2019 09:32:23 GMT-0500 (Eastern Standard Time) ; G91 ; relative positioning G1 H2 Z5 F6000 ; lift Z relative to current position G1 H1 X-805 F400 ; move quickly to X axis endstop and stop there (first pass) S1 checks for endstop hit G91 G1 H2 X5 F1800 ; go back a few mm G1 H1 X-10 F360 ; move slowly to X axis endstop once more (second pass) H1 checks for endstop hit G92 X0 G90 G1 H2 Z-5 F2000 ; lower Z again G90 ; absolute positioning
@fcwilt said in Motors working then chatter before and after homing...:
Comment out the Z axis commands, move Z clear with the jog buttons, and try homing again.
