Duet Wifi - how to set cooling fan?
While I'm here, cold extrusion stopped working.
your config has a mixture of RRF2 and RRF3 commands.
I suggest creating a new config using the config tool https://configtool.reprapfirmware.org/
and then transferring across any changes you've made -
Here is the new config:
that looks correct although you shouldn't be including M587 commands in your config
@jay_s_uk My cooling fan is connected to FAN0, but when sending M106 S0 it doesn't do anything (it's always on).
is it always on when the sd card is not inserted into the board and then the board is powered on?
@eranglr
You have it mapped to the tool T0 with. Actually, that's not it at all!M563 P0 D0 H1 F0
. So it won't be active until the tool is activeCheck that you have connected the fan to FAN0, and not the 'Always on' pins. See the wiring diagram: https://duet3d.dozuki.com/Wiki/Duet_Wiring_Diagrams
@droftarts connected it to FAN0 (not always on).
The fan is always on even when I turn the duet with no SD card inside.
This post is deleted! -
@eranglr Can you send M122 and post the reply?
@jay_s_uk yes, it is.
Could it be a jumper or something like that? -
@droftarts
M122
RepRapFirmware for Duet 2 WiFi/Ethernet version 3.2.2 running on Duet WiFi 1.02 or later
Board ID: 08DJM-9178L-L4MSJ-6J1FL-3SN6T-TV16Q
Used output buffers: 3 of 24 (11 max)
Static ram: 23460
Dynamic ram: 73136 of which 40 recycled
Never used RAM 15444, free system stack 182 words
Tasks: NETWORK(ready,188) HEAT(blocked,308) MAIN(running,379) IDLE(ready,20)
Owned mutexes: WiFi(NETWORK)
Last reset 00:00:43 ago, cause: power up
Last software reset at 2021-02-24 17:24, reason: User, GCodes spinning, available RAM 15444, slot 1
Error status: 0x00
Aux0 errors 0,0,0
MCU temperature: min 35.1, current 38.2, max 38.5
Supply voltage: min 26.8, current 26.9, max 27.2, under voltage events: 0, over voltage events: 0, power good: yes
Driver 0: position 0, standstill, SG min/max not available
Driver 1: position 0, standstill, SG min/max not available
Driver 2: position 0, standstill, SG min/max not available
Driver 3: position 0, standstill, SG min/max not available
Driver 4: position 0, standstill, SG min/max not available
Driver 5: position 0
Driver 6: position 0
Driver 7: position 0
Driver 8: position 0
Driver 9: position 0
Driver 10: position 0
Driver 11: position 0
Date/time: 2021-02-24 17:40:35
Cache data hit count 51187488
Slowest loop: 4.02ms; fastest: 0.21ms
=== Storage ===
Free file entries: 10
SD card longest read time 0.9ms, write time 0.0ms, max retries 0
=== MainDDARing ===
=== AuxDDARing ===
Segments left: 0
Movement lock held by null
HTTP is idle in state(s) 0
Telnet is idle in state(s) 0
File is idle in state(s) 0
USB is idle in state(s) 0
Aux is idle in state(s) 0
Trigger is idle in state(s) 0
Queue is idle in state(s) 0
LCD is idle in state(s) 0
Daemon is idle in state(s) 0
Code queue is empty.
=== Network ===
Slowest loop: 16.13ms; fastest: 0.00ms
HTTP sessions: 1 of 8- WiFi -
Network state is active
WiFi firmware version 1.23
WiFi MAC address bc:dd:c2:31:9f:e7
WiFi Vcc 3.37, reset reason Turned on by main processor
WiFi flash size 4194304, free heap 24208
WiFi IP address 192.168.202.42
WiFi signal strength -64dBm, mode none, reconnections 0, sleep mode modem
Clock register ffffffff
- WiFi -
@eranglr my guess is you've blown the fan mosfet.
Can you take a high quality close up photo of the area around the connector, specifically the area between the fan connectors and the two LCD headers -
@jay_s_uk This is a brand new card, so I doubt if I blow the MOSFET.
ok then, i'll let someone else step in and support
@jay_s_uk Just for fun, where's the mosfet, and are there 3 mosfet (one for each fan)?
@eranglr And it would be very unlucky if it's blown all the mosfets, as he said it was the same for FAN1 and FAN2.
Is there any chance the fan you are using is shorting out to ground somewhere else? Is it wired directly to the fan pin, or does it go through something else?
The MOSFETs work on the negative side of the fan, so the fan gets +ve volts all the time, so if there is a short on the negative side, it will always be on.
If you can post a photo of your wiring, that may help.
they are here for reference
@jay_s_uk Doesn't look burnt.
@droftarts The fan should be connected directly, but I'll check again to make sure.
