Hotend always on after updating RRF3
I've just updated to RRF3 and I've noticed that the hotend (hetear 1) is already active when I turn on the printer (even if the power supply is off). Look at the picture
This is my config file:
M569 P1 S0 ; physical drive 1 goes forwards
M584 X1 Y0 Z2 E3 ; set drive mapping
M92 X80.00 Y80.00 Z400.00 E408.50 ; set steps per mm
M203 X6000.00 Y6000.00 Z1500.00 E3600.00 ; set maximum speeds (mm/min)
M201 X2500.00 Y2500.00 Z50.00 E1500.00 ; set accelerations (mm/s^2)
M906 X1200 Y1200 Z1200 E1200 I30 ; set motor currents (mA) and motor idle factor in per cent
M208 X310 Y315 Z265 S0 ; set axis maxima; Endstops
M574 Z1 S2 ; configure Z-probe endstop for low end on Z; Stall Detection
;M915 X Y S7 F0 H200 R2 ; X and Y motor stall detection; Z-Probe
M558 P1 C"zprobe.in" H5 F250 T6000 ; set Z probe type to unmodulated and the dive height + speeds
G31 P500 X0 Y0 Z1.20 ; set Z probe trigger value, offset and trigger height
M557 X50:260 Y20:230 S105 ; define mesh grid; Heaters
M307 H0 B0 S1.2 ; disable bang-bang mode for the bed heater and set PWM limit
M143 H0 S100 ; set temperature limit for heater 0 to 100C
M950 F0 C"fan0" Q1000 ; create fan 0 on pin fan0 and set its frequency
M950 F1 C"fan1" Q1000 ; create fan 1 on pin fan1 and set its frequency
M950 F2 C"fan2" Q1000 ; create fan 2 on pin fan2 and set its frequency
M106 P2 S0 H-1 ; set fan 2 value. Thermostatic control is turned off; Tools
M563 P0 S"Hotend" D0 H1 F0:2 ; define tool 0
G10 P0 R0 S0 ; set initial tool 0 active and standby temperatures to 0C; Miscellaneous
M911 S22.5 R23.5 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; set voltage thresholds and actions to run on power loss
T0I've already checked the onboard leds: 3.3V is on, 5V is on, e0 Heat as well as Bed Heat are off.
I've also tried to add "M104 S0" in confing.g but it doesn't work.Any advice is welcome. Thanks.
It's active because you have a T0 at the end of your config.g. The temperature is 0 so it's active but not on if that makes sense.
Removing T0 at the end of config.g the hotend is no more active but in standby. Is there any way to shut it down?
@zecchi I'm not sure but why do you want to? You don't have an active or standby temperature set so it's not going be "On"
@Rushmere3D yeah, it's true, it was only to see "off"
thank you -
active does not mean its heating.
it means this tool has been selected -
@Veti yeah, I've noticed. Thank you for the info
@zecchi A "T" followed by negative number will deselect a tool. So using T-0 might make it show as off rather than active at zero degrees. Don't know for sure as I always like to select at least one tool in config.g (because one can't extrude anything until a "Tn" command has been sent.)
@deckingman unfortunately T-0 (or any negative value ) doesn't work. At this point I'll leave "T0", as others say there is no difference for me. thank you all!
Usually people have the opposite problem where they don't have T0 in config.g and then wonder why the temperature won't change and don't realize that a tool must be selected first.
Using G10 P0 R0 S0 sets the temps to 0, so in effect, "off". T0 selects the tool, so that it is ready to accept a temperature command.
