Error: Attempting to extrude with no tool selected
@engikeneer thanks for the heads up. this is the first time i have seen it with someone who is already posting successfully. Akismet is a bit of a black box, can you ask him to email info@duet3d.com and we can try and trouble shoot through this.
@sgk You must post the sliced gcode file so we can see what the slicer is adding.
Do you have something defined in config-override.g concerning tools?
Might be weird, but did you try to remove the tool label S"T0" in M563?
Mine is like this:
; Tools M563 P0 D0 H1 F1 ; define tool 0 G10 P0 R0 S0 ; set initial tool 0 active and standby temperatures to 0C
@sgk Try moving the 'Tool' section of your config.g to after the fan definitions. At the moment it is defining the tool with a fan (F1, which is the thermostatic hot end fan, so I think it should be F0, the tool fan) before the fan has been defined. This wasn't a problem in the old version of the firmware, as fans were defined by default, but in RRF3 there are no default definitions.
hello everyone thank you very much for all of your help.
I post my gcodehttps://drive.google.com/drive/folders/1ryDNZchhWtu0Z5FudB5cCDygz8ms5czn?usp=sharing
for info I disconnected my panelduo and I managed to print
1 time -
@sgk
ok see if you can route the paneldue cable not near any power or stepper cables -
thank you but I have more panelduo because it no longer works the touch
so i will see if it works now permanently -
G90 M82 M106 S255 G4 P500 M106 S191 M140 S60 M190 S60 M104 S200 T0 M109 S200 T0 M291 P"Homing all axis" R"Printing.." S1 T2 G21 ; metric values G28 ; home all ;G29 S2 ; mark if you want to disable mesh grid G32 ; Run mesh grid compenstion ; Purge extruder G92 E0 F100 ; reset extruder G1 Z10 F3000 ; move z up little to prevent scratching of surface M98 P/macros/Filament/Purge ; Run nozzle purge macro ;G1 E-1 F2000 ; Retract 1mm filament G92 E0 ; reset extruder M291 P"Printing started !" R"Printing.." S1 T3 ; process Process1 ; layer 1, Z = 0.120 T0 G92 E0.0000 G1 E-6.0000 F2400 ; feature inner perimeter ; tool H0.120 W0.480
What do you have in macro here:
What do you have in bed.g?
What do you have in homeall.g?
hello
; bed.g
; generated by RepRapFirmware Configuration Tool on Tue Oct 09 2018 13:27:56 GMT+0300
M291 P"Probing mesh grid process started" R"Probing.." S1 T2
G28 ; home all axis bb
M671 X-55.0:364.0 Y175.0:175.0 S5.0
G30 P1 X5 Y150 Z-99999
G30 P0 X300 Y150 Z-99999 S2
G90 ; absolute positioning bb
M557 X20:270 Y20:270 S240 ; Define mesh grid
G29 S0 ; Probe the bed and save height map to file
M374 ; Save calibration data. Default is sys/heightmap.csv
M291 P"Probing mesh grid process finished !" R"Probing.." S1 T2
; Probe the bed at 4 points
;G30 P0 X10 Y10 H0 Z-99999
;G30 P1 X10 Y290 H0 Z-99999
;G30 P2 X290 Y290 H0 Z-99999
;G30 P3 X290 Y10 H0 Z-99999 S -
; homeall.g
; called to home all axes
G91 ; relative positioning
G1 H2 Z5 F6000 S2 ; lift Z relative to current position
G1 H1 X-355 Y355 F6000 ; move quickly to X or Y endstop and stop there (first pass)
G1 H1 X-355 ; home X axis
G1 H1 Y355 ; home Y axis
G1 X5 Y-5 F6000 ; go back a few mm
G1 H1 X-355 F360 ; move slowly to X axis endstop once more (second pass)
G1 H1 Y355 ; then move slowly to Y axis endstop
G1 X152 Y166.4 F6000 ; go to first bed probe point and home Z
G30 ; home Z by probing the bed; Uncomment the following lines to lift Z after probing
;G91 ; relative positioning
;G1 S2 Z5 F100 ; lift Z relative to current position
;G90 ; absolute positioning -
;purge hotend
M291 P"purge started !" R"purging.." S1 T2 ; display msg
G1 X5 Y70 Z0.3 F5000.0 ; move to start-line position
G1 Z0.3 F1000 ; print height
G1 X5 Y220 F1500.0 E15 ; draw 1st line
G1 X5.2 Y220 Z0.3 F5000.0 ; move to side a little
G1 X5.2 Y70 Z0.3 F1500.0 E30 ; draw 2nd line
G1 X150 Y150 F6000 ; move to center of the bed
M291 P"purge finished !" R"purging.." S1 T2 ; display msg -
; Clean nozzle macro
M291 P"Cleaning Hotend" R"Cleaning.." S1 T5 ; display msg
G1 X-20 Y290 F10000 ; move to first brush point
G1 Z0.5 F3000 ; lower nozzle to the brush
G1 X-8 Y290 F10000 ;
G1 X-20 Y290 F10000 ; move back to first brush point
G1 X-8 Y280 F10000 ; move to 2 brush point
G1 X-20 Y280 F10000 ; move to 2 brush point
G1 X-8 Y280 F10000 ; move back to 2 brush point
G1 X-20 Y270 F10000 ; move back to 3 brush point
G1 X-8 Y270 F10000 ; move back to 3 brush point
G1 X-8 Y260 F10000 ; move back to 4 brush point
G1 X-20 Y260 F10000 ; move back to 4 brush point
G1 X-20 Y254 F10000 ; move back to 5 brush point
G1 X-8 Y254 F10000 ; move back to 5 brush point
M291 P"Cleaning finished !" R"Cleaning...." S1 T2 ; display msg
