Question about Duet2Maestro external drive module
the duet maestro does not support the 2209.
only the 2224. -
the board is here
https://www.duet3d.com/Duet2Maestro2StepExpansion -
How to bypass uart and connect high current driver
You could try picking up the step and direction signals from the connector for the 2-driver daughter board. The signal levels are 3.3V.
Hello, if I don’t use the onboard TMC2224, but use STEP and DIR on the board to connect 5 external drives, what should I do?
Thank you -
@Veti said in Question about Duet2Maestro external drive module:
only the 2224.And the 2208, which is the same as the 2224 with a different pinout. It may be possible to get TMC2209 drivers working too, but stall detection would not be available.
@ansonyang said in Question about Duet2Maestro external drive module:
The maximum number of STEP and DIR signal pairs you can pick up is 2.
If this is the case with an external drive module, how do I set it up?
Sorry for my bad English, translation software used -
You will need to common the grounds too.
We've never tried using external drivers with the Duet Maestro, but if it works at all, I don't think it will need any setting up apart from the usual steps/mm with M92.
Excuse me
E2 and E3 external drive modules can work, but X_Y_Z_E0_E1 external drive modules cannot work.
Please help me -
what do you mean by that? you want to replace the internal drivers?
I want to replace the TMC2224 on the motherboard with other drive modules
you want to desolder the onboard drivers?
at that stage it might be easier to get a skr board and run the lpc port of rrf on it
@Veti I don't know, can you tell me?
@Veti Thank you my friend
why would you want to use a drv8825 instead of a tmc driver?
@Veti I want to use a big drive to drive a big motor, not just DRV8825
the duet 3 can drive up to 6.3A
