Error M587:Failed to add SSID to remembered list.
@Hiroaki The M122 reply has been cut off, and the WiFi diagnostics is missing. If you are connecting with YAT:
Set YAT to use <LF> as the end of line character. This will improve the readability of the messages coming from the Duet. Click "Text Settings" in the "Terminal Settings" and change "EOL sequence:" to <LF>. Click "OK" to close Text Settings. Click "OK" again to close Terminal Settings.
@droftarts Thank you.
This is it.
RepRapFirmware for Duet 2 WiFi/Ethernet version 2.05.1 running on Duet WiFi 1.02 or later + DueX5
Board ID: 08DJM-956GL-M43T0-6JKDL-3S86P-994YQ
Used output buffers: 1 of 24 (2 max)
Static ram: 25712
Dynamic ram: 93980 of which 84 recycled
Exception stack ram used: 264
Never used ram: 11032
Tasks: NETWORK(ready,1884) HEAT(blocked,1232) DUEX(suspended,160) MAIN(running,3836) IDLE(ready,160)
Owned mutexes:
Last reset 00:06:48 ago, cause: power up
Last software reset time unknown, reason: User, spinning module GCodes, available RAM 10896 bytes (slot 2)
Error status: 0
Free file entries: 10
MCU temperature: min 29.5, current 32.0, max 65.8
Supply voltage: min 0.0, current 0.5, max 0.6, under voltage events: 0, over voltage events: 0, power good: no
Driver 0: ok, SG min/max not available
Driver 1: ok, SG min/max not available
Driver 2: ok, SG min/max not available
Driver 3: ok, SG min/max not available
Driver 4: ok, SG min/max not available
Driver 5: ok, SG min/max not available
Driver 6: ok, SG min/max not available
Driver 7: ok, SG min/max not available
Driver 8: ok, SG min/max not available
Driver 9: ok, SG min/max not available
Cache data hit count 681994076
Slowest loop: 1.58ms; fastest: 0.05ms
Hiccups: 0, FreeDm: 160, MinFreeDm: 160, MaxWait: 0ms
=== DDARing ===
Heater 1 is on, I-accum = 0.0
Segments left: 0
Movement lock held by null
http is idle in state(s) 0
telnet is idle in state(s) 0
file is idle in state(s) 0
serial is ready with "M122" in state(s) 0
aux is idle in state(s) 0
daemon is idle in state(s) 0
queue is idle in state(s) 0
Code queue is empty.
=== Network ===
Slowest loop: 0.84ms; fastest: 0.00ms
HTTP sessions: 0 of 8- WiFi -
Network state is starting
WiFi module is disabled
ok
- WiFi -
M552 s-1
WiFi module stopped
ok
M552 s0
ok
M122
then it was still- WiFi -
ok
- WiFi -
@Hiroaki Send M552 S-1, then M122, M552 S0, then M122, and M552 S1, then M122. This is what the response from my Duet 2 WiFi looks like (you can just copy the WiFi part at the end):
M552 S-1
WiFi module stopped
ok
M122
RepRapFirmware for Duet 2 WiFi/Ethernet version 2.05 running on Duet WiFi 1.02 or later
Board ID: 08DGM-9T6BU-FG3SD-6JKD4-3S86N-KAMHF
-WiFi -
Network state is disabled
okM552 S0
ok
WiFi module started
M122
-WiFi -
Network state is running
WiFi module is idle
WiFi firmware version 1.23
WiFi MAC address a0:20:a6:31:b4:b9
WiFi Vcc 3.36, reset reason Turned on by main processor
WiFi flash size 4194304, free heap 30176
okM552 S1
ok
WiFi module is connected to access point BTWholeHome-XXX, IP address 192.168.0.12
M122
-WiFi -
WiFi Vcc 3.37, reset reason Turned on by main processor
WiFi flash size 4194304, free heap 25568
WiFi IP address 192.168.0.12
WiFi signal strength -43dBm, reconnections 0, sleep mode modem
okIf you're not getting something similar, I'd guess that the WiFi module has failed. The usual reason for this is a power surge on the 3.3V line; the WiFi board and SD card are often the first to fail if this has happened, but can protect the main processor from failing.
It is possible that the WiFi module firmware has not flashed correctly. Try downloading a fresh DuetWiFiServer-1.23.bin from https://github.com/Duet3D/RepRapFirmware/releases/tag/2.05.1 and upload it to the 'sys' folder on the SD card, then send
M997 S1
.Ian
Hello @Hiroaki... I have had this issue myself a few times. The advice here did solve it; but I had to do it a couple of times. Re-flashing the firmware more than once might be necessary. I also found that in BOSSA, using the setting "erase all" seemed to yield the best results. Good luck to you!
@droftarts Thank you. As it's getting late night, I will do it tomorrow.
By the way do you think it's possible to change the wifi module ? -
@beachtec Thank you. I will try tomorrow. It's 0:21AM ...
Best Regards -
@droftarts
One question .
Upload Duetwifiserver-1.23.bin to the SYS not WWW folder?
Regards -
@Hiroaki said in Error M587:Failed to add SSID to remembered list.:
One question .
Upload Duetwifiserver-1.23.bin to the SYS not WWW folder?Yes, firmware updates go in the 'sys' folder. The 'www' folder is for DWC components.
@droftarts ok Thank you.
I think you'll need to rename the file and remove the
-1.23
part so that the final file name is just DuetWiFiServer.bin -
@droftarts Hello
Thank you so much.
I could solve the problem.
sent M997 S1 and then ok.
I appreciate that.
Thank you -
@Phaedrux Thank you.
This was also helped me !
Thank you.
