Question about bed probing
@User3D said in Question about bed probing:
I still don't know if my bed is stable
So the first thing to improve is the stabilty of the bed.
Otherwise you will compare one error to an other...
Or you have to mesh level before every print...
Had the same issue with my Hevo.
After modifying the bed frame, the thing is rock solid.
I mesh level the bed only for sanity 3-4 times a year.. -
@DIY-O-Sphere How you modified your HEVO Bed?
@fcwilt said in Question about bed probing:
so why not just continue the process and level it?
wanted to make it less human dependent .
No biggie... I'll go with current method .Thanks for the help
I just run bed leveling twice at the start of a print. It only probes the bed at three points each time so it's not like it take a long time.
Can you clarify what you mean by "human dependent"?
If error difference is greater than a value then I want it to tell me. So then I will level my bed manually.
Perhaps you and I are talking about different types of bed leveling?
What do you do to manually level your bed?
@fcwilt paper technique I am talking about here .
So you don't have a Z probe?
@fcwilt I have
@fcwilt I have
If you have a z probe why would you be using paper to level the bed?
@fcwilt I started doing so after nozzle ran into my bed and scratched it
