Duet 3 losing connection whilst printing
I have exactly the same problem and have tried everything with SD card, new image etc.
Does anyone else have any ideas what this could be?
I have come a little closer to solving the problem:
Keyboard, mouse, HDMI, USB touchscreen cable all unplugged from the Raspberry Pi 4.
Raspberry Pi 4 has its own power supply
Remote access to the Pi via AnyDesk
Don't click anything in the web GUI while printing-> Lost connection problem is gone
If you click around in the Web GUI (while printing) the problem comes back immediately
Seems to be a problem when the Pi is busy with something else while printing -
@Thoma308 said in Duet 3 losing connection whilst printing:
Seems to be a problem when the Pi is busy with something else while printingWhat speed class is your SD card?
@Phaedrux said in Duet 3 losing connection whilst printing:
Seems to be a problem when the Pi is busy with something else while printingA1 SanDisk Ultra UHS-I Speed UP TO 98 MB/s 653X 16GB
Seems to be a problem when the Pi is busy with something else while printingI have now done another test:
Raspberry PI without LAN and without WLAN (offline).
I got the Lost connection message 2 times in about 2 hours - but without aborting the print ...
still funny the whole thing -
still funny the whole thingEven after some more tests and an update to the latest versions, the problem is still there and unsolved.
So I would be glad for more ideas
RepRapFirmware for Duet 3 MB6HC version 3.2 running on Duet 3 MB6HC v1.01 or later (SBC mode)
Board ID: 08DJM-956L2-G43S4-6J1FL-3SJ6J-186LG
Used output buffers: 1 of 40 (10 max)
Static ram: 149788
Dynamic ram: 62488 of which 64 recycled
Never used RAM 146492, free system stack 128 words
Tasks: Linux(ready,71) HEAT(blocked,296) CanReceiv(blocked,927) CanSender(blocked,352) CanClock(blocked,352) TMC(blocked,19) MAIN(running,1217) IDLE(ready,19)
Owned mutexes: HTTP(MAIN)
Last reset 01:17:13 ago, cause: software
Last software reset details not available
Error status: 0x00
Aux0 errors 0,0,0
Aux1 errors 0,0,0
MCU temperature: min 23.8, current 29.9, max 31.1
Supply voltage: min 23.7, current 23.9, max 24.1, under voltage events: 0, over voltage events: 0, power good: yes
12V rail voltage: min 12.1, current 12.1, max 12.2, under voltage events: 0
Driver 0: position 111288, standstill, reads 17312, writes 59 timeouts 0, SG min/max 0/1023
Driver 1: position 69098, standstill, reads 17312, writes 59 timeouts 0, SG min/max 0/1023
Driver 2: position 102, standstill, reads 17312, writes 59 timeouts 0, SG min/max 0/1023
Driver 3: position 0, standstill, reads 17308, writes 63 timeouts 0, SG min/max 0/340
Driver 4: position 0, standstill, reads 17309, writes 63 timeouts 0, SG min/max 0/321
Driver 5: position 0, standstill, reads 17329, writes 43 timeouts 0, SG min/max 0/461
Date/time: 2021-01-24 10:59:34
Slowest loop: 181.18ms; fastest: 0.03ms
=== Storage ===
Free file entries: 10
DMs created 125, maxWait 476875ms, bed compensation in use: none, comp offset 0.000
=== MainDDARing ===
Scheduled moves 107, completed moves 107, hiccups 0, stepErrors 0, LaErrors 0, Underruns [16, 0, 42], CDDA state -1
=== AuxDDARing ===
Bed heaters = -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1, chamberHeaters = -1 -1 -1 -1
Segments left: 0
Movement lock held by null
Telnet is idle in state(s) 0
File* is idle in state(s) 0
USB is idle in state(s) 0
Aux is idle in state(s) 0
Queue* is idle in state(s) 0
LCD is idle in state(s) 0
SBC is idle in state(s) 0
Daemon is idle in state(s) 0
Aux2 is idle in state(s) 0
Code queue is empty.
=== CAN ===
Messages queued 18522, send timeouts 41688, received 0, lost 0, longest wait 0ms for reply type 0, free buffers 48
=== SBC interface ===
State: 4, failed transfers: 149
Last transfer: 1ms ago
RX/TX seq numbers: 33443/55116
SPI underruns 192, overruns 31
Number of disconnects: 10, IAP RAM available 0x2c8a8
Buffer RX/TX: 0/0-0
=== Duet Control Server ===
Duet Control Server v3.2.0
Code buffer space: 4096
Full transfers per second: 35.68
Maximum length of RX/TX data transfers: 2548/36
24.1.2021, 11:01:28: M122 "DSF": === Duet Control Server ===
Full transfers per second: 35.76
24.1.2021, 11:15:39: M122: === Diagnostics ===
Used output buffers: 2 of 40 (10 max)
Static ram: 149788
Tasks: Linux(ready,71) HEAT(blocked,296) CanReceiv(blocked,927) CanSender(blocked,352) CanClock(blocked,352) TMC(blocked,19) MAIN(running,1141) IDLE(ready,19)
Last reset 01:33:18 ago, cause: software
Error status: 0x00
Aux0 errors 0,0,0
Aux1 errors 0,0,0
MCU temperature: min 29.6, current 30.0, max 30.3
Supply voltage: min 23.8, current 23.9, max 24.0, under voltage events: 0, over voltage events: 0, power good: yes
Driver 0: position 111288, standstill, reads 27870, writes 0 timeouts 0, SG min/max not available
Driver 1: position 69098, standstill, reads 27870, writes 0 timeouts 0, SG min/max not available
Driver 2: position 16102, standstill, reads 27870, writes 0 timeouts 0, SG min/max not available
Driver 3: position 0, standstill, reads 27866, writes 4 timeouts 0, SG min/max 0/280
Driver 4: position 0, standstill, reads 27866, writes 4 timeouts 0, SG min/max 0/274
Driver 5: position 0, standstill, reads 27870, writes 0 timeouts 0, SG min/max not available
Date/time: 2021-01-24 11:15:38
Slowest loop: 0.45ms; fastest: 0.04ms
=== Storage ===
DMs created 125, maxWait 1432576ms, bed compensation in use: none, comp offset 0.000
=== MainDDARing ===
Scheduled moves 109, completed moves 109, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 1], CDDA state -1
=== AuxDDARing ===
Segments left: 0
=== CAN ===
Messages queued 3859, send timeouts 8682, received 0, lost 0, longest wait 0ms for reply type 0, free buffers 48
Last transfer: 2ms ago
RX/TX seq numbers: 2360/24033
Buffer RX/TX: 0/0-0
Full transfers per second: 35.72
Maximum length of RX/TX data transfers: 4080/156 -
Can you check your rPi syslog file (/var/log/syslog) and look for warnings/errors from duet control server. if there are any do they match up with when you had the lost connections?
@gloomyandy said in Duet 3 losing connection whilst printing:
/varlog/syslog
Yes, I just started the heater, and instantly saw warnings in that log file, as below
Jan 24 13:17:49 duet3 DuetWebServer[564]: [DoCode] Executing code 'M140 P0 S60'
Jan 24 13:17:49 duet3 DuetWebServer[564]: #033[40m#033[32minfo#033[39m#033[22m#033[49m: Microsoft.AspNetCore.Mvc.Infrastructure.ContentResultExecutor[1]
Jan 24 13:17:49 duet3 DuetWebServer[564]: Executing ContentResult with HTTP Response ContentType of text/plain; charset=utf-8
Jan 24 13:17:49 duet3 DuetWebServer[564]: #033[40m#033[32minfo#033[39m#033[22m#033[49m: Microsoft.AspNetCore.Mvc.Infrastructure.ControllerActionInvoker[2]
Jan 24 13:17:49 duet3 DuetWebServer[564]: Executed action DuetWebServer.Controllers.MachineController.DoCode (DuetWebServer) in 121.9828ms
Jan 24 13:17:49 duet3 DuetWebServer[564]: #033[40m#033[32minfo#033[39m#033[22m#033[49m: Microsoft.AspNetCore.Routing.EndpointMiddleware[1]
Jan 24 13:17:49 duet3 DuetWebServer[564]: Executed endpoint 'DuetWebServer.Controllers.MachineController.DoCode (DuetWebServer)'
Jan 24 13:17:49 duet3 DuetWebServer[564]: #033[40m#033[32minfo#033[39m#033[22m#033[49m: Microsoft.AspNetCore.Hosting.Diagnostics[2]
Jan 24 13:17:49 duet3 DuetWebServer[564]: Request finished in 124.107ms 200 text/plain; charset=utf-8
Jan 24 13:17:49 duet3 DuetControlServer[3086]: [warn] Restarting transfer because a bad data response was received (0x00000022)
Jan 24 13:17:49 duet3 DuetControlServer[3086]: [warn] Restarting transfer because a bad data response was received (0x00000011)
Jan 24 13:17:50 duet3 DuetControlServer[3086]: [warn] Restarting transfer because a bad header response was received (0x000000b2)
Jan 24 13:17:50 duet3 DuetControlServer[3086]: [warn] Bad data CRC32 (expected 0xe20300be, got 0x02635649)
Jan 24 13:17:50 duet3 DuetControlServer[3086]: [warn] Bad data CRC32 (expected 0xe20300be, got 0xabbbd02c)
Jan 24 13:17:50 duet3 DuetControlServer[3086]: [warn] Bad data CRC32 (expected 0xe20300be, got 0x66f47fab)
Jan 24 13:17:50 duet3 DuetControlServer[3086]: [warn] Restarting transfer because the number of maximum retries has been exceeded
Jan 24 13:17:50 duet3 DuetControlServer[3086]: [warn] Restarting transfer because a bad header response was received (0x00000074)
Jan 24 13:17:50 duet3 DuetControlServer[3086]: [warn] Lost connection to Duet (Board is not available (no header))
Jan 24 13:17:50 duet3 DuetControlServer[3086]: [info] Connection to Duet established
Jan 24 13:17:50 duet3 DuetControlServer[3086]: [warn] Bad data CRC32 (expected 0xfee53e33, got 0x29af8a10)
Jan 24 13:17:50 duet3 DuetControlServer[3086]: [warn] Restarting transfer because a bad data response was received (0x0000002c)
Jan 24 13:17:51 duet3 DuetControlServer[3086]: [warn] Restarting transfer because a bad header response was received (0xffffffe1)
Jan 24 13:17:51 duet3 DuetControlServer[3086]: [warn] Restarting transfer because a bad header response was received (0x0000007a)
Jan 24 13:17:51 duet3 DuetControlServer[3086]: [warn] Lost connection to Duet (Board is not available (no header))
Jan 24 13:17:51 duet3 DuetControlServer[3086]: [warn] Bad data CRC32 (expected 0x147bc906, got 0x094245ad)
Jan 24 13:17:51 duet3 DuetControlServer[3086]: [warn] Bad data CRC32 (expected 0x147bc906, got 0xb45e66d9)
Jan 24 13:17:51 duet3 DuetControlServer[3086]: [info] Connection to Duet established
Jan 24 13:17:51 duet3 DuetControlServer[3086]: [warn] Restarting transfer because a bad header response was received (0x00000070)
Jan 24 13:17:51 duet3 DuetControlServer[3086]: [warn] Restarting transfer because a bad data response was received (0xffffff77)
Jan 24 13:17:51 duet3 DuetControlServer[3086]: [warn] Bad data CRC32 (expected 0xf639780f, got 0x6abe97ec)
Jan 24 13:17:51 duet3 DuetControlServer[3086]: [warn] Restarting transfer because a bad header response was received (0x000000de) -
Looks like your heater may be introducing noise into the Duet/SBC connection. Obvious things are to check how the various cables are routed. How long is the cable between the rPi and the Duet? Perhaps some photos of how you have things set up?
@gloomyandy That was my first thought as well, so I moved the rPi out of the enclosure with the other electronics until it was sorted. It is that cable that came with the Duet ![alt text]
SOLVED:
The Heater is not the problem
I plugged everything back in on the PI, keyboard, mouse,
HDMI, USB touchscreen and connected the PI to the LAN.
Also reinstalled Anydesk as a remote terminal.
I accessed everything via http://duet3.local/ and locally via the screen on the PI again.AND NOW THE SOLUTION:
The separtate power supply is the problem. You can power the SBC directly and power the Duet separately.
there are jumpers for that on the board.
And that was the problem with two separate power supplies.
I now have a 4A power supply directly on the PI and through that I also feed the 5V in the Duet.
-> and that was the solution2h printing without any error message
https://duet3d.dozuki.com/Wiki/Duet_3_Mainboard_6HC_Hardware_Overview#Section_5V
SBC->5V and 5V -> SBC both are now connected -
@Thoma308 In that case, your problem is different to mine, as I already tried all the variations of powering pi & duet
But it probably has to do with the power supply. I would make some more attempts in this direction. I use a Raspberry Pi 4 Model B 4GB
I have the same problem but when I did connect it via duet->SBC still giving the same issue.
For me it runs perfectly now, but only with the power supply from the Pi and both jumper set
SBC->5V
5V -> SBC -
@Dan1990 via ssh/putty.
There is a typo it is actually /var/log/syslog
I ran the following command and watched the output once whilst testing:
tail -f /var/log/syslog -
Thanks,
I have the same issue as you, and I think I have found a lead to solve it. I disconnected the bed and for now, everything looks fine.
