heatbed rebel FRW 3.2
Hello
I have a problem with the heatbed. after several autopid (m303) and data readings, save and reset.
insists on not functioning normally.
I went from megatronic where it worked, with duet I have a time / c ° error.
the plate is 8mm aluminum + 5mm glass.
My config.g is:; Configuration file for Duet WiFi (firmware version 3)
; generated by RepRapFirmware Configuration Tool v3.2.2 on Wed Jan 20 2021 20:48:08 GMT+0100 (Ora standard dell’Europa centrale); General preferences
M550 P"Bad Printer 2 (3.2)" ; set printer name
M669 K1 ; select CoreXY mode
M552 S1 ; enable network
M586 P0 S1 ; enable HTTP
M586 P1 S0 ; disable FTP
M586 P2 S0 ; disable Telnet
M569 P2 S0 ; physical drive 2 goes backwards
M569 P4 S0 ; physical drive 4 goes backwards
M584 X0 Y1 Z2 E3:4 ; set drive mapping
M92 X81.00 Y81.00 Z1600.00 E94.00:94.00 ; set steps per mmM566 X900.00 Y900.00 Z300.00 E300.00:300.00 ; set maximum instantaneous speed changes (mm/min)
M203 X12000.00 Y12000.00 Z600.00 E6000.00:6000.00 ; set maximum speeds (mm/min)
M201 X1500.00 Y1500.00 Z100.00 E10000.00:10000.00 ; set accelerations (mm/s^2)
M906 X1000 Y1000 Z1000 E1000:1000 I30 ; set motor currents (mA) and motor idle factor in per centM84 S180 ; Set idle timeout
M208 X-26 Y-12 Z0 S1 ; set axis minima
M208 X235 Y225 Z215 S0 ; set axis maxima
M574 Y1 S1 P"ystop" ; configure active-high endstop for low end on Y via pin ystopM574 Z1 S1 P"zstop" ; configure active-high endstop for low end on Z via pin zstop
M558 P0 H10 F120 T6000 ; disable Z probe but set dive height, probe speed and travel speed
M557 X10:200 Y10:200 S40 ; define mesh grid
M308 S0 P"bedtemp" Y"thermistor" T100000 B4138 R4700 ; configure sensor 0 as thermistor on pin bedtemp
M143 H0 S100 ; set temperature limit for heater 0 to 100C
M143 H1 S285 ; set temperature limit for heater 1 to 285
C
M308 S2 P"e1temp" Y"thermistor" T100000 B4138 ; configure sensor 2 as thermistor on pin e1tempM950 H2 C"e1heat" T2 ; create nozzle heater output on e1heat and map it to sensor 2
M
307 H2 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit
M143 H2 S285 ; set temperature limit for heater 2 to 285C; Fans
M106 P0 C"testa" S0 H-1 ; set fan 0 name and value. Thermostatic control is turned off
M106 P1 C" cpu" S0 H0 T40 ; set fan 1 name and value. Thermostatic control is turned on
M563 P0 S"hot end 0" D0 H1 F0 ; define tool 0
M563 P1 S"hot end 1" D1 H2 F0 ; define tool 1
G10 P1 X0 Y26 Z0 ; set tool 1 axis offsets
M501; Custom settings
override.g
M122 ; stop emergenza esternoM591 ; rilevamento filo inceppato
M500 ; salva eprom
M581 ; configurazione del trigger esterno
M555 ; imposta compatibilità
M501 ; legge i parametri memorizzati
M70 ; caricamento del filamento
M70 ; scaricare il filamento
M90 ; Imposta data e ora locali
M911 S10 R11 P" M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; set voltage thresholds and actions to run on power loss
@Pillccia said in heatbed rebel FRW 3.2:
M500 ; salva eprom
Don't put M500 in config.g. It's only used immediately after tuning is finished to save the results. Send it from the console.
Only put M501 in config.g once.
@Phaedrux
i uploaded frw 2.05.
now the bed, and the rest, works, done autotuning of all the heaters, and the next step is to do the first test pieces, to see the last calibrations. -
@Pillccia There are no PID parameters anywhere in either your config.g or your config_overide.g files. You've got M307 B0 to disable bang-bang mode but you haven't put the result of the M303 tuning parameters in your config.g file, nor have you saved the result to config_overide (according to the information that you've posted).
Hello and thanks
But I didn't understand which line I have to write in config.g, M307 vp13,4 10950 d51,5?
Exact -
No.
In the console send
M303 H0 S60
to tune the bed.
Wait for it to finish.
Then sendM303 H1 S200
to tune the hotend.
Then sendM500
Then addM501
to the end of config.g.That's it.
