Duex5 Fan Settings?
the pin assignment of the probe was a little different after the update. everything works now
will update the board regularly from now on XD . many thanks
It's an inductive probe that has deploy and retract?
a bltouch was built in, I forgot to delete the commands
Remove the M401 and M402 commands and even delete or rename the deployprobe.g and retractprobe.g files.
Post your current config.g and your homing files as well as any of the macros you are calling in your above sample.
I found the error and the print runs without problems
What was the error?
the voltage was too low. with the 24v now the sensor works fine
Since the update, I have to select the slot on the paneldue every time I start it with m21 p1. can I somehow program this in the config?
You could try adding M21 P1 to the end of config.g
After entering the command the SD card can be selected but the connection is not permanent. if I print something on the es card and the connection is interrupted, the board restarts. but it doesn't matter, I use the upload & start function
