Duex5 Fan Settings?
@joe92
Take the full release zip file "Duet2and3Firmware-3.0.zip" and try it again.... -
Just to ensure you have a clean install with all the files, and you still have access to DWC. Upload these 3 zip files, one at a time. Don't extract them. Reboot after each.
https://github.com/Duet3D/RepRapFirmware/releases/download/3.0/Duet2and3Firmware-3.0.zip
https://github.com/Duet3D/RepRapFirmware/releases/download/3.2/Duet2and3Firmware-3.2.zip
ok everything works so far but my inductive sensor (PL-08N) doesn't
; generated by RepRapFirmware Configuration Tool v3.2.1 on Fri Jan 15 2021 23:22:23 GMT+0100 (Mitteleuropäische Normalzeit); General preferences
M555 P2 ; Set firmware compatibility to look like Marlin
M550 P"Voron V2" ; set printer name
M669 K1 ; select CoreXY mode; Network
M552 S1 ; enable network
M586 P0 S1 ; enable HTTP
M586 P1 S0 ; disable FTP
M586 P2 S0 ; disable Telnet; G29 Mesh
M557 X55:295 Y30:270 S30 ; S30 for high density, S40 for testing; Drives
M569 P0 S1 ; X Motor goes backwards
M569 P1 S1 ; Y Motor goes backwards
M569 P3 S1 ; Extruder Motor 0 goes forwards (BMG)
M569 P5 S1 ; Z1 goes backwards
M569 P6 S0 ; Z2 goes forwards
M569 P7 S1 ; Z3 goes forwards
M569 P8 S0 ; Z4 goes backwardsM92 X80 Y80 Z400 ; Steps per mm
M92 E415 ; Steps per mm (BMG) (1.8deg)
M350 E16 I1 ; Configure microstepping with interpolation
M350 X16 Y16 Z16 I1 ; Configure microstepping with interpolation
M203 X18000 Y18000 E9000 Z4000 ; Set maximum speeds (mm/min) for 2.1 only (300mm/s max)
M201 X3000 Y3000 E6000 Z500 ; Set accelerations (mm/s^2)
M566 X900 Y900 E1200 Z150 ; Set maximum instantaneous speed changes (mm/min)
M98 P"/macros/print_scripts/xy_current_high.g" ; Set XY Motor Currents
M98 P"/macros/print_scripts/e_current_high.g" ; Set Extruder Motor Currents
M98 P"/macros/print_scripts/z_current_high.g" ; Set Z Motor Currents (must come after extruder, because on the extruder headers)
M84 S0 ; Set idle timeout, never time out; Axis Limits
M208 X350 Y350 Z300 S0 ; set axis maxima; Endstops
M574 Y1 S1 P"ystop" ; configure active-high endstop for low end on Y via pin ystop; Inductive Leveling Sensor
M98 P"/macros/probe_scripts/activate_z_probe.g" ; activate the Z probe
M98 P"/macros/probe_scripts/activate_z_switch.g" ; activate the Z switch; Z-Axis Stepper Leveling Configuration
M584 X0 Y1 Z5:6:7:8 ; 4 motors; duex 5, 6, 7, 8
M671 X403:403:-56:-56 Y356:-66:-66:356 S20 ; belts in all 4 corners; Heaters
M308 S0 P"bedtemp" Y"thermistor" T100000 B3950 ; configure sensor 0 as thermistor on pin bedtemp
M308 S1 P"e0temp" Y"thermistor" T100000 B3950 ; configure sensor 1 as thermistor on pin e0temp
M950 F0 C"duex.fan3" Q500 ; create fan 0 on pin duex.fan3 and set its frequency
M950 F2 C"fan2" Q500 ; create fan 2 on pin fan2 and set its frequency
M106 P2 S1 H1 T45 ; set fan 2 value. Thermostatic control is turned on; Tools
M575 P1 S1 B57600 ; enable support for PanelDue; Enable config-override.g
;M501; Allow Movement of Axis that have not been homed
M564 H0 -
0:/macros/Probe_Scripts/activate_z_probe.g
M558 P5 C"^zprobe.in" H5 F120 T6000 ; set Z probe type to switch and the dive height + speeds
G31 P25 X0 Y-23.50 Z6.500 ; set Z probe trigger value, offset and trigger height0:/macros/Probe_Scripts/activate_z_switch.g
G31 P1000 X0 Y0 Z1.53 ; Setup Offsets for Z Switch -
I tried the pin assignment but no difference. It doesn't matter whether the cables from the sensor are connected to the board, this error appears "Error: Z probe already triggered at start of probing move". the sensor is permanently set to 1000 in the web control. I don't know what to do next
To invert the switch signal you add a ! to the pin name.
Ex: C"^!zprobe.in"
the inverting worked but I get this message "G32
Error: Z probe was not triggered during probing move "; bed.g
; setup for quad belt gantryM561 ; Clear any existing bed transform
G28 ; homeM98 P"/macros/probe_scripts/activate_z_probe.g" ;activate inductive z-probe
M401 ; Deploy probe - Deployprobe.g
; Probe bed at these 4 points:
G30 P0 X65 Y40 Z-9999
G30 P1 X65 Y260 Z-9999
G30 P2 X285 Y260 Z-9999
G30 P3 X285 Y40 Z-9999 S4M402 ; Retract Probe - Retractprobe.g
G28 Z ; Home Z AxisM98 P"/macros/probe_scripts/activate_z_probe.g" ;activate inductive z-probe
the z-probe works in single commands, but not in the g32 / g29
the pin assignment of the probe was a little different after the update. everything works now will update the board regularly from now on XD . many thanks
It's an inductive probe that has deploy and retract?
a bltouch was built in, I forgot to delete the commands
Remove the M401 and M402 commands and even delete or rename the deployprobe.g and retractprobe.g files.
Post your current config.g and your homing files as well as any of the macros you are calling in your above sample.
I found the error and the print runs without problems
What was the error?
the voltage was too low. with the 24v now the sensor works fine
Since the update, I have to select the slot on the paneldue every time I start it with m21 p1. can I somehow program this in the config?
You could try adding M21 P1 to the end of config.g
After entering the command the SD card can be selected but the connection is not permanent. if I print something on the es card and the connection is interrupted, the board restarts. but it doesn't matter, I use the upload & start function
