New to the duet COMPLETE NEWBIE
@Phaedrux Fixed it and was able to get it heated up to 180,
Now when i try to get the bed heated i get thisError: Heater 0 fault: temperature rising much more slowly than the expected 1.8°C/sec
@Phaedrux Okay i looked up the issue and found YOU lol, going to PID tune the bed. .
We're on a roll!
@Phaedrux Good morning from my end. we definitely were on a roll yesterday. I did a PID test for the heated bed and this is what I got,
1/20/2021, 7:25:49 PM M500
1/20/2021, 7:25:31 PM M307 H0 R0.208 C535.3 D7.42 S1.00 V12.0
Warning: M307: Heater 0 appears to be over-powered. If left on at full power, its temperature is predicted to reach 136C
1/20/2021, 7:23:29 PM Warning: heater behaviour was not consistent during tuning
Auto tuning heater 0 completed after 3 idle and 25 tuning cycles in 4384 seconds. This heater needs the following M307 command:
Send M500 to save this command in config-override.gAt this point I don't know what to do.
EDIT: indeed i do, Ill go back in to the shop and tune the hotend as well and try to run the min temps for PLA. . hopefully i dont get any errors. I will let you know once i am finished. -
you send M500 to save the tuning parameters.
@Veti
Yes i sent it after both test were performed. Here is the summary for both1/21/2021, 10:15:03 AM M500
1/21/2021, 10:14:47 AM M307 H1 R2.273 C141.1 D6.29 S1.00 V12.0
1/21/2021, 10:14:20 AM Auto tuning heater 1 completed after 3 idle and 5 tuning cycles in 401 seconds. This heater needs the following M307 command:
1/21/2021, 10:11:54 AM Auto tune starting phase 3, fan off
1/21/2021, 10:09:52 AM Auto tune starting phase 2, heater settling
1/21/2021, 10:07:44 AM Auto tune starting phase 1, heater on1/21/2021, 10:07:39 AM M303 H1 S210
Auto tuning heater 1 using target temperature 210.0°C and PWM 1.00 - do not leave printer unattended
1/21/2021, 10:06:23 AM M106 S127
1/21/2021, 10:00:22 AM Connection established
1/20/2021, 7:27:51 PM Connection interrupted, attempting to reconnect...
HTTP request timed out
1/20/2021, 6:22:39 PM Auto tune starting phase 3, fan off
1/20/2021, 6:14:17 PM Auto tune starting phase 2, heater settling
1/20/2021, 6:10:31 PM Auto tune starting phase 1, heater on
1/20/2021, 6:10:25 PM M303 H0 S60
Auto tuning heater 0 using target temperature 60.0°C and PWM 1.00 - do not leave printer unattended -
i was talking about the delta calibration
the new hotend tuning command is
M303 T0 S210 -
@Veti Ohhh , Okay. Im about to do a new one now then . THANKKK YOUUUUUUU!!!
M303 T0 S210 will tune the hotend heater and take the part cooling fan into account.
For the bed heater, the M303 H0 S60 is correct.
Not sure why you're getting that though. What kind of bed heater do you have on the CR-10? Stock? Are you starting from room temp?
Do the saved tuning results allow for you to heat the bed to 60 in a reasonable time and keep a consistent temp? If so, that's all that really matters.
@Phaedrux Big baby is doing better, i got her up to 50 and she held it pretty well. Thank you!! Ill keep you updated though
@Phaedrux should i be concerned if the MCU temp is up to 27.6?
Probably not, but first make sure it's an accurate temp.
https://duet3d.dozuki.com/Wiki/Calibrating_the_CPU_temperature
With a bit of forced air cooling even after a long print it doesn't get much above 35 for me. And you really only need to worry about 80+ The drivers get hotter and need more cooling than the MCU, but the MCU temp can be used as a proxy for the driver temps and allow for using a thermostatically controlled fan. All described in this link.
https://duet3d.dozuki.com/Wiki/Mounting_and_cooling_the_board
@Phaedrux I hooked one up and its good now. .
I tried to print the calibration box and my Extruder wasn't close to my bed at all still trying to print. . also when i try to home XYZ it states its "busy" and waits about 3-5 mins to move at all. . . idk what to do. Is it something id have to change within my config? -
Please post your current config.g and homeall.g and copy and paste the first 50 lines or so of your sliced gcode file you're trying to print.
; generated by RepRapFirmware Configuration Tool v3.2.1 on Tue Jan 19 2021 17:33:25 GMT-0500 (Eastern Standard Time); General preferences
M550 P"Creola" ; set printer name; Network
M552 S1 ; enable network
M586 P0 S1 ; enable HTTP
M586 P1 S0 ; disable FTP
M569 P0 S0 ; physical drive 0 goes backwards
M92 X80.00 Y80.00 Z400.00 E97.08 ; set steps per mm
M203 X6000.00 Y6000.00 Z600.00 E1200.00 ; set maximum speeds (mm/min)
M201 X500.00 Y500.00 Z120.00 E250.00 ; set accelerations (mm/s^2)
M208 X300 Y300 Z400 S0 ; set axis maxima; Endstops
M574 Z1 S1 P"!zstop" ; configure active-high endstop for low end on Z via pin !zstop; Z-Probe
M558 P0 H18 F120 T480000 ; disable Z probe but set dive height, probe speed and travel speed
M557 X10:220 Y10:220 S20 ; define mesh grid; Heaters
M308 S0 P"bedtemp" Y"thermistor" T98801 B4185 ; configure sensor 0 as thermistor on pin e0temp
M950 H0 C"bedheat" T0 ; create bed heater output on e0heat and map it to sensor 0
M143 H0 S80 ; set temperature limit for heater 0 to 80C
M308 S1 P"e1temp" Y"thermistor" T98801 B4185 ; configure sensor 1 as thermistor on pin e1temp; homeall.g
; called to home all axes
G91 ; relative positioning
G1 H2 Z18 F480000 ; lift Z relative to current position
G1 H1 X-305 Y-305 F3000 ; move quickly to X and Y axis endstops and stop there (first pass)
G1 H2 X5 Y5 F480000 ; go back a few mm
G1 H1 X-305 Y-305 F3600 ; move slowly to X and Y axis endstops once more (second pass)
G1 H1 Z-405 F3600 ; move Z down stopping at the endstop
G90 ; absolute positioning
G92 Z0 ; set Z position to axis minimum (you may want to adjust this); Uncomment the following lines to lift Z after probing
;G91 ; relative positioning
;G1 Z18 F8000 ; lift Z relative to current position
;G90 ; absolute positioning;FLAVOR:Marlin
;TIME:15708
;Filament used: 30.0079m
;Layer height: 0.32
;MINX:87.5
;MINY:87.5
;MINZ:0.32
;MAXX:212.5
;MAXY:212.5
;MAXZ:99.84
;Generated with Cura_SteamEngine 4.8.0
M140 S45
M105
M190 S45
M104 S210
M105
M109 S210
M82 ;absolute extrusion mode
M201 X500.00 Y500.00 Z100.00 E5000.00 ;Setup machine max acceleration
M203 X500.00 Y500.00 Z10.00 E50.00 ;Setup machine max feedrate
M204 P500.00 R1000.00 T500.00 ;Setup Print/Retract/Travel acceleration
M205 X8.00 Y8.00 Z0.40 E5.00 ;Setup Jerk
M220 S100 ;Reset Feedrate
M221 S100 ;Reset FlowrateG28 ;Home
G92 E0 ;Reset Extruder
G1 Z2.0 F3000 ;Move Z Axis up
G1 X10.1 Y20 Z0.28 F5000.0 ;Move to start position
G1 X10.1 Y200.0 Z0.28 F1500.0 E15 ;Draw the first line
G1 X10.4 Y200.0 Z0.28 F5000.0 ;Move to side a little
G1 X10.4 Y20 Z0.28 F1500.0 E30 ;Draw the second line
G1 Z2.0 F3000 ;Move Z Axis upG92 E0
G92 E0
G1 F2700 E-5
;LAYER_COUNT:312
;LAYER:0
M107
G0 F6000 X96.919 Y97.136 Z0.32
;TYPE:SKIRT
G1 F2700 E0
G1 F1200 X97.194 Y96.861 E0.05174
G1 X97.565 Y96.502 E0.12042
G1 X97.79 Y96.289 E0.16164
G1 X98.257 Y95.859 E0.2461
G1 X98.563 Y95.587 E0.30057 -
@gabrealek said in New to the duet COMPLETE NEWBIE:
M205 X8.00 Y8.00 Z0.40 E5.00 ;Setup JerkDelete these lines from your cura start gcode.
;FLAVOR:Marlin
Also in Cura change your gcode flavour to REPRAP
Also change cura to use relative extrusion while you're at it.
Then reslice and try again.
@Phaedrux I feel like such a nube, thanks again!! Im about to try now and keep you updated.
Don't feel too bad, 3D printing is probably one of the most complicated hobbies you can pick up.
@Phaedrux Okay. . so it tried to print again . . but . the extruder isnt going up or down . .
