New to the duet COMPLETE NEWBIE
; generated by RepRapFirmware Configuration Tool v3.2.1 on Tue Jan 19 2021 15:22:13 GMT-0500 (Eastern Standard Time); General preferences
M550 P"Creola" ; set printer name; Network
M552 S1 ; enable network
M586 P0 S1 ; enable HTTP
M586 P1 S0 ; disable FTP
M569 P0 S0 ; physical drive 0 goes backwards
M92 X80.00 Y80.00 Z400.00 E93.00 ; set steps per mm
M203 X6000.00 Y6000.00 Z600.00 E1200.00 ; set maximum speeds (mm/min)
M201 X500.00 Y500.00 Z120.00 E250.00 ; set accelerations (mm/s^2)
M208 X300 Y300 Z400 S0 ; set axis maxima; Endstops
M574 Z1 S1 P"!zstop" ; configure active-high endstop for low end on Z via pin !zstop; Z-Probe
M558 P0 H18 F120 T480000 ; disable Z probe but set dive height, probe speed and travel speed
M557 X10:220 Y10:220 S20 ; define mesh grid; Heaters
M308 S0 P"e0temp" Y"thermistor" T9880 B4185 ; configure sensor 0 as thermistor on pin e0temp
M950 H0 C"e0heat" T0 ; create nozzle heater output on e0heat and map it to sensor 0
M307 H0 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit
M143 H0 S250 ; set temperature limit for heater 0 to 250C
M308 S1 P"bedtemp" Y"thermistor" T9880 B4185 ; configure sensor 1 as thermistor on pin bedtemp
M950 H1 C"bedheat" T1 ; create bed heater output on bedheat and map it to sensor 1
M307 H1 B0 S1.00 ; disable bang-bang mode for the bed heater and set PWM limit
M140 H1 ; map heated bed to heater 1
M143 H1 S80 ; set temperature limit for heater 1 to 80C; Fans
M950 F0 C"fan0" Q20 ; create fan 0 on pin fan0 and set its frequency
M950 F1 C"fan1" Q20 ; create fan 1 on pin fan1 and set its frequency
M563 P0 S"Extruder" D0 F0:1 ; define tool 0
M911 S21 R23 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; set voltage thresholds and actions to run on power loss; homeall.g
; called to home all axes
; generated by RepRapFirmware Configuration Tool v3.2.1 on Tue Jan 19 2021 15:30:54 GMT-0500 (Eastern Standard Time)
G91 ; relative positioning
G1 H2 Z18 F480000 ; lift Z relative to current position
G1 H1 X-305 Y-305 F3000 ; move quickly to X and Y axis endstops and stop there (first pass)
G1 H2 X5 Y5 F480000 ; go back a few mm
G1 H1 X-305 Y-305 F3600 ; move slowly to X and Y axis endstops once more (second pass)
G1 H1 Z-405 F3600 ; move Z down stopping at the endstop
G90 ; absolute positioning
G92 Z0 ; set Z position to axis minimum (you may want to adjust this); Uncomment the following lines to lift Z after probing
;G91 ; relative positioning
;G1 Z18 F8000 ; lift Z relative to current position
;G90 ; absolute positioning; homex.g
; called to home the X axis
; generated by RepRapFirmware Configuration Tool v3.2.1 on Tue Jan 19 2021 15:31:40 GMT-0500 (Eastern Standard Time)
G1 H1 X-305 F3000 ; move quickly to X axis endstop and stop there (first pass)
G1 H2 X5 F480000 ; go back a few mm
G1 H1 X-305 F3600 ; move slowly to X axis endstop once more (second pass)
G1 H2 Z-18 F480000 ; lower Z again
G90 ; absolute positioning; homez.g
; called to home the Z axis
; generated by RepRapFirmware Configuration Tool v3.2.1 on Tue Jan 19 2021 15:31:58 GMT-0500 (Eastern Standard Time)
G1 H1 Z-405 F3000 ; move Z down until the endstop is triggered
;G90 ; absolute positioningIve checked my wiring and it all seems correct.
@gabrealek said in New to the duet COMPLETE NEWBIE:
M143 H1 S80 ; set temperature limit for heater 1 to 80CIt would be more traditional for heater0 to be the bed heater and for heater1 to be the first tool heater. I don't think that's strictly enforced now with RRF3 being more flexible about it, but still not a bad idea to conform to the standard.
Also, your tool definition is lacking a heater.
Maybe take another crack at the config tool. https://duet3d.dozuki.com/Guide/Ender+3+Pro+and+Duet+Mini+5++Guide+Part+2:+Configuration/88
@Phaedrux Okay, back into the studio I go. Thank you for helping me!!!!
Double check your heater and thermistor connections as well. Hopefully that will resolve the odd heater reporting in DWC.
Otherwise the config looks ok so far.
After the heaters are sorted you'd want to carefully check the motor directions are correct and endstops are working and then test homing. And then test and tune the heaters and calibrate the extruder.
follow along
https://duet3d.dozuki.com/Guide/Ender+3+Pro+and+Duet+Maestro+Guide+Part+3:+Commissioning/39 -
@Phaedrux thanks. Ive checked the connections and redid them as the ender tutorial and now i am having a fault in the hotend and also the bed when i try to heat it as well.
Here is my new config . . ive been trying to get it right all day. ive done it exactly as the tutorial as well.
; generated by RepRapFirmware Configuration Tool v3.2.1 on Tue Jan 19 2021 17:33:25 GMT-0500 (Eastern Standard Time); General preferences
M950 H0 C"e0heat" T0 ; create bed heater output on e0heat and map it to sensor 0
M308 S1 P"e1temp" Y"thermistor" T9880 B4185 ; configure sensor 1 as thermistor on pin e1temp
M950 H1 C"e1heat" T1 ; create nozzle heater output on e1heat and map it to sensor 1
M106 P0 C"PartCool" S0 H-1 ; set fan 0 name and value. Thermostatic control is turned off
M106 P1 S1 H T45 ; set fan 1 value. Thermostatic control is turned on; Tools
M563 P0 S"Hotend" D0 H1 F0 ; define tool 0
T0 ; select first tool -
T9880
I think you're missing a digit in your T values.
@Phaedrux I dont understand how i would correct that. . its in there twice. . Ive tried to look up what a T9880 is . . i cant find anything .. Is it a problem with the setting i put in the config?
The correct values are
T98801
@Phaedrux thank you. It is greatly appreciated. Also, is the estop0 supposed to light up like the x,y, and z? When I plug it in it does not light up
That depends. What kind of switch are you plugging in as an endstop? The difference would be normally open switch or normally closed switch. The important thing is that the LED changes state when the switch is depressed.
What is the intended use for the endstop?
@Phaedrux I was just wondering. that was all .. thank you for all of your help!! i really appreciate it. Hope I didn't bother you to much. Lol
@Phaedrux OKAY, "sighs" new problem of the day. .
I got the hang of it now . . just posted to see if you'd find it sooner than my baby eyesError: G10: Requested temperature out of range
M308 S0 P"bedtemp" Y"thermistor" T98801 B4185 ; configure sensor 0 as thermistor on pin e0temp
M950 H0 C"bedheat" T0 ; create bed heater output on e0heat and map it to sensor 0
M308 S1 P"e1temp" Y"thermistor" T98801 B4185 ; configure sensor 1 as thermistor on pin e1temp
@Phaedrux
M307 H1 B0 S1.00 ; disable bang-bang mode for heater and set PWM limitI think its this line here maybe??
M143 H1 S80 ; set temperature limit for heater 1 to 80C -
@Phaedrux Fixed it and was able to get it heated up to 180,
Now when i try to get the bed heated i get thisError: Heater 0 fault: temperature rising much more slowly than the expected 1.8°C/sec
@Phaedrux Okay i looked up the issue and found YOU lol, going to PID tune the bed. .
We're on a roll!
@Phaedrux Good morning from my end. we definitely were on a roll yesterday. I did a PID test for the heated bed and this is what I got,
1/20/2021, 7:25:49 PM M500
1/20/2021, 7:25:31 PM M307 H0 R0.208 C535.3 D7.42 S1.00 V12.0
Warning: M307: Heater 0 appears to be over-powered. If left on at full power, its temperature is predicted to reach 136C
1/20/2021, 7:23:29 PM Warning: heater behaviour was not consistent during tuning
Auto tuning heater 0 completed after 3 idle and 25 tuning cycles in 4384 seconds. This heater needs the following M307 command:
Send M500 to save this command in config-override.gAt this point I don't know what to do.
EDIT: indeed i do, Ill go back in to the shop and tune the hotend as well and try to run the min temps for PLA. . hopefully i dont get any errors. I will let you know once i am finished. -
you send M500 to save the tuning parameters.
@Veti
Yes i sent it after both test were performed. Here is the summary for both1/21/2021, 10:15:03 AM M500
1/21/2021, 10:14:47 AM M307 H1 R2.273 C141.1 D6.29 S1.00 V12.0
1/21/2021, 10:14:20 AM Auto tuning heater 1 completed after 3 idle and 5 tuning cycles in 401 seconds. This heater needs the following M307 command:
1/21/2021, 10:11:54 AM Auto tune starting phase 3, fan off
1/21/2021, 10:09:52 AM Auto tune starting phase 2, heater settling
1/21/2021, 10:07:44 AM Auto tune starting phase 1, heater on1/21/2021, 10:07:39 AM M303 H1 S210
Auto tuning heater 1 using target temperature 210.0°C and PWM 1.00 - do not leave printer unattended
1/21/2021, 10:06:23 AM M106 S127
1/21/2021, 10:00:22 AM Connection established
1/20/2021, 7:27:51 PM Connection interrupted, attempting to reconnect...
HTTP request timed out
1/20/2021, 6:22:39 PM Auto tune starting phase 3, fan off
1/20/2021, 6:14:17 PM Auto tune starting phase 2, heater settling
1/20/2021, 6:10:31 PM Auto tune starting phase 1, heater on
1/20/2021, 6:10:25 PM M303 H0 S60
Auto tuning heater 0 using target temperature 60.0°C and PWM 1.00 - do not leave printer unattended -
i was talking about the delta calibration
