Endstops unstable and EMERGENCY STOP NOT STOPPING EXT.BOARD ???
Also endstops on extension board are ignored when homing after a print.
-Yes endstops are connected on the same ext board as the related stepper motors. -
@dc42 Just realised when I do a M115, it say firmware_version 3.1.1 BUT Firmware_date 2020-05-19.b2. is it right ?
Can you post the results of M122 so we can see what boards you're talking about?
@Phaedrux m122
RepRapFirmware for Duet 3 MB6HC version 3.1.1 running on Duet 3 MB6HC v1.01 or later (SBC mode)
Board ID: 08DJM-956L2-G43S4-6J1F8-3SD6T-9V56D
Used output buffers: 1 of 40 (16 max)
Static ram: 154604
Dynamic ram: 163276 of which 60 recycled
Exception stack ram used: 224
Never used ram: 75052
Tasks: NETWORK(ready,1972) HEAT(blocked,1188) CanReceiv(suspended,3408) CanSender(suspended,1488) CanClock(blocked,1436) TMC(blocked,204) MAIN(running,4952) IDLE(ready,76)
Owned mutexes:
Last reset 00:29:43 ago, cause: software
Last software reset at 2020-12-31 18:49, reason: User, spinning module LinuxInterface, available RAM 74620 bytes (slot 2)
Software reset code 0x0010 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0444a000 BFAR 0x00000000 SP 0xffffffff Task MAIN
Error status: 0
MCU temperature: min 34.1, current 35.2, max 37.0
Supply voltage: min 24.1, current 24.2, max 24.3, under voltage events: 0, over voltage events: 0, power good: yes
12V rail voltage: min 12.0, current 12.0, max 12.2, under voltage events: 0
Driver 0: standstill, reads 1982, writes 14 timeouts 0, SG min/max 0/0
Driver 1: standstill, reads 1982, writes 14 timeouts 0, SG min/max 0/0
Driver 2: standstill, reads 1983, writes 14 timeouts 0, SG min/max 0/0
Driver 3: standstill, reads 1983, writes 14 timeouts 0, SG min/max 0/0
Driver 4: standstill, reads 1983, writes 14 timeouts 0, SG min/max 0/0
Driver 5: standstill, reads 1984, writes 14 timeouts 0, SG min/max 0/0
Date/time: 2020-12-31 20:31:34
Slowest loop: 6.29ms; fastest: 0.14ms
=== Storage ===
Free file entries: 10
=== MainDDARing ===
Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 CDDA state: -1
=== AuxDDARing ===
Bed heaters = -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1, chamberHeaters = -1 -1 -1 -1
Segments left: 0
Movement lock held by null
HTTP* is ready with "M122" in state(s) 0
Telnet is idle in state(s) 0
File is idle in state(s) 0
USB is idle in state(s) 0
Aux is idle in state(s) 0
Queue is idle in state(s) 0
LCD is idle in state(s) 0
SBC is idle in state(s) 0
Daemon* is idle in state(s) 0
Aux2 is idle in state(s) 0
Code queue is empty.
=== Network ===
Slowest loop: 0.66ms; fastest: 0.01ms
HTTP sessions: 0 of 8- Ethernet -
State: disabled
Error counts: 0 0 0 0 0
=== CAN ===
Messages sent 23204, longest wait 1ms for type 6018
=== Linux interface ===
State: 0, failed transfers: 0
Last transfer: 16ms ago
RX/TX seq numbers: 45704/29677
SPI underruns 0, overruns 0
Number of disconnects: 0
Buffer RX/TX: 0/0-0
=== Duet Control Server ===
Duet Control Server v3.1.1
Code buffer space: 4096
Full transfers per second: 33.53
- Ethernet -
@Phaedrux So I managed to get my expension board to actually update to the last version, and none of my 6hc. half is giving me duet3_sbciap_mb6hc.bin canot be find, other half doest update. (I have 3 machines running 6hc + exp)
@dc42 your 3.2 cant be installed on any of my board. tried every way possible and it always fail.
I did a hard reset with bossa using the last firmware and now I have a dead machine. "DSC isnt started". -
Sounds like your raspberry pi is not up and running
@oliof would be hard to do all those update since im working directly on it -_-"
I also connected it to my other board and it work so it is from the board 100%.Most useless comment yet.
Ill mark this one as "solved" for now as obviously it didnt update right, and start one about why I cant update ??
@jrockland I had the same problem therefor I installed 3.1.1 fw package on both, hc6 and on hc3. After this the update package 3.2 did properly updated both boards.
Maybe u need to do this also.
