Duet 2 Wifi V 1.0.4c Blocked
Hello, i am stefano, sorry for my english not correct.
Have this problem have upgrade my duet firmware 3.0 and all ok
upgrade firmware 3.2 and duet remain in connecting
have unmount all and connected my pc, problem pc not see port duet
solution for send firmware and fix problem?
Not 100% sure what the problem is, but see of this helps
https://duet3d.dozuki.com/Wiki/What_to_do_if_your_Duet_won't_respond
https://duet3d.dozuki.com/Wiki/Installing_and_Updating_Firmware#Section_Fallback_procedure_Num_3
If you still have access to DWC. Upload these 3 zip files, one at a time. Don't extract them. Reboot after each.
https://github.com/Duet3D/RepRapFirmware/releases/download/3.0/Duet2and3Firmware-3.0.zip
https://github.com/Duet3D/RepRapFirmware/releases/download/3.2/Duet2and3Firmware-3.2.zip
That will get your firmware and DWC up to date.
https://configtool.reprapfirmware.org/Start
For your config, might be a good idea to run through the configurator tool and generate a fresh set for RRF3.Check your current firmware version with M115.
If you do not have DWC access, you'd need to follow the links from bearer.
not possible comunicate con port usb, pc not see port usb, impossible send code, have change cable usb, have change pc, have test with mac, windows and linux
try more usb cables. some people have had to try 18 different cables.
have, null problem remain
@Phaedrux not possible connect with port usb you solution not solve
@stefano said in Duet 2 Wifi V 1.0.4c Blocked:
Do you know what Windows Device Manager is?
If you do run it and look for entries under "Ports (COM & LPT)" and tell us what, if anything, is there.
@bearer have see all problem not solve
@fcwilt null not see port
Photos of the board?
have solve problem with jtag
