BLT Manual deploy +HomeZ ok ~ Auto HomeZ = no?
For some reason, I can't seem to get my BLT working as expected. I followed the online example for wiring, Config.g et al, but I have something either transposed or wrong. Can someone take a look and see if anything sticks out?
FYI - It seems to be wired up correctly. The probe will not automatically deploy when functioning as a Z end stop/Zzero switch. However - If I manually deploy the probe via my 'deployprobe' macro, it does in fact deploy & if I command the Z to home, it does in fact work as expected. Just not sure where my code is messed up.
Yes...there's cleanup to be done deleting extra comments in the code. Thank you in advance for looking...
;BLT Config 1/1/21
; generated by RepRapFirmware Configuration Tool v3.1.10 on Wed Dec 09 2020 11:04:02 GMT-0500 (Eastern Standard Time); General preferences
M550 P"CR10S6" ; set printer name; Network
M552 S1 ; enable network
M586 P0 S1 ; enable HTTP
M586 P1 S0 ; disable FTP
M569 P0 S0 ; physical drive 0 goes backwards
M92 X80.00 Y80.00 Z400.00 E420.00 ; set steps per mm
M203 X6000.00 Y6000.00 Z1250.00 E1200.00 ; set maximum speeds (mm/min)
M201 X500.00 Y500.00 Z40.00 E250.00 ; set accelerations (mm/s^2)
M906 X1000 Y1000 Z1000 E900 I30 ; set motor currents (mA) and motor idle factor in per cent
M208 X500 Y500 Z900 S0 ; set axis maxima; Endstops
M591 P1 C"e0stop" S1 D0 ; filament monitor connected to E0 endstop S1=On S0=Off P1=simple sensor (high signal when filament present); Z-Probe
M558 P9 C"^zprobe.in" H5 F120 T6000 A10 R0.75 S0.02 ; set Z probe type to bltouch and the dive height + speeds
M950 S0 C"exp.heater3" ; create servo pin 0 for BLTouch on exp.heater3
G31 P500 X-33 Y-1 Z1.438 ; set Z probe trigger value, offset and trigger height
M557 X25:450 Y25:475 S50; IRPROBE M558 P1 C"zprobe.in" H5 F120 T6000 ; set Z probe type to unmodulated and the dive height + speeds
; IRPROBE G31 P500 X-48 Y-10 Z2.55 ; set Z probe trigger value, offset and trigger height
; IRPROBE M557 X25:450 Y25:475 S50 ; define mesh grid; Heaters
M140 H-1 ; disable heated bed (overrides default heater mapping)
M308 S0 P"spi.cs1" Y"rtd-max31865" ; configure sensor 0 as thermocouple via CS pin spi.cs1
M950 H0 C"e1heat" T0 ; create nozzle heater output on e1heat and map it to sensor 0
M307 H0 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit
M143 H0 S290 ; set temperature limit for heater 0 to 290C; Fans
M106 P1 S1 H T45 ; set fan 1 value. Thermostatic control is turned on; Tools
M563 P0 D0 H0 F0 ; define tool 0
T0 ;Start up with tool 0 selected in the console
; homez.g
; called to home the Z axis
G91 ; relative positioning
G90 ; absolute positioning
G1 X63 Y25 F6000 ; go to first probe point
;M98 P"^deployprobe.g"
M401 P1; Lower Z probe (BLTouch)
M402 P1; Retract Probe
;M98 P"^retractprobe.g"
G1 Z5 F100 ; lift Z relative to current position
; homeall.g
; called to home all axes
G1 H1 X-505 Y-505 F1800 ; move quickly to X and Y axis endstops and stop there (first pass)
G1 H2 X5 Y5 F6000 ; go back a few mm
G1 H1 X-505 Y-505 F360 ; move slowly to X and Y axis endstops once more (second pass)
G1 X63 Y25 F6000 ; go to first bed probe point and home Z
G30 ; home Z by probing the bed; Uncomment the following lines to lift Z after probing
;G91 ; relative positioning
;G90 ; absolute positioning
;deployprobe.g
M280 P0 S10 ; deploy BLTouch
;retractprobe.g
M280 P0 S90 ; retract BLTouch
@BDubs said in BLT Manual deploy +HomeZ ok ~ Auto HomeZ = no?:
Sorry but I don't understand what that means.
What do you do to make it work, and what do you do when it doesn't work?
Does sending G28 (homeall.g) work?
If you send G30 does it deploy the pin?
;M98 P"^retractprobe.g"Remove all that deploy retract cruft. It just needs G30.
Can you send M122 and M98 P"config.g" and share the results?
Basically, If tell it to HomeZ (after homing X & Y individually) - it runs the nozzle into the bed.
However...If I deploy the probe pin and then run homeZ, it works as you'd expect. It touches off twice and raises the Z up. It does not retract the pin though...I have to do that manually.
Not running home all until homeZ is good - for obvious reasons.
(More on the other stuff you asked in a few min...)
@Phaedrux said in BLT Manual deploy +HomeZ ok ~ Auto HomeZ = no?:
1/1/2021, 5:45:51 PM M122
RepRapFirmware for Duet 2 WiFi/Ethernet version 3.1.1 running on Duet WiFi 1.02 or later
Board ID: 08DGM-9568A-F23SD-6J1F2-3S86Q-KBN7D
Used output buffers: 3 of 24 (12 max)
Static ram: 27980
Dynamic ram: 93708 of which 44 recycled
Exception stack ram used: 496
Never used ram: 8844
Tasks: NETWORK(blocked,384) HEAT(blocked,1224) MAIN(running,1848) IDLE(ready,80)
Owned mutexes: WiFi(NETWORK)
Last reset 00:01:31 ago, cause: software
Last software reset time unknown, reason: User, spinning module GCodes, available RAM 9076 bytes (slot 0)
Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0441f000 BFAR 0xe000ed38 SP 0xffffffff Task MAIN
Error status: 0
MCU temperature: min 30.6, current 32.1, max 32.2
Supply voltage: min 24.0, current 24.1, max 24.4, under voltage events: 0, over voltage events: 0, power good: yes
Driver 0: standstill, SG min/max 0/289
Driver 1: standstill, SG min/max 214/383
Driver 2: standstill, SG min/max 0/257
Date/time: 2021-01-01 17:45:47
Cache data hit count 151460176
Slowest loop: 6.25ms; fastest: 0.13ms
=== Storage ===
Free file entries: 10
SD card longest read time 1.0ms, write time 0.0ms, max retries 0
Hiccups: 0(0), FreeDm: 169, MinFreeDm: 167, MaxWait: 24574ms
=== MainDDARing ===
Scheduled moves: 17, completed moves: 17, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 CDDA state: -1
=== AuxDDARing ===
Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 CDDA state: -1
Bed heaters = -1 -1 -1 -1, chamberHeaters = -1 -1 -1 -1
Heater 0 is on, I-accum = 0.0
Segments left: 0
Movement lock held by null
HTTP is idle in state(s) 0
Telnet is idle in state(s) 0
File is idle in state(s) 0
USB is idle in state(s) 0
Aux is idle in state(s) 0
Trigger is idle in state(s) 0
Queue is idle in state(s) 0
Daemon is idle in state(s) 0
Code queue is empty.
=== Network ===
Slowest loop: 15.72ms; fastest: 0.00ms
Responder states: HTTP(2) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0), 0 sessions
HTTP sessions: 1 of 8- WiFi -
Network state is active
WiFi firmware version 1.23
WiFi MAC address 2c:3a:e8:0b:1b:7b
WiFi Vcc 3.40, reset reason Unknown
WiFi flash size 4194304, free heap 25672
WiFi IP address 192.168.3.105
WiFi signal strength -55dBm, reconnections 0, sleep mode modem
Socket states: 4 0 0 0 0 0 0 0
=== Filament sensors ===
Extruder 0 sensor: ok
FYI - M98 P"config.g" does nothing when I enter it in & execute
- WiFi -
Do I need another M307 command for the BLT?
RE: https://forum.duet3d.com/topic/20344/probe-points-with-bltouch/2
M307 H3 A-1 C-1 D-1 ; Disable heater on PWM channel for BLTouch
If you send M401 and M402 does it deploy and retract the pin?
No, that's for RRF2.
That's a negative on all 3 counts.
However, If I click on my deployprobe macro, it deploys. Clicking on retractprobe macro, it retracts.
Where are those macros? They should be in the system folder
@Phaedrux Wow dude...You rock! That was it!
I thought I uploaded them to the System folder...not sure where they got loaded to. The Macro folder?
HUGE THANK YOU!
