Duet 3 Mini 5+ : Initial announcement
Is there a board DXF available for creating a mount?
@jchodakowski said in Duet 3 Mini 5+ : Initial announcement:
the dimensions should suffice
@CaLviNx thanks!
I ordered my boards from overseas now. I know, that does not make any sense, but E3D are to slow for me at the moment.
Btw: The first holder for the new kid on the block:
https://www.thingiverse.com/thing:4699948
Not fancy but it should do it's job.Cheers, Chriss
Speaking of which... any news on stocks ? (please including the expansion card...what's the name for it 2+ ?)
It would appear the mini-5+ has the same hole spacing/foot print as the Duet-2 as my mini-5+ fitted on the same mount as the Duet-2
@CaLviNx yes if you check drawings same placement
I got my board 2 minutes ago.
It traveled from the USA to good old Germany faster than the guys in the UK made it available on there stock. Strange world.... -
@oc_geek Not sure why e3d did not list their stocks before the Christmas break, hopefully they will soon.
The mini 2+ will go into production next week.
Stocks of the mini 5+ will start to go out to our other resellers next week. We have not got enough from this production run for all of them
@CaLviNx said in Duet 3 Mini 5+ : Initial announcement:
I'm sorry but the drawing do not seams to be accurate. I designed a holder based on the drawing and the board do not fit.
So I measured a hole distance :
Long site: 115mm
Sort site: 92mmThe drawing says:
Long site: 115mm
Sort site: 96mmI'm sorry, but the 96 must be wrong. I measured 92mm, and the printed 96mm part is to wide that the board to not fit.
Cheers, Chriss
@Chriss check the drawing again the 96 is from the edge of the board and the holes are 4 in from that edge making 92 as per your measurements
Doug
When using an acrylic or other material to install the electronics, a PDF(or other) with accurate size that can be used as a template to print and mark the holes is of much help.
Wow.. you are right....
This is so hard... the drawing shows the distance from hole to hole on the long site. And the distance from the board "west site" to the hole center at the "east site". Wow.... they fooled me... again.
Overall dimensions and mounting hole positions on the Duet 3 Mini are the same as for the Duet WiFi/Ethernet. However, the motor connectors are on the opposite side of the board compared to Duet 2.
@T3P3Tony Do you confirm the official name of the expansion is going to be "Mini 2+" cse noone of the resellers know about its existance... thanks
@Chriss said in Duet 3 Mini 5+ : Initial announcement:
measure twice, cut once.............
@oc_geek yes it is. and we have not got any to send to the resellers, and no pictures to setup the product listing yet so thats why they are not setup for it yet.
Will you be listing it on your site. I perfer to buy from yourselfs ... E3D already get to much money out of me ...LOL
@lodger TBC at this point when we reopen retail sales.
First one in Canada?!
My Ender 3 Pro will be happy! The last of my FDM printers not in Duet!
