New heater tuning algorithm
@dc42 said in New heater tuning algorithm:
It will cycle for at most 30 cycles in stage 3. But the algorithm used in RRF 3.2beta4.1 is often quicker.
If it is now cooling down again, it has finished and you should see a result in the console. Send M303 without parameters to check.
My heating table heats for about 3 minutes. from 35 to 40celsius. But cooling is 43 minutes on average due to the insulation and volume. In total each cycle taking 55 minutes on average. If 30 cycles, it is mean it should take more than 28 hours to complete.
@sozkan
By the way, this is the preview of the incomplete test of 4.0;
So I should go for 4.1 then immediately and share the results.
Thanks for the help. -
If it takes 43 minutes to cool by 5C but only 3 minutes to heat up, perhaps you have too much insulation? With most print surfaces, you need the bed to cool down before you can release the print.
Why are you using such a low target temperature (40C)? All the materials I print with need 60C or more indicated temperature.
@dc42 you right but, It is just fresh to build a handcrafted heated bed with high voltage. I am afraid to run a higher temperature for safety concerns. therefore, I am aiming to test it first at low temperatures. But I cannot test before it runs smoothly, later I can PID for normal operating temperatures again.
@dc42 I was testing Autotuning with firmware latest 4.1 version, It took 7 hours, but still did not complete. The thing I have faced again, the motor cracking sound with this version too.
So I revert back to firmware 3.2.3b that works smoothly on the motor axis. But the temperature tuning things that I have seen, not for my machine type. I am trying to figure out the M301, M303, M307 M950 parameters to set up manually with the values I find. If you could help me with it I appreciated.
By the way, these parameters not valid in this firmware, wich was Firmware version 3.1.1 AutoTuning found valuesM307 H0 A233.3 C508.3 D1.3 S1.00 V24.3 B0
I am beta4.1 on a Duet 3 running in standalone mode.
I have retuned my bed using the new algorithm.
Whenever I heat up the bed to print, it faults with heating slower than expected.
Here is my M307M307 H0 R1.468 C146.948:146.948 D2.43 S1.00 V27.0 B0
I have a 500mm bed (10mm aluminium) running a 240v 2kw heater.
Anything else I can provide?
It takes the full 30 cycles to tune and fails. -
I've rolled back to beta 2 to be able to tune the bed with the old algorithm and this was the result.
M307 H0 A63.2 C50.0 D1.9 S1.00 V27.0
This post is deleted! -
Extra Long Hot ends ( Like Dyze Typhoon or pulsar ) blocks with multiple sensors heater on the same block need to be calibrated together. Is there any possibility to add in the new algorithm?
Good morning. I've jut finished tuning the Heater 1 at 230°C with M303 H1 S230. This is my first print after using the new calibration algorithm....I'm experiencing a lot of oscillation around the set point as you can see:
Even arouns 235°C (first layer) and around 230°C (second layer) as well.....I made the autotuning with tha fan on for the first 2 stages and turned it off for the third stage. Oscillationa are sometimes more than 1°C above and belows
Never seen oscillations like those with the older algorithm
As you can see the issue goes on for all the print:
I've been able to tune only the Heater 1 because the tuning for the bed looked to go in loop...After 40 minutes I've turned it off...as you can see the graph for the bed is very stable
What's happening?
Uh, I was forgetting....Beta 4.1
@the_dragonlord said in New heater tuning algorithm:
The tuning process will automatically control the fan. It seems you confused it by manually changing fan speed. Please tune again and don't touch the fan.
The new tuning algorithm takes up to 30 heat-cool-cycles and can take very long on large heated beds. So what you describe sounds pretty normal in the first place.
@wilriker said in New heater tuning algorithm:
the first attempt I've made the tuning didn't control the fan at all neither in the beginning neither in the end... maybe there's an option to control it?
@the_dragonlord you need to tune as a tool rather than a heater.
So M303 T0 S200 -
@jay_s_uk said in New heater tuning algorithm:
So M303 T0 S200uh ok ok... thanks! What's the tool number for the bed?
@the_dragonlord for the bed you tune as normal as a heater
excellent, thanks!
I'm a little confused on the part cooling fan aspects of this new tuning cycle.
I ran through it once and see "Auto tune starting phase 3, fan off"
I tried running again with the fan manually turned on, but that same message is shown. I thought that the cycle automatically turned on the part cooling fan, but it doesn't seem to do this for me.
@CCS86 you need to tune as a tool not as a heater to get the fans activated.
M303 T0 S200 and so on.
Phase 3 is first done with the fan off and then with the fan on. -
Phase 3 is first done with the fan off and then with the fan on.Sweet, thank you much!
You are the first person to report that with the new algorithm.
My suggestions are:
- Tune the heater again, but as a tool instead of as a heater. This will take account of the effect of the cooling fan.
- Make sure that the system ios using the M307 parameters that resulted form tuning.
- If you still get oscillations after doing that, increase the dead time (M307 D parameter). Try an increase of 30%, and increase further of needed to stop the oscillations.
