Duet 3 Mini 5+ : Initial announcement
@CaLviNx forgive me i did not know there was a data sheet with specs as the board is still in testing and things can change before the release
@dc42 said in Duet 3 Mini 5+ : Initial announcement:
The PCB is not the same between wifi and ethernet like for Duet2 ?
I love the possibility to swap from wifi to Ethernet by swap the wifi module to Ethernet module on Duet 2, it's cheaper than buy an another Duet. -
@pipersw no its not the same
for 5 steppers motors at 1.4A, the TMC2209 need active cooling with the board mounted vertically ?
@pipersw said in Duet 3 Mini 5+ : Initial announcement:
Probably wise to use a fan, but my guess is that you wouldn't get any overheat warnings even without fan cooling.
Great that sd-slot doesn´t sit under the ethernet any more, so easier to get the card out
@dc42 Thermal via are available on the bottom side under the TMC, for allow to add a heatsink to increase the thermal area ?
Like it :
@pipersw
thats a clone of the duet 3. hmm
most of the time the clones cheap out on the copper in the pcb, which means the pcb can not act as a heatsink like its supposed to. that is why you see heatsinks on the clone boards. -
Just to clarify, we expect to have almost 300 pre-production boards early in December, so there should be enough for those who want to try them.
Any news about how early in December? It is getting later and later ...
Cheers, Chriss
They are in production right now! We want to give our resellers a chance to get them into stock as well. We have not made a decision if we will re-open the website for ordering these at the same time.
@T3P3Tony
No worries here... I do not care whether I order them at you or at a reseller. But I want one of them. I have the frame here ready to fit the board in.
And I'm sure that I'm not the only one in this situation. So I do not want to end where all the PSP buyers ended. -
@T3P3Tony Which reseller in Germany will receive a stock? I hope it will happen before Christmas
I wait for stock in E3donline. I hope in next week
main question - what is steprate of DUET3 mini and DUET3 ?
Were looking and didn't found.Second question regarding upload speeds.
Got DUET2Wifi and upload speed is not the best, specially it's long process when you upload big files.
Often my files are over 150mb.I was looking for alternative for 2.4Ghz modules and found RTL8720DN which is 802.11 a/b/g/n.
Will be possible to adapt to DUET2 or duet3 mini such modules. -
if you want upload speed go for the ethernet one.
also if you connect a raspberry pi your connection options become far greater. you can use any wifi adapter that works with the pi (or the pi build in one) and the upload speed depends on what the pi can handle (far higher than the duet 3 in standalone mode)
you can connect a pi to a duet 2, see here. https://forum.duet3d.com/topic/17203/duet-2-ethernet-and-sbc/272
you gain the same benefits. -
@bartwaw said in Duet 3 Mini 5+ : Initial announcement:
If you compare the Ethernet version of the Mini with the 6HC the key differences are processor and stepper motors. See the Documentation pages here:
https://duet3d.dozuki.com/Wiki/Duet_3_Mini_5plus_Hardware_overview
https://duet3d.dozuki.com/Wiki/Duet_3_Mainboard_6HC_Hardware_OverviewOn the 6HC you get 6 stepper drivers capable of up to 6.3A peak, on the Mini 5+ you get 5 drivers capable of 2A peak.
The processor of the 6HC is more powerful so will allow for greater number of CANFD expansion boards, the mini 5+ processor will allow for fewer (maximum not yet tested).
Its not just the module that is the limitation but also the fact that a microcontroller is handling this rather than a CPU. As @Veti says the Ethernet is a bit quicker. and the SBC is much quicker.
Some of the step rates can be found here https://docs.google.com/spreadsheets/d/1AWA1wLbOaYzxzdQa5LRZvn9rgEk2BuluHy6-_OnD6FY
I haven't measured the step rate of the Duet 3 Mini yet, but it should be similar to or slightly faster than the Duet WiFi/Ethernet.
Did I understand the specs correctly, I can't have both a BLTouch, filament sensor and PanelDuo attached?
@Reine said in Duet 3 Mini 5+ : Initial announcement:
where did you get that idea from? paneldue connects to io0, whereas bltouch needs pwm ports which are io3 or io6
I have seen all the resellers in EU, and I don't see the board announced or in stock.
It will be available in January ?
