Newbie: New Install on Ender 5 Plus---Willing to PAY$$$
Also, Im using Creality Slicer. What is a good nonbranded software? Like top-notch. And how do I earn 1 reputation? This 60 sec post thing is annoying
Give PrusaSlicer a try. Probably your best bet. You will have to do a bit of setup. I think it has a profile for the Ender 3 which should get you 99% of the way there.
@Phaedrux I tried Ultimaker last night but it seemed too complicated
prusaslicer is easier, it has far less options
What speed to print at? Fast (0.2mm), Normal (0.15mm), or HQ (0.1mm)?
yes print cooler.
also post your config.g
@shatty said in Newbie: New Install on Ender 5 Plus---Willing to PAY$$:
Fast (0.2mm)
i use this for most prints. and about 60mm/s on my ender 3.
; generated by RepRapFirmware Configuration Tool v3.1.4 on Sun Nov 15 2020 03:22:47 GMT-0500 (Eastern Standard Time); General preferences
M550 P"E5Plus" ; set printer name; Network
M551 P"xxxxx" ; set password
M552 S1 ; enable network
M586 P0 S1 ; enable HTTP
M586 P1 S0 ; disable FTP
M569 P1 S0 ; physical drive 1 goes forwards
M569 P2 S1 ; physical drive 2 goes backwards
M92 X80.00 Y80.00 Z800.00 E130 ; set steps per mm
M566 X1200.00 Y1200.00 Z60.00 E300.00 ; set maximum instantaneous speed changes (mm/min)
M203 X9000.00 Y9000.00 Z1200.00 E6000.00 ; set maximum speeds (mm/min)
M201 X500.00 Y500.00 Z100.00 E5000.00 ; set accelerations (mm/s^2)
M906 X800 Y800 Z1400 E1000 I50 ; set motor currents (mA) and motor idle factor in per cent
M208 X350 Y350 Z400 S0 ; set axis maxima; Endstops
M574 Z1 S2 ; configure Z-probe endstop for low end on Z; Z-Probe
M950 S0 C"exp.heater3" ; create servo pin 0 for BLTouch
M558 P9 C"^zprobe.in" H5 F600 T6000 ; set Z probe type to bltouch and the dive height + speeds
G31 P500 X16.3 Y14 Z2.43 ; set Z probe trigger value, offset and trigger height
M557 X15:190 Y15:190 S20 ; define mesh grid; Heaters
M308 S0 P"bedtemp" Y"thermistor" T100000 B4092 ; configure sensor 0 as thermistor on pin bedtemp
M307 H0 A101.7 C607.1 D2.6 S1.00 V24.3 B0 ; enable bang-bang mode for the bed heater and set PWM limit
M143 H0 S110 ; set temperature limit for heater 0 to 110C
M308 S1 P"e0temp" Y"thermistor" T100000 B4092 ; configure sensor 1 as thermistor on pin e0temp
M307 H1 A268.5 C102.1 D3.1 S1.00 V24.2 B0 ; disable bang-bang mode for heater and set PWM limit
M143 H1 S280 ; 280 deg max on hot end; Fans
M106 P0 S1 H1 ; set fan 0 value. Thermostatic control is turned off
M575 P1 S1 B57600 ; enable support for PanelDue -
is the thermistor the original thermistor of the ender 5?
if yes change both M308 to T98801 B4185
@Veti yes.
@Veti said in Newbie: New Install on Ender 5 Plus---Willing to PAY$$:
T98801 B4185
Do i have to auto tune again?
I'm printing on my E5+ right now. Duet 2 Wifi, running perfectly. Send me your config G and I will look at it.
@RyanP I posted above
Temps are good. I used my infrared thermo.
Bear in mind you are running Firmware 3 where as I am not. But here is your gcode with the bolded sections changed. Feel free to try that.
Configuration file for Duet WiFi (firmware version 3)
M566 X600 Y600 Z60.00 E3000.00 ; set maximum instantaneous speed changes (mm/min)
M201 X1500.00 Y1500.00 Z100.00 E5000.00 ; set accelerations (mm/s^2)
M204 P600 T1500 ;set print and travel accellerations
M906 X800 Y800 Z800 E800 I50 ; set motor currents (mA) and motor idle factor in per cent
M208 X0 Y0 Z***-1*** S1 ; set axis minima
M558 P9 C"^zprobe.in" H5 F60 T6000 ; set Z probe type to bltouch and the dive height + speeds
@RyanP said in Newbie: New Install on Ender 5 Plus---Willing to PAY$$:
Do you have your Z motors in series? Connected to both Z connectors?
No, they are separate with one being run off E1.
This allows me to run a G32 command to do a left to right adjustment during my bed compensation macro.
@RyanP
Can you send me your filament files? -
From where, my slicer?
