Newbie: New Install on Ender 5 Plus---Willing to PAY$$$
@Veti yes.
@Veti said in Newbie: New Install on Ender 5 Plus---Willing to PAY$$:
T98801 B4185
Do i have to auto tune again?
I'm printing on my E5+ right now. Duet 2 Wifi, running perfectly. Send me your config G and I will look at it.
@RyanP I posted above
Temps are good. I used my infrared thermo.
Bear in mind you are running Firmware 3 where as I am not. But here is your gcode with the bolded sections changed. Feel free to try that.
Configuration file for Duet WiFi (firmware version 3)
; generated by RepRapFirmware Configuration Tool v3.1.4 on Sun Nov 15 2020 03:22:47 GMT-0500 (Eastern Standard Time); General preferences
M550 P"E5Plus" ; set printer name; Network
M551 P"xxxxx" ; set password
M552 S1 ; enable network
M586 P0 S1 ; enable HTTP
M586 P1 S0 ; disable FTP
M569 P1 S0 ; physical drive 1 goes forwards
M569 P2 S1 ; physical drive 2 goes backwards
M92 X80.00 Y80.00 Z800.00 E130 ; set steps per mm
M566 X600 Y600 Z60.00 E3000.00 ; set maximum instantaneous speed changes (mm/min)
M203 X9000.00 Y9000.00 Z1200.00 E6000.00 ; set maximum speeds (mm/min)
M201 X1500.00 Y1500.00 Z100.00 E5000.00 ; set accelerations (mm/s^2)
M204 P600 T1500 ;set print and travel accellerations
M906 X800 Y800 Z800 E800 I50 ; set motor currents (mA) and motor idle factor in per cent
M208 X0 Y0 Z***-1*** S1 ; set axis minima
M208 X350 Y350 Z400 S0 ; set axis maxima; Endstops
M574 Z1 S2 ; configure Z-probe endstop for low end on Z; Z-Probe
M950 S0 C"exp.heater3" ; create servo pin 0 for BLTouch
M558 P9 C"^zprobe.in" H5 F60 T6000 ; set Z probe type to bltouch and the dive height + speeds
G31 P500 X16.3 Y14 Z2.43 ; set Z probe trigger value, offset and trigger height
M557 X15:190 Y15:190 S20 ; define mesh grid; Heaters
M308 S0 P"bedtemp" Y"thermistor" T100000 B4092 ; configure sensor 0 as thermistor on pin bedtemp
M307 H0 A101.7 C607.1 D2.6 S1.00 V24.3 B0 ; enable bang-bang mode for the bed heater and set PWM limit
M143 H0 S110 ; set temperature limit for heater 0 to 110C
M308 S1 P"e0temp" Y"thermistor" T100000 B4092 ; configure sensor 1 as thermistor on pin e0temp
M307 H1 A268.5 C102.1 D3.1 S1.00 V24.2 B0 ; disable bang-bang mode for heater and set PWM limit
M143 H1 S280 ; 280 deg max on hot end; Fans
M106 P0 S1 H1 ; set fan 0 value. Thermostatic control is turned off
M575 P1 S1 B57600 ; enable support for PanelDue -
@RyanP said in Newbie: New Install on Ender 5 Plus---Willing to PAY$$:
Do you have your Z motors in series? Connected to both Z connectors?
No, they are separate with one being run off E1.
This allows me to run a G32 command to do a left to right adjustment during my bed compensation macro.
@RyanP
Can you send me your filament files? -
From where, my slicer?
@shatty said in Newbie: New Install on Ender 5 Plus---Willing to PAY$$:
no
@RyanP What are you using for a slicer? I thought they are universal across all slicers. Im using Creality's
2nd print at 200c. Little better. What should I do next? Drop it more? Im not going to be using PLA. I am just using the sample that came with the printer. I have black PETG. Should I put that in and continue from there?
that is already looking good. maybe a bit overextrusion or it could be bad quality filament.
try reducing the flow by 10%petg printing is a bit more difficult compared to pla. its not as forgiving.
I compared it to the first print and it actually looks alot better. The layers are more uniformed and color also. I think have it set at 135 for extrusion. I will drop it down to 130.
is that your esteps or percent of flow?
That is esteps
pla does not like to be overextruded, but underextrusion is ok.
so try 125 if 130 is the default for your extruder.
PETG @ 230 C. Its the best print yet!. There was a little sting inside the cabin. Thats it! Maybe drop it 5 deg?
If u see stuff on the side of the hull, thats cat hair. The cat loves going near the stupid printer
