Do I complete the bed mesh before/after M671in the "bed" file?
@fcwilt I understand, I'll order some endstops for the top of the z axis. What would be the Gcode commands for this?
@mmartin said in Do I complete the bed mesh before/after M671in the "bed" file?:
Well for my printer with three Z steppers I have this which specifies which outputs are being used for the Z steppers
M584 X0 Y1:2 Z5:6:7 E3;
Then I have this which specifies which inputs are used for the Z end stop sensors and the other bits of information needed
M574 Z1 S1 P"!duex.e2stop + !duex.e3stop + !duex.e4stop" ; configure active-high endstop for low end
Once you have that then simply homing Z would take care of moving the gantry toward the end stop sensors and adjusting the Z steppers as needed so that both end stop sensors had been triggered at the same time.
The commands would be typical homing commands. The following assumes you are homing to Z min rather than Z max.
G91 ; relative moves G1 H1 Z-999 F600 ; move down "fast" until the end stop sensors are triggered G1 Z20 ; move up so the end stop sensors are no longer triggered G1 H1 Z-999 F150 ; move down "slow" until the end stop sensors are triggered
If I can find my camera I will make a short video showing the "leveling" in action.
@fcwilt Thanks!
Here is a very quick and dirty video showing the "coarse" bed leveling using the three Z axis end stop sensors followed by the "fine" bed leveling using the Z probe and the Auto Bed Leveling feature.
Before doing video this I turned off the printer and carefully adjusted the Z axes positions to put the bed grossly out of level.
@fcwilt Your video is marked private.
@Phaedrux said in Do I complete the bed mesh before/after M671in the "bed" file?:
I don't use YouTube that much.
I was thinking that when I used the "sharable link" that ignored the private setting.
I think the other option is unlisted. I haven't used it myself though.
@fcwilt Video works now. Beautifully done.
I get a kick out of watching it level the bed using the end stop sensors when it is way out of level, like I set it up to be.
@fcwilt Do you have a write up on your build anywhere? A BOM? It's tempting me to redo my DBot once again. I'm fed up with lead screws.
I don't have anything written up.
I could create a BOM based on the model.
I could get you a license for Moment of Inspiration which is the CAD program I created the model with.
I can save the model using a number of other file formats - of which I know little.
You may recall that this printer started life as a DBot so many of the pieces of extrusion have been reused - I think.
While I have read that belt stretch might be a problem when belts are used for the Z axis, and I may have to deal with that, I really like the results of using the belts. It is MUCH quieter than when I was using 2mm pitch lead screws.
Let me know what I can do.
@fcwilt said in Do I complete the bed mesh before/after M671in the "bed" file?:
How would that work?
Can't go wrong with STEP.
Don't go out of your way just for me. I was mostly just curious to see what you've done.
Long story short - someone owes me a favor which I could "redeem".
As an experiment I load my project file, deleted all the steppers, pulleys, rails, etc and exported the rest of the model as a STP file.
See attached. I couldn't upload the STP file as it was too large. A ZIP file was NOT too large but wouldn't upload with a ZIP extension. Don't know why.
Zip files are generally prohibited because their contents could be anything, so for security reasons they aren't allowed, but I think even that thinking is a bit outdated. I'll see about getting zip files added to the forum.
As you found, changing the extension is enough to fool the system.
Sorry for violating the rules. But since the system doesn't actually seem to care if it is a ZIP file I think the security is a bit weak.
If you get a chance to try and load that STP file into your CAD program I would be interested to hear the results.
Exactly my point.
Will try loading it up in fusion.
@fcwilt Thanks the STEP files works. I will have to inspect it closer a little later.
That's good to know.
At least I don't have to export each individual object - wasn't looking forward to that.
If you want the complete model with all the bits I deleted just let me know.
Yes that would have been prohibitive. All of the individual bodies have been retained, so it should be fairly easy to work with.
I'm not sure I would go through with a full markforged conversion, but the Z axis definitely interests me.
