pydsfapi [v3.2.0] - Official Python Client Library for DSF
@achrn said in pydsfapi [v3.1.1] - Official Python Client Library for DSF:
@wilriker
With theself.socket.recv(32 * 1024)
changed toself.socket.recv(64 * 1024)
and a routine interrogating the machine model and doing some occasionalcommand_connection.perform_simple_code('M573 P0')
at the same time, I've had some prints stop part-way (but neglected to record the error in detail - at the time I thought I knew what had done it so thought I didn't need to pay attention to what it was saying).If it happens again please record the error and report here.
This may be coincidence, though it's the only time the printer has stopped mid-print, but it may be that putting that receive up to 64 kB upsets something (possibly just takes too long).
I don't think so. This is all going through a local socket connection, i.e. speeds around RAM speed - 64 KiB will be transferred in under 1ms.
@ofliduet said in pydsfapi [v3.1.1] - Official Python Client Library for DSF:
Different question: Is it possible to use the API to access the socket from a different host? It looks so close to me but no catch.
Yes, you can forward the socket via SSH
ssh -o StreamLocalBindUnlink=yes -L<localpath>:/run/dsf/dcs.sock <hostname>
Make sure that the user you are using to connect via SSH has read-write permissions on
/run/dsf/dcs.sock
I'm trying to use the api with a Duet3 board with firmware 3.1.1 (stable) and the initial connect for the subscription gives me the confirmation immediately followed by a complete machine model:
send: {"mode": "Subscribe", "version": 8, "SubscriptionMode": "Patch", "Filter": ""} recv: {"success":true}{"boards":[{"bootloaderFileName":null,"canAddress":0,"firmwareDate":"2020-05-19b2","firmwareFileName":"Duet3Firmware_MB6HC.bin","firmwareName":"RepRapFirmware for Duet 3 MB6HC","firmwareVersion":"3.1.1"
causing a parser error
File "/home/pi/src/OctoPrint/venv3/lib/python3.7/site-packages/pydsfapi/pydsfapi.py", line 446, in connect return super().connect(sim, socket_path) File "/home/pi/src/OctoPrint/venv3/lib/python3.7/site-packages/pydsfapi/pydsfapi.py", line 238, in connect response = self.receive_response() File "/home/pi/src/OctoPrint/venv3/lib/python3.7/site-packages/pydsfapi/pydsfapi.py", line 280, in receive_response return json.loads(json_string, object_hook=responses.decode_response) File "/usr/lib/python3.7/json/__init__.py", line 361, in loads return cls(**kw).decode(s) File "/usr/lib/python3.7/json/decoder.py", line 340, in decode raise JSONDecodeError("Extra data", s, end)
Is that a known problem?
No it is not. It looks like DCS was sending only a partial response out of unknown reason. Also it did send this unsolicited as you mentioned in a later post. AFAIK it should not do this.
@chrishamm Can you please comment on that part?I'm also wondering about whether the API is threadsafe. A complete worked example with a thread running in the background periodically updating a complete machine model with patches would be extremely helpful.
pydsfapi
is currently not thread-safe. For the time being you either need to synchronize on the connection yourself or create one connection per thread. -
Line 284 of pydsfapi/pydsfapi.py limits the json response to 32kB:
json_string = self.socket.recv(32 * 1024).decode('utf8')
Thanks again for reporting this. I fixed it and will release a new version shortly.
Release 3.1.2
This is a bugfix release to solve the issue with responses from DCS being capped at 32 KiB.
It can be found as usual on GitHub Releases page.
@wilriker said in pydsfapi [v3.1.1] - Official Python Client Library for DSF:
@chrishamm Can you please comment on that part?My fault. I was confused. This is as intended from DCS
and there is actually still a bug inpydsfapi
3.1.2.EDIT: I revise the latter part. AFAICT it should be fixed now.
@wilriker Thanks. I've installed and used the new version, though actually my first print job turns out to peak at a 31.9kB machine model, so would have been OK previously (d'oh).
However, I do seem to have provoked the error @ofliduet had:
Traceback (most recent call last): File "./mm_time.py", line 12, in <module> subscribe_connection.connect() File "/usr/local/lib/python3.7/dist-packages/pydsfapi/pydsfapi.py", line 447, in connect return super().connect(sim, socket_path) File "/usr/local/lib/python3.7/dist-packages/pydsfapi/pydsfapi.py", line 238, in connect response = self.receive_response() File "/usr/local/lib/python3.7/dist-packages/pydsfapi/pydsfapi.py", line 280, in receive_response return json.loads(json_string, object_hook=responses.decode_response) File "/usr/lib/python3.7/json/__init__.py", line 361, in loads return cls(**kw).decode(s) File "/usr/lib/python3.7/json/decoder.py", line 340, in decode raise JSONDecodeError("Extra data", s, end) json.decoder.JSONDecodeError: Extra data: line 1 column 17 (char 16)
This was from a really simple:
#!/usr/bin/python3 # subscribe to the machine model and report the timings of most recent print job import json import time from pydsfapi import pydsfapi from pydsfapi.initmessages.clientinitmessages import SubscriptionMode # establish the connection subscribe_connection = pydsfapi.SubscribeConnection(SubscriptionMode.PATCH, debug=False) subscribe_connection.connect() try: # Get the complete model once machine_model = subscribe_connection.get_machine_model() [[continues, just prints out some machine model values, omitted for brevity]]
I note that this error is occurring at line 12, before I ask for a copy of the machine model, as @ofliduet reported.
If I do literally nothing but run the function again (i.e. press [up-cursor], press [Enter]) it runs fine. About one run in twenty errors, with no discernible pattern. I've never had it error twice in succession, I have had it error, then run OK twice, then error on the next (I think that's the most frequent repeat I've seen).
@achrn Thanks for re-reporting. I know then what the problem is. I just could not reproduce it on my setup.
I already have a solution that I will provide tomorrow. But I need to find a way to make it more efficient. That will be part of the 3.2 release.
Release 3.1.3
This is another bugfix release to solve the problem if message in (primarily in Subscription mode) are received faster than they are processed it would lead to JSON parser errors.
Thanks again to @achrn for reporting.
@wilriker Has the type of the MachineModel type that
subscribe_conenction.get_machine_model()
returns changed?My scripts that previously did that then e.g.
for h in machine_model['heat']['heaters']
are suddenly reportingTypeError: 'MachineModel' object is not subscriptable
.(This might have been a change in 3.1.2 - I had thought I installed 3.1.2, but when I installed 3.1.3 it suggested it was replacing 3.1.1).
@achrn I have noticed something similar but TBH I have no idea what is going on here. Nothing has changed in regards to this but still it is no longer working. I have to investigate that.
Which python version are you using?
@wilriker Wow that was quick!
It occurred to me I could check for myself when the change happens - it does change between 3.1.1 and 3.1.2 and if I roll back to 3.1.1 my scripts start working again - MachineModel is subscriptable in 3.1.1, but not in 3.1.2 and 3.1.3.
Having looked at the diff on GitHub 3.1.1 - 3.1.2 I can't see why the changes would change what gets returned (apart from let it be longer). As far as I can see teh changed
def receive_json(self):
was returning a str and is still returning a str.My Python is 3.7.3
@achrn Just as an idea, have you removed all
.pyc
files as well as__pycache__
directories? Just to make sure nothing is stuck in half-way pre-compiled voodoo black-magic bogus. -
@wilriker I ahdan't, but I was doing
pip3 uninstall pydsfapi
before each new install.I've tried again - unistall, hunt for any pydsfapi traces and obliterate them (including fo ~/.local/lib/python3.7 where I found a few). I'm not sure I want to remove all
__pycache__
and*.pyc
- plus it would take a while to hunt them all down. There are no*dsf*.pyc
orpydsfapi*
(except the .gz I'm installing from) files anywhere on the machine before I do apip3 install
After that, still the same behaviour - MachineModel object is not subscriptable.
I have a relatively simple workaround, because if I don't transfer a full model, my first 'patch' gets a whole model. So I can easily change my scripts to start with an empty dict, and use
get_machine_model_patch()
to obtain a 'patch' containing the whole model (as a nice predictable string). Then I apply that patch to the empty dict, and that gives me a dict of the machine model, and the script proceeds from that point fine. -
@achrn I have a vague theory of what might be the cause for this. But I can probably only test next week.
@wilriker No problem - as I say, I've got an easy workaround, so there's not a rush on my account. Thanks.
@achrn said in pydsfapi [v3.1.3] - Official Python Client Library for DSF:
.I see the same problem with 3.1.1. It works for me (both versions) if I use
for h in machine_model.heat['heaters']
i.e. trying to access
heat
as a member rather than adict
key. -
@wilriker said in pydsfapi [v3.1.3] - Official Python Client Library for DSF:
Yes, that works for me too in 3.1.3.
However, it breaks my patch-applying routine, so I think it's more work for me than my other workaround (at least, for my existing scripts).
@achrn I don't know why this works for you in 3.1.1 (as it does not for me) but I found a simple way of getting it to work. I would though hold that off for version 3.2.0 because you said you have a working alternative solution.
Yes, no problem for me - I have what I wanted working now, so don't rush on my account.
