pydsfapi [v3.2.0] - Official Python Client Library for DSF
@wilriker Thanks. I will try it directly tomorrow and give feedback to you. Just for others who are searching: these changes are still on the dev Branch.
@wilriker Ok I tried. I took the latest commit on the dev branch (Hash: 7b7c9291aaa1e77bd570c2503f981a73410a0f32)
I changed:
cmd_conn.connect('/var/run/dsf/dcs.sock')
I ran the example file with python 3.7 and the RPI and sudo rights (dcs.sock requires it)
and I got the following error
File "/home/shares/pi/HandwritingRoboter/src/DSF-APIs/pydsfapi/pydsfapi.py", line 234, in connect server_init_message.EXPECTED_SERVER_VERSION, server_init_message.version)) AttributeError: 'ServerInitMessage' object has no attribute 'EXPECTED_SERVER_VERSION'
Probably you have an Idea what that could be?
@JBisc Yeah, the reason was me refactoring a name right before committing but after testing.
But there is another problem why it would not have happened for me anyway: the version on the
dev
branch requires DSF 2.1.0 fromunstable
repo.EDIT: I pushed another change fixing this bug right before I posted here. So once you upgraded to DSF 2.1.0 the latest commit on
dev
should work. -
Release 2.1.0
I present to you the first official release of
pydsfapi
which can be found at GitHub Releases page as usual.This is the first release of
pydsfapi
and it is target at compatibility with Duet Software Framework 2.1.0 and later (it specifically does not work with DSF 1.2.4 and earlier).With this release the package structure has been brought to a Python standard layout and a
setup.py
has been added for easier installation viadisttools
.What's missing
- There are no concrete class implementations representing the ObjectModel. For now there is a placeholder class
MachineModel
that has all the values asdict
withdict
s inside it.
Release v2.1.2
This release can be found as usual on GitHub Releases page.
Port changes from upstream
- Increase PROTOCOL_VERSION to 6
- Add G53 to string output of commands that use it
Release 3.1.0
This release syncs changes and version with latest DuetSoftwareFramework and can be found as usual on GitHub Releases page.
Ported changed from upstream
- Increase PROTOCOL_VERSION to 7
- Add new
Aux2
CodeChannel
- Comments now use
Q
asCodeType
(instead ofC
) - Letter for unprecedented parameters has been changed from empty string to
Release 3.1.1
Minor release that just updates
PROTOCOL_VERSION
to 8 to be in line with DuetSoftwareFramework 3.1.1.Can be found at GitHub Releases page.
Line 284 of pydsfapi/pydsfapi.py limits the json response to 32kB:
json_string = self.socket.recv(32 * 1024).decode('utf8')
The full machine model can easily exceed that when a print is under way, because it contains an entry for every layer, with at least 90 bytes per layer (depending on the values and number of filaments). Then the json string is just arbitrarily truncated at 32kB and you get an error such as:
Traceback (most recent call last): File "./delta_lights.py", line 99, in <module> mm = subscribe_connection.get_machine_model() File "/usr/local/lib/python3.7/dist-packages/pydsfapi/pydsfapi.py", line 455, in get_machine_model machine_model = self.receive(machinemodel.MachineModel) File "/usr/local/lib/python3.7/dist-packages/pydsfapi/pydsfapi.py", line 275, in receive return cls.from_json(json.loads(json_string)) File "/usr/lib/python3.7/json/__init__.py", line 348, in loads return _default_decoder.decode(s) File "/usr/lib/python3.7/json/decoder.py", line 337, in decode obj, end = self.raw_decode(s, idx=_w(s, 0).end()) File "/usr/lib/python3.7/json/decoder.py", line 353, in raw_decode obj, end = self.scan_once(s, idx) json.decoder.JSONDecodeError: Unterminated string starting at: line 1 column 32768 (char 32767)
If you change the (32 * 1024) to something bigger it goes away, but it doesn't take a very large print to overwhelm any sensible value - 32kB at 90 bytes per layer is only 364 layers, so another 32kB gets you less than a further 73mm of print height at 0.2mm layers.
As I understand it, there's the facility in the DSF to filter the machine model returned. However, I haven't figured out of that is in pydsfapi and if so how to use it. Can a filter be used to not return the 'layers' entries?
@achrn Thanks for reporting. I will look into that.
@wilriker
With theself.socket.recv(32 * 1024)
changed toself.socket.recv(64 * 1024)
and a routine interrogating the machine model and doing some occasionalcommand_connection.perform_simple_code('M573 P0')
at the same time, I've had some prints stop part-way (but neglected to record the error in detail - at the time I thought I knew what had done it so thought I didn't need to pay attention to what it was saying).This may be coincidence, though it's the only time the printer has stopped mid-print, but it may be that putting that receive up to 64 kB upsets something (possibly just takes too long).
I'm trying to use the api with a Duet3 board with firmware 3.1.1 (stable) and the initial connect for the subscription gives me the confirmation immediately followed by a complete machine model:
send: {"mode": "Subscribe", "version": 8, "SubscriptionMode": "Patch", "Filter": ""} recv: {"success":true}{"boards":[{"bootloaderFileName":null,"canAddress":0,"firmwareDate":"2020-05-19b2","firmwareFileName":"Duet3Firmware_MB6HC.bin","firmwareName":"RepRapFirmware for Duet 3 MB6HC","firmwareVersion":"3.1.1"
causing a parser error
File "/home/pi/src/OctoPrint/venv3/lib/python3.7/site-packages/pydsfapi/pydsfapi.py", line 446, in connect return super().connect(sim, socket_path) File "/home/pi/src/OctoPrint/venv3/lib/python3.7/site-packages/pydsfapi/pydsfapi.py", line 238, in connect response = self.receive_response() File "/home/pi/src/OctoPrint/venv3/lib/python3.7/site-packages/pydsfapi/pydsfapi.py", line 280, in receive_response return json.loads(json_string, object_hook=responses.decode_response) File "/usr/lib/python3.7/json/__init__.py", line 361, in loads return cls(**kw).decode(s) File "/usr/lib/python3.7/json/decoder.py", line 340, in decode raise JSONDecodeError("Extra data", s, end)
Is that a known problem?
I'm also wondering about whether the API is threadsafe. A complete worked example with a thread running in the background periodically updating a complete machine model with patches would be extremely helpful.
Different question: Is it possible to use the API to access the socket from a different host? It looks so close to me but no catch.
@ofliduet
Could it be the same issue, but truncating the json in a different location triggering a different error in the json decoder? That is, mine was failing because the truncation happened part-way through a quoted string, if you're not part-way through a string, presumably you'd get a different sort of json decode error?One diagnostic would be to print something with very few layers (one or two) to reset the layers dict in the machine model, then try again.
Also, when I was doing stuff initially I sometimes got an error that if I simply repeated the same script it didn't error. I didn't get to the bottom of that, but one thing I'd try is run the same script again and see if it works.
@achrn Don't think so. This is an initial model, coming in unsolicited directly after the connection has been made. The printer is standing still and I can see the complete model in the recv line. The problem might actually be on the dsf side, where it shouldn't send out a machine model unless specifically requested.
@ofliduet
Standing still doesn't affect it - the machine model seems to contain the last layers list, no matter how long ago that was (though presumably not if the machine and/or the pi is switched off in the meantime, though I haven't tested that).However, if you've received the whole machine model, I agree that I don't think it can be the same issue.
If I do a subscribe connection but don't explicitly request a full machine model, the first 'patch' I get is the full model, but I don't seem to get an unsolicited full model. That is:
import json from pydsfapi import pydsfapi from pydsfapi.initmessages.clientinitmessages import SubscriptionMode subscribe_connection = pydsfapi.SubscribeConnection(SubscriptionMode.PATCH, debug=False) subscribe_connection.connect() mm_u_str = subscribe_connection.get_machine_model_patch() mm_update=json.loads(mm_u_str)
works fine for me, mm_u_str is a json string of the whole model and json.loads is happy to parse it. Subsequent
give me just small patches, as expected. -
@achrn Playing with it a bit more last night I can confirm that the sample code does run correctly when called directly. Where I have problems is when I call the exact some code while there are other things going on.
I'm trying to write an Octoprint plugin that provide a virtual printer in Octoprint, so that I can use TheSpaghettiDetective and the Canvas plugins for the Pallette device without having to go through the serial connection. So the code is called up on startup of the Octoprint server when it loads all plugins and the process is obviously busy at that time with multiple threads doing things at the same time. This seems to have an affect, hence my question on the tread safety of the API. -
@achrn said in pydsfapi [v3.1.1] - Official Python Client Library for DSF:
@wilriker
at the same time, I've had some prints stop part-way (but neglected to record the error in detail - at the time I thought I knew what had done it so thought I didn't need to pay attention to what it was saying).If it happens again please record the error and report here.
I don't think so. This is all going through a local socket connection, i.e. speeds around RAM speed - 64 KiB will be transferred in under 1ms.
@ofliduet said in pydsfapi [v3.1.1] - Official Python Client Library for DSF:
Yes, you can forward the socket via SSH
ssh -o StreamLocalBindUnlink=yes -L<localpath>:/run/dsf/dcs.sock <hostname>
Make sure that the user you are using to connect via SSH has read-write permissions on
/run/dsf/dcs.sock
No it is not. It looks like DCS was sending only a partial response out of unknown reason. Also it did send this unsolicited as you mentioned in a later post. AFAIK it should not do this.
@chrishamm Can you please comment on that part?I'm also wondering about whether the API is threadsafe. A complete worked example with a thread running in the background periodically updating a complete machine model with patches would be extremely helpful.
pydsfapi
is currently not thread-safe. For the time being you either need to synchronize on the connection yourself or create one connection per thread. -
Thanks again for reporting this. I fixed it and will release a new version shortly.
