issues after upgrading to RRF3.2 beta3
@dc42, the issues that worry me most are those related to the "Assertion failed" error which is from the downgrade to version 3.1.1 that are bothering me and this "Error: Failed to get macro response within 8000ms from SBC (channel File)" which I cannot understand what it refers to. I look forward to your feedback so that we can correct the mistakes and work in total serenity. I believe that duet boards work properly, unfortunately I have no way to verify the proper functioning of raspberry, I would also be willing to replace it if it may be necessary as many users seem to be not going to give problems. I believe that duet cards work properly, unfortunately I have no way to verify the proper functioning of the raspberry, I would also be willing to replace it if it may be necessary as many users seem to be not going to give problems. Let me know, thank you again.
Marco -
@Marco-Bona said in issues after upgrading to RRF3.2 beta3:
To be clear: the "Assertion failed" only occurred after you downgraded to 3.1.1. Correct?
I will ask @chrishamm to look at the "Failed to get macro response within 8000ms from SBC" error. When do you see that error? If running a particular macro provokes it, please provide that macro file.
@dc42, The "Assertion failed" error began to occur with RRF3.2 beta2, then I tried to downgrade to beta 1 and finally to 3.1.1 but in both cases it continued to give problems. I do not understand whether it is a consequence or whether there is any other problem that occurred at that time.
I also tried to format and replace the sd card but nothing changed.
For this error " Error: Failed to get macro response within 8000ms from SBC (channel File)" it seems that it concerns the clean_nozzle.g file that I allege, initially if I remember correctly it was (channel daemon) or something similar. I had to delete the daemon.g file which contained a voltage check because it was repeated every 10 seconds.
Remember that the file clean_nozzle in RRF3.2 has no problem, I am still using it in standalone mode. I check in the morning if with beta3 in standalone mode it creates problems and I let you know.
clean_nozzle.g -
Thanks for providing the file.
The "Assertion failed" errors are a known issue with 3.2beta2 (fixed in beta3) when you use M701 or M702. Do you use those commands?
@dc42, no, I'm not using them. The behavior is blocking when printing and restarting the SBC.
I'm going to cheer up an old report that I saved myself, I hope it can help.=== Diagnostics === RepRapFirmware for Duet 3 MB6HC version 3.1.1 running on Duet 3 MB6HC v0.6 or 1.0 (SBC mode) Board ID: 08DJM-956L2-G43S4-6JKF0-3S86T-9A5YD Used output buffers: 1 of 40 (24 max) === RTOS === Static ram: 154604 Dynamic ram: 164252 of which 44 recycled Exception stack ram used: 272 Never used ram: 74044 Tasks: NETWORK(ready,1968) HEAT(blocked,1188) CanReceiv(suspended,3512) CanSender(suspended,1488) CanClock(blocked,1452) TMC(blocked,192) MAIN(running,4488) IDLE(ready,76) Owned mutexes: === Platform === Last reset 00:00:35 ago, cause: software Last software reset at 2020-10-24 09:35, reason: Assertion failed, spinning module GCodes, available RAM 72892 bytes (slot 2) Software reset code 0x4123 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0444a80f BFAR 0x00000000 SP 0x2045fe9c Task MAIN Stack: 00000194 00484cd0 00463dbf 00000000 00000000 00000001 2044cff8 2044cfa8 2043f1a8 00000001 2043f120 Error status: 0 MCU temperature: min 25.2, current 25.8, max 26.0 Supply voltage: min 24.1, current 24.1, max 24.1, under voltage events: 0, over voltage events: 0, power good: yes 12V rail voltage: min 12.0, current 12.1, max 12.1, under voltage events: 0 Driver 0: standstill, reads 41315, writes 19 timeouts 0, SG min/max 0/0 Driver 1: standstill, reads 41315, writes 19 timeouts 0, SG min/max 0/0 Driver 2: standstill, reads 41318, writes 17 timeouts 0, SG min/max 0/0 Driver 3: standstill, reads 41317, writes 18 timeouts 0, SG min/max 0/0 Driver 4: standstill, reads 41319, writes 17 timeouts 0, SG min/max 0/0 Driver 5: standstill, reads 41319, writes 17 timeouts 0, SG min/max 0/0 Date/time: 2020-10-24 09:36:26 Slowest loop: 5.83ms; fastest: 0.14ms === Storage === Free file entries: 10 SD card 0 not detected, interface speed: 37.5MBytes/sec SD card longest read time 0.0ms, write time 0.0ms, max retries 0 === Move === Hiccups: 0(0), FreeDm: 375, MinFreeDm: 375, MaxWait: 0ms Bed compensation in use: none, comp offset 0.000 === MainDDARing === Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 CDDA state: -1 === AuxDDARing === Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 CDDA state: -1 === Heat === Bed heaters = 0 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1, chamberHeaters = 3 -1 -1 -1 Heater 1 is on, I-accum = 0.0 === GCodes === Segments left: 0 Movement lock held by null HTTP* is ready with "M122" in state(s) 0 Telnet is idle in state(s) 0 File is idle in state(s) 0 USB is idle in state(s) 0 Aux is idle in state(s) 0 Trigger* is idle in state(s) 0 Queue is idle in state(s) 0 LCD is idle in state(s) 0 SBC is idle in state(s) 0 Daemon* is doing "G4 S30" in state(s) 0 0, running macro Aux2 is idle in state(s) 0 Autopause is idle in state(s) 0 Code queue is empty. === Network === Slowest loop: 1.29ms; fastest: 0.01ms Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0), 0 sessions Telnet(0), 0 sessions HTTP sessions: 0 of 8 - Ethernet - State: disabled Error counts: 0 0 0 0 0 Socket states: 0 0 0 0 0 0 0 0 === CAN === Messages sent 156, longest wait 2ms for type 6018 === Linux interface === State: 0, failed transfers: 1 Last transfer: 21ms ago RX/TX seq numbers: 44842/1122 SPI underruns 0, overruns 0 Number of disconnects: 0 Buffer RX/TX: 0/0-0 === Duet Control Server === Duet Control Server v3.1.1 Daemon: Buffered code: G4 S30 ; delay running again or next command for at least 60 seconds ==> 32 bytes Executing macro daemon.g, started by system > Next stack level Code buffer space: 4096 Configured SPI speed: 8000000 Hz Full transfers per second: 22.78
@dc42, this is the error I made when I read the daemon.g file in SBC mode:
Error: Failed to get macro response within 8000ms from SBC (channel Daemon)
It is repeated every 10 seconds, although there is a 30 seconds delay in the file
Thank. Please provide the daemon.g file you were using.
@Marco-Bona
daemon.g is ran every second so adding a 60 second delay really isn't a good idea. -
@jay_s_uk, the purpose is to view the voltage periodically, it always worked
@dc42 , i reset everythingand I encounter the same problems as before. When I recall the file with M98 P"clean_nozzle.g" now this error also appears:
Error: Failed to get macro response within 8000ms from SBC (channel HTTP) Warning: Macro file clean_nozzle.g not found
I also point out that the machine is very slow when performing homing while if I delete daemon.g during homing it works correctly
@Marco-Bona yes, because you're blocking a system file by delaying it for 60 seconds which, as i pointed out before, is not a good idea. it gets ran every second and then blocks for 60 seconds, which will block system resources
@jay_s_uk , I would like to give you reason but even eliminating the delay does not change the behavior, explain it to me now
did you wait at least 60 seconds for the queue to flush? or even better, restart the machine?
@jay_s_uk , of course, I also took off the power to be sure
Could be due to the issue that dc42 mentioned about echos.
Try using M118.
And why send a message when the voltage is ok? why not just limit to sending a message when its not ok. That way, you won't get deluged by messages. -
@dc42, I did some evidence, it would seem that by deleting this part
if move.axes[2].userPosition <= 40 G90 G1 Z40 F900 ;move z bed for clearance
of clean_nozzle.g there are no errors. Politely you can verify that the code is right even if I do not explain why in standalone mode it has no problems. The curious thing is that it would seem that eliminating conditional instructions there are no problems
@jay_s_uk , I tried with M118 but the problem persists. As for using the file it was a simple proof that unfortunately it doesn't work as it should
@dc42, I confirm that the problem is related to conditional codes, I put these instructions inside daemon.g and the errors are gone
; daemon.g ;Constantly runs in background to check outputs etc M300 S3000 P500 ; sound alert, required deviation could not be achieved G4 S30
@dc42, I found what causes the error, it turns out to me that if I enter any command before the if loop you do not receive error messages, for example in my file clean_nozzle.g I entered an M400 command before the if loop and the error was no longer repeated, as in daemon.g inserting "M300 S3000 P500; sound warning, the required deviation was not reached" before the if loop seems to be working properly. Can you verify that it's correct please?
