Duet 3 Mini 5+ : Initial announcement
DC42/Tony: Can you post the hole mounting dimensions for the Duet 3 Mini 5+? Better yet, a STEP file of the board?! I'm working on an electrical box for the ExoSlide/ExoCube printer, and would like to be able to mount this new board once available.
Tony will provide a STEP file in due course. Overall dimensions and mounting holes are as for the Duet 2 series. The biggest difference is that the board has been reversed so that if the stepper motor outputs are at the bottom, the power input is on the left, and the SD card, USB and network connectors are on the left. We've done this so that a Raspberry Pi can be positioned next to the Duet and connected without running the cable over or under the Duet or the Pi.
So any news on when the new board will be avaliable ...i'm planing a new build and love to get the new board with this build!thank you!
We will have a limited number of pre-production boards next month. Full production and general availability will be Q1 next year.
@dc42 said in Duet 3 Mini 5+ : Initial announcement:
David as with the Duet3 6HC will the mini come with a SD Card setup for SBC use?
Can't wait to get my hands on one to replace the Wifi in the Delta.Regards Doug
Yes, in theory it will work with exactly the same SD card because newer boards will ship with a config that simply points directly to the configurator and has no default config
@T3P3Tony said in Duet 3 Mini 5+ : Initial announcement:
I was thinking more for the PI tony not standalone? Although it won't be hard to generate one from scratch
@dc42 how to sign for a pre production board?
@Dougal1957 yep, the SD cards should be dual boot, both stand alone and Pi
@weed2all we will be supplying them via resellers and directly through the website
Is there any estimation in terms of releasing? or still before x-mas?
@Dan1990 this was yesterday:
Just to clarify, we expect to have almost 300 pre-production boards early in December, so there should be enough for those who want to try them. We are hopeful that these boards will pass the relevant CE approval tests, but we can't guarantee this because so far we have only run some of these tests (the ones most likely to fail) and on a previous PCB revision. That's why we are calling them pre-production boards. If the boards do pass CE testing then we will be able to do the first production run in January.
nice where can i sing up for preorder
@poohzaza we won't be running a pre-order for those. They will be for sale our website and hopefully some resellers as well.
You sell on your website ? I see you don't sell anything, everything is out of stock with Covid
@pipersw right now yes, we will let people what the plan is when we get closer to the release of the mini 5+
better start saving my pennies the perfect board for me , and people wanting to upgrade ender 3s type printers, they should sell well
@T3P3Tony awsome...tag my name here when the boards are ready to be sell!...as im constantly check the forum...
ps i hope you add a 12v reg for the fans
