Duet 3 SBC Addon Driver Board
@Phaedrux With a single tool I should do that ?
@mrenz999 said in Duet 3 SBC Addon Driver Board:
No, only 1 tool. It's a 2 in 1 out hotend.
Well if you want to drive 2 extruder independently you'll need to define a second tool. It may be a single nozzle, but it's still 2 tools. They can share the heater and fans, and have different extruder drives assigned.
If you only had a single tool defined how would the slicer tell the printer to use the other filament input? It needs to send a tool change command (T0 / T1) to change tools which tells the firmware to use the other extruder.
In the M906 I only have one for my Z which has three drivers. Should that be changed as well ?
No, Z axis is a single axis with identical motors, so only a single value there. The E axis is different because each extruder is independent and may have different motors and must be defined per extruder.
@Phaedrux said in Duet 3 SBC Addon Driver Board:
M92 X100.00 Y100.00 Z400.00 E408 ; set steps per mm M566 X600.00 Y600.00 Z24.00 E300.00 ; set maximum instantaneous speed changes (mm/min) M203 X20000 Y20000 Z600 E2000.00 ; set maximum speeds (mm/min) M201 X3000.00 Y3000.00 Z600.00 E5000.00 ; set accelerations (mm/s^2) M906 X1300 Y1300 Z1300 E800 I30 ; set motor currents (mA) and motor idle factor in per cent
In this section your second E driver will need to have values defined for it. exp:
M906 E800:800
Also, just to be clear you need a second E value for all of those commands. If the extruder motors are identical, they should be the same value, but show up twice separated by a colon.
So it's better to rerun the configuration tool than to add a tool ?
On an unrelated note. Do I need the SD card in the Duet 3 with SBC ? -
The tool definition would look like this
; Tools M563 P0 D0 H1 F0 ; define tool 0 G10 P0 X0 Y0 Z0 ; set tool 0 axis offsets G10 P0 R0 S0 ; set initial tool 0 active and standby temperatures to 0C ; Tools M563 P1 D1 H1 F0 ; define tool 1 G10 P0 X0 Y0 Z0 ; set tool 0 axis offsets G10 P0 R0 S0 ; set initial tool 0 active and standby temperatures to 0C
The only difference is that it assigns the second extruder to tool1. The heater and fan stays the same and there is no offset since it's the same nozzle.
Nah, in this case the tool definition I provided should be enough as long as you fix those other commands to have both extruder values included. (m92, M201, etc)
No. In SBC mode the SD card goes in the SBC only.
If you ever wanted to switch to standalone mode (sometimes useful for troubleshooting) you would need a separeate SD card (ideally) and put your config files on it, and put it in the Duet, then disconnect the SBC.
@Phaedrux Ok. Going to edit and see what happens
Thank you. -
@Phaedrux Should I see 2 extrusion controls ? On the Dashboard screen ?
Edits complete. Shows 2 tools now but still no movement for the 2nd extruder.
; generated by RepRapFirmware Configuration Tool v3.1.3 on Tue Jun 16 2020 08:02:01 GMT-0700 (Pacific Daylight Time); General preferences
G21 ; Set units to MM
M550 P"Duet 3" ; set printer name
M669 K1 ; select CoreXY mode;Network
M552 S1 ; enable network
M586 P0 S1 ; enable HTTP
M586 P1 S0 ; disable FTP
M569 P0.1 S0 ; physical drive 0.1 goes backwards
M569 P0.4 S0 ; physical drive 0.4 goes backwards
M569 P0.5 S1 ; physical drive 0.5 goes forwards
M569 P1.0 S0 ; physical drive 1.0 goes forwards
M584 X0.0 Y0.1 Z0.2:0.3:0.4 E0.5:1.0 ; set drive mapping
M92 X100.00 Y100.00 Z400.00 E408:408 ; set steps per mm
M566 X600.00 Y600.00 Z24.00 E300.00:300.00 ; set maximum instantaneous speed changes (mm/min)
M203 X20000 Y20000 Z600 E2000.00:2000.00 ; set maximum speeds (mm/min)
M201 X3000.00 Y3000.00 Z600.00 E5000.00:5000.00 ; set accelerations (mm/s^2)
M906 X1300 Y1300 Z1300 E800:800 I30 ; set motor currents (mA) and motor idle factor in per cent
M84 S30 ; Set idle timeout
M671 X-40:460:460 Y150:310:50 S9 ; leadscrews at rear left, front middle and rear right; Axis Limits
M208 X Y0 Z0 S1 ; set axis minima
M208 X410 Y410 Z465 S0 ; set axis maxima; Endstops
M574 X1 S1 P"!io0.in" ; configure active-high endstop for low end on X via pin !io0.in
M574 Y1 S1 P"!io1.in" ; configure active-high endstop for low end on Y via pin !io1.in
M574 Z1 S2 ; configure Z-probe endstop for low end on Z; Z-Probe
;M950 S0 C"io7.out" ; create servo pin 0 for BLTouch
;M558 P9 C"^io7.in" H5 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds height + speeds
;G31 P500 X-40 Y-10 Z6 ; set Z probe trigger value, offset and trigger height
;M557 X20:430 Y15:410 S20 ; define mesh grid
Z-Probe
M558 P1 C"!io7.in" H5 F120 T6000
G31 P500 X-40 Y-10 Z2
M557 X20:430 Y15:410 S20; Heaters
M308 S0 P"temp0" Y"thermistor" T100000 B4008 ; configure sensor 0 as thermistor on pin temp0
M308 S1 P"temp1" Y"thermistor" T100000 B3950 ; configure sensor 1 as thermistor on pin temp1
M143 H1 S300
M307 H0 A188.5 C683.1 D0.2 S1.0 V24.1 B0
M307 H1 A351.2 C120.5 D7.2 S1.0 V24.1 B0; Fans
M950 F0 C"out7" Q500 ; create fan 0 on pin out7 and set its frequency
M106 P0 S1 H-1 ; set fan 0 value. Thermostatic control is turned off
M950 F1 C"out8" Q500 ; create fan 1 on pin out8 and set its frequency
M106 P1 S1 H-1 ; set fan 1 value. Thermostatic control is turned off
M950 F2 C"out9" Q500 ; create fan 2 on pin out9 and set its frequency
M106 P2 S1 H-1 ; set fan 2 value. Thermostatic control is turned off; Tools
G10 P0 R0 S0 ; set initial tool 0 active and standby temperatures to 0C; Tools
M563 P1 D1 H1 F0
G10 P0 X0 Y0 Z0
G10 P0 R0 S0; Custom settings are not defined
T0
M501 -
You need to select the tool you want to control. (click it's name in the web interface, or send T0 or T1)
