Homedelta.g Problem
No Spoke too soon.
As soon as I put G501 in the config.g file it happens again.
I'm running
Firmware Electronics: Duet 0.85
Firmware Version: 1.26.1 (2020-02-09b1)
Web Interface Version: 1.22.5the config-override.g file generated is
; config-override.g file generated in response to M500
; Delta parameters
M665 L217.290:217.290:217.290 R106.726 H221.667 B85.0 X-1.474 Y-2.338 Z0.000
M666 X-7.170 Y6.461 Z0.710 A0.00 B0.00
; Heater model parameters
M307 H0 A90.0 C700.0 D10.0 S1.00 V0.0 B1
M307 H1 A340.0 C140.0 D5.5 S1.00 V0.0 B0
M307 H2 A340.0 C140.0 D5.5 S1.00 V0.0 B0
M307 H3 A340.0 C140.0 D5.5 S1.00 V0.0 B0
M307 H4 A340.0 C140.0 D5.5 S1.00 V0.0 B0
M307 H5 A340.0 C140.0 D5.5 S1.00 V0.0 B0 -
post your config.g and your config overwrite
Config.g
; Configuration file for Duet 0.8.5 (firmware version 1.21)
; generated by RepRapFirmware Configuration Tool v3.1.4 on Fri Oct 30 2020 17:48:17 GMT+0000 (Greenwich Mean Time); General preferences
M550 P"MiniKossel" ; set printer name
M665 R105.6 L217.29 B85 H248.92 ; Set delta radius, diagonal rod length, printable radius and homed height
M666 X-26.4 Y-26.4 Z-26.6 ; put your endstop adjustments here, or let auto calibration find them; Network
M540 PBE:EF:DE:AD:FE:ED ; set custom MAC address
M552 P192.168.1.49 S1 ; enable network and set IP address
M553 P255.255.255.0 ; set netmask
M554 P192.168.1.1 ; set gateway
M586 P0 S1 ; enable HTTP
M586 P1 S0 ; disable FTP
M92 X83.22 Y77.58 Z79.68 E631.43 ; set steps per mm
M566 X1200.00 Y1200.00 Z1200.00 E1200.00 ; set maximum instantaneous speed changes (mm/min)
M203 X18000.00 Y18000.00 Z18000.00 E1200.00 ; set maximum speeds (mm/min)
M201 X1000.00 Y1000.00 Z1000.00 E1000.00 ; set accelerations (mm/s^2)
M906 X1000 Y1000 Z1000 E800 I30 ; set motor currents (mA) and motor idle factor in per cent
M208 Z-0.1 S1 ; set minimum Z; Endstops
M574 X2 Y2 Z2 S1 ; set active high endstops; Z-Probe
M558 P1 H10 F120 T2400 ; set Z probe type to unmodulated and the dive height + speeds
G31 P500 X11 Y0 Z1.663 ; set Z probe trigger value, offset and trigger height
M557 R85 S20 ; define mesh grid; Heaters
M305 P0 T100000 B3950 R4700 ; set thermistor + ADC parameters for heater 0
M305 P1 T100000 B4388 R4700 ; set thermistor + ADC parameters for heater 1
; M106 P0 S0 I0 F500 H-1 c"Part Cooling" ; set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
M106 P1 S0 I0 F500 H-1 c"Bed Cooling"; set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned off
T0 ; select first tool
M501dont have Config overwrite file
on a delta its better to use M579
https://duet3d.dozuki.com/Wiki/Calibrating_a_delta_printer#Section_Correcting_for_small_X_and_Y_scaling_errorshow did you arrive at those values?
your endstops are out by quite some bit. that is a difference of 13mm. this could be why the G1 X0 Y0 does not work at Z216
try adjusting them so they are on the same level
thanks for reply veti
re M579 do I put the steps/mm back to 80 and insert a line M579 with my values in?The end stops are all pretty near in my config file, those you copied are generated by auto cal, but will check again.
@Dave-Parry said in Homedelta.g Problem:
see
https://duet3d.dozuki.com/Wiki/Gcode#Section_M579_Scale_Cartesian_axes@Dave-Parry said in Homedelta.g Problem:
yes but those are the values used. and they suggest that the endstops are not at the same level.
alternatively you could change the previous line to
G1 Z-15 F2000 ; down a few mm so that we can centre the head
Have readjusted them, they were'nt that far out but now their within 0.04.
But still have same problem -
Have you tried adding vetis command to lower the print head before trying to move to X0 Y0?
Error: G0/G1: target position not reachable from current position
This error basically means that you're trying to move the head to a position that would require one of the arms to move higher than it physically can. So when trying to move to x0 y0 it would need to raise one arm higher than it can. Dropping all arms down a bit first will help with that.
Yes forgot to do that. That solved that, but have developed another problem that the Y axis does'nt always home properly on the first attempt. Particulaly if the head if off centre. Homes ok if I press home a second time.
@Dave-Parry increase your home height to the theoretical full travel of the axis.
So of your homes height is 320mm but your carriage could have to travel 400 if it's fully extended then put 400mm in for each axis. -
Great that sorted it. Was getting a bit frustrated with it, but hopefully sorted now
We're always here to help.
Hi Guys,
I've been getting this error on my mini Kossel delta as well.
I tried updating the firmware and it's still happening.
My homedelta.g and config.g are as follows:; homedelta.g
; called to home all towers on a delta printer
; generated by RepRapFirmware Configuration Tool v3.1.4 on Tue Nov 10 2020 18:53:43 GMT-0500 (Eastern Standard Time)
G91 ; relative positioning
;*** Slow homing has been configured. Change F180 to F1800 below when your configuration is working
G1 H1 X265 Y265 Z265 F180 ; move all towers to the high end stopping at the endstops (first pass)
G1 H2 X-5 Y-5 Z-5 F1800 ; go down a few mm
;*** Slow homing has been configured. Change F180 to F360 below when your configuration is working
G1 H1 X10 Y10 Z10 F180 ; move all towers up once more (second pass)
G1 Z-5 F2400 ; move down a few mm so that the nozzle can be centred
G90 ; absolute positioning
G1 X0 Y0 F2400 ; move X+Y to the centre; Configuration file for Duet WiFi (firmware version 3)
; generated by RepRapFirmware Configuration Tool v3.1.4 on Tue Nov 10 2020 18:47:04 GMT-0500 (Eastern Standard Time); General preferences
M665 R105.6 L215 B85 H250 ; Set delta radius, diagonal rod length, printable radius and homed height
M666 X0 Y0 Z0 ; put your endstop adjustments here, or let auto calibration find them; Network
M552 S1 ; enable network
M569 P2 S0 ; physical drive 2 goes backwards
M92 X80.00 Y80.00 Z80.00 E663.00 ; set steps per mm
M574 X1 S1 P"!xstop" ; X min active high endstop switch
M574 Y1 S1 P"!ystop" ; Y min active high endstop switch
M574 Z1 S1 P"!zstop" ; Z min active high endstop switch
;M574 Z2 S2 ; configure Z-probe endstop for high end on Z; Z-Probe
M558 P8 C"zprobe.in" H10 F120 T2400 ; set Z probe type to unmodulated and the dive height + speeds
G31 P500 X11 Y0 Z2 ; set Z probe trigger value, offset and trigger height
M308 S0 P"bedtemp" Y"thermistor" T100000 B3950 ; configure sensor 0 as thermistor on pin bedtemp
M308 S1 P"e0temp" Y"thermistor" T100000 B4388 ; configure sensor 1 as thermistor on pin e0temp
M307 H1 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit; Fans
M106 P1 S1 H-1 ; set fan 1 value. Thermostatic control is turned off; Tools
T0 ; select first tool -
@Duke said in Homedelta.g Problem:
G1 X0 Y0 F2400 ; move X+Y to the centreIf it's the same error as the previous poster then increase the size of that Z move to drop the head further. Try -25 instead of -5
@Phaedrux
That worked perfectly, thank you so much!
I guess I didn't understand this thread as well as I thought, but now it makes more sense.
