Dc42 IR probe not triggering DuetWifi on Rostock MaxV2
David - perhaps worth re-wording the Duet and miscsolutions pages to explicitly specify P1 for your sensor?
It was already mentioned twice in the Commissioning section to use M558 P1, but I've added another short paragraph to make it clear that this applies not only during commissioning.
So I just got back to working on the upgrade, got the probing working fine. I ended up having to paint the back of the glass with high temp matte black paint! But that works great now and autocalibration works and all seems to be well… EXCEPT
I cannot get anything to print for the life of me! I've sliced and diced, I've read and read, I feel like I'm missing something, but no extrusion from a sliced gcode.
I can manually extrude, the machine moves to given coordinates just fine. If I tell it to print a sliced model, it just heats up the bed, heats up the nozzle, homes all three towers and just stops. No errors are given. It just says the print is 100% completed.
HELP!? - new thread?
Please post a link to the gcode file you are trying to print
The print going to 100% reminds me of other threads. As well as posting a link to the gcode file, can you also humour an old man and let me know what you have after M555 in your config.g file.
Edit. Just looked up a few posts and I see it's set to P2 so unless that has changed, just ignore me.
This usually means that you are trying to print with no tool selected. But you must have had a tool selected when you extruded manually.
So here's a link to the MatterControl sliced gcode https://pastebin.com/7UYKev5G
Yea I'm definitely selecting T0 at the end config.g and again in the custom start code for MatterControl
Line 25 "MM17". Duet won't know what to do with that odd gcode command. Wonder if that's was causing it….........
Wow, can't believe I didn't see that! It could possibly be, but I'll have to try removing it when I get back to the office. That was there when my Rostock was being run by its original Rambo board….at least I'm fairly sure it was...or I could totally have fat fingered it from an M117 which is likely given the context.
Sometimes I love what a fresh pair of eyes spots!
Let us know if that was the cause - it's just a guess.
Well that was it….thanks for catching my glazed over eyeballs! Removed that, works perfectly fine other than the nozzle thinking 5mm above bed is Z0, so now to re-calibrate and print for real.
