Capacitive Sensor
there is a video from tom about it
Return to the installation.
The wiring is very simple and the adjustment of the probe in Config.g too.Where it goes wrong is with the mesh of the bed ... impossible to have a complete mesh. The nozzle only probes the 2 ends of the front of the deck and stops ... yet normally it should probe all 4 corners as configured.
Tired of searching, I will put back my mini IR probe which for me is not exceptional either (I expected to be frank to be more precise).
@Rudy2A said in Capacitive Sensor:
this is most likely because you did not take the probe offset into consideration.
post your config.g
Exactly, I thought about taking the offset of my probe ... the G32 work good.
; generated by RepRapFirmware Configuration Tool v3.1.4 on Mon Oct 26 2020 11:25:15 GMT+0100 (CET); General preferences
M550 P"My Printer+" ; set printer name
M669 K1 ; select CoreXY mode; Network
M552 S1 ; enable network
M586 P0 S1 ; enable HTTP
M586 P1 S0 ; disable FTP
M569 P1 S0 ; physical drive 1 goes forwards
M569 P3 S0 ; physical drive 3 goes forwards
M569 P4 S0M584 X0 Y1 Z2:4 E3 ; set drive mapping
M671 X-58:317 Y132:132 S10 ; vis à plomb à gauche (connectées à Z) et à droite (connectées à E1) de repère XM350 X16 Y16 Z16 E16 I1 ; configure microstepping with interpolation
M92 X80.00 Y80.00 Z1600.00 E830.00 ; set steps per mm
M566 X600.00 Y600.00 Z60.00 E2400.00 ; set maximum instantaneous speed changes (mm/min)
M203 X11639 Y11639 Z200 E600 ; set maximum speeds (mm/min)
M201 X800.00 Y800.00 Z40.00 E300.00 ; set accelerations (mm/s^2)
M906 X950 Y950 Z950 E1120 I20 ; set motor currents (mA) and motor idle factor in per cent
M208 X0 Y0 Z-0.5 S1 ; set axis minima
M208 X270 Y270 Z245 S0 ; set axis maxima; Endstops
M574 X1 S1 P"xstop" ; configure active-high endstop for high end on X via pin xstop
M574 Y1 S1 P"ystop" ; configure active-high endstop for high end on Y via pin ystop
;M574 Z1 S2 P"io2.in" ; Axe Z avec deux moteurs, butées min.; Z-Probe
M558 P5 C"zprobe.in" H5 F120 T6000 ; set Z probe type to unmodulated and the dive height + speeds
G31 P500 X0 Y-43 Z1.30 ; set Z probe trigger value, offset and trigger height
M557 X11:250 Y11:252 S20 ; define mesh grid; Heaters
M308 S0 P"bedtemp" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 0 as thermistor on pin bedtemp
M307 H0 A435.0 C388.3 D7.8 B0 S0.8 V13.4
;M307 H0 B0 S1.00 ; disable bang-bang mode for the bed heater and set PWM limit
M308 S1 P"e0temp" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 1 as thermistor on pin e0temp
M307 H1 A650.7 C221.3 D4.8 B0 S1 V13.3
;M307 H1 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit; Fans
G32 does not create a mesh. G29 does
G32 does true bed leveling.post your bed.g
I have known this for a little while and thanks to this forum that there is a difference between G32 and G29. It was just a tip in case ...
; bed.g
G28 ; Home all Axes
M561 ; Efface la correction de plan
M290 R0 S0 ; Efface Baby-stepping; Bed levelling (G32)
G30 P0 X0.0 Y132 Z-99999; sonde près d'une vis sans fin, à mi-chemin le long de l'axe Y
G30 P1 X260 Y132 Z-99999 S2; sonde près d'une vis et calibrez 2 moteurs -
@Rudy2A
that only has 2 probe point. why do you think it should probe 4 points? -
This configuration works perfectly with the IR probe.
S2 probes the 4 corners (2X2).
If you put S4, it will probe 4 points on the first line multiplied by 4, so 16 points on the bed.
This is valid for S3, S6 ...
so you are talking about G29 and not G32.
M557 X11:250 Y11:252 S20 ; define mesh gridThis does not match.
Also there will be an error message in the console telling you whats wrong.Y252 can not be reached with an offset of -43
change this to
M557 X11:250 Y11:220 S20 ; define mesh grid -
@Veti said in Capacitive Sensor:
Y252 ne peut pas être atteint avec un décalage de -43
changez ceci en
M557 X11: 250 Y11: 220 S20; définir la grille de maillagethank you,
Indeed, with that it works ...
On the other hand, depending on the tests carried out, the capacitive or IR probe is similar. I would tell you that my finding to come.
I definitely left the capacitive probe to the detriment of the mini IR probe.
The reason is that for me the weight of the capacitive probe was a bit too heavy. She was exerting a difference on my bed when polling.
FYI, my bed is not absolutely stable and the slightest difference in weight causes a difference in the measurement in the height map.
I will be working on another much more stable bed system soon, so I will test again.
@Rudy2A
there a small capacitive probes like the pinda probe -
I found the sensors all gad its addvantages and dis -advantages after som monkeyong arround i decided to try this
I installed the z swich on tip of the extruder
Which sits on two linerer rails so when the nozzle
Touches the bed it trips the sw
This works really well and is extremely accurate
I went this way because of the fluctuations with most sensors. be aware this is a ton of work but well worth it in my opinion. im happy with my mod but took 4 months to put together and i have lots if time. The other sensor i used was a n abl capasitive
I found out i was as much as 1.5 mm off at random
Other times it worke fair but not supper accurate
The other option is the bl toutch im affraid i would go thru a bunch breaking the pins.. good luck thought i would share that. -
@ziggymanpopo Late response due to my work ... Thank you for sharing, I admit that your technique has already turned in my head!
