Wifi not connecting after firmware install. Duet2 Wifi
@droftarts said in Wifi not connecting after firmware install. Duet2 Wifi:
M122
M122
RepRapFirmware for Duet 2 WiFi/Ethernet version 2.05.1 running on Duet WiFi 1.02 or later
Board ID: 08DJM-9178L-L2MSD-6J9FD-3S46J-9SFAP
Used output buffers: 1 of 24 (2 max)
Static ram: 25712
Dynamic ram: 92540 of which 460 recycled
Exception stack ram used: 260
Never used ram: 12100
Tasks: NETWORK(ready,812) HEAT(blocked,1232) MAIN(running,3824) IDLE(ready,160)
Owned mutexes:
Last reset 00:01:39 ago, cause: power up
Last software reset at 2020-10-25 11:28, reason: User, spinning module GCodes, available RAM 9316 bytes (slot 1)
Error status: 0
Free file entries: 10
MCU temperature: min 18.4, current 23.7, max 23.9
Supply voltage: min 0.6, current 1.7, max 1.8, under voltage events: 0, over voltage events: 0, power good: no
Driver 0: ok, SG min/max not available
Driver 1: ok, SG min/max not available
Driver 2: ok, SG min/max not available
Driver 3: ok, SG min/max not available
Driver 4: ok, SG min/max not available
Cache data hit count 365048372
Slowest loop: 5.52ms; fastest: 0.05ms
Hiccups: 0, FreeDm: 160, MinFreeDm: 160, MaxWait: 0ms
=== DDARing ===
Segments left: 0
Movement lock held by null
http is idle in state(s) 0
telnet is idle in state(s) 0
file is idle in state(s) 0
serial is ready with "M122" in state(s) 0
aux is idle in state(s) 0
daemon is idle in state(s) 0
queue is idle in state(s) 0
Code queue is empty.
=== Network ===
Slowest loop: 83.12ms; fastest: 0.00ms
HTTP sessions: 0 of 8- WiFi -
Network state is running
WiFi firmware version 1.23
WiFi MAC address dc:4f:22:6e:e5:d2
WiFi Vcc 3.39, reset reason Turned on by main processor
WiFi flash size 4194304, free heap 23952
WiFi IP address 192.168.1.60
WiFi signal strength -53dBm, reconnections 0, sleep mode modem
ok
- WiFi -
My SD Card is in place. Above says its not detecting one...
@haydenkrause said in Wifi not connecting after firmware install. Duet2 Wifi:
this mean one card has been detected in slot 0
ah ok - miss read that
thank for ur help btw!
Ok. So tried all the above in formatting FAT32 etc, putting the following files on the SD card...
sys (from configuration tool)
gcode (empty folder)
macros (empty folder)I am seeing my wifi LED on. But i cant connect using the IP address
you are missing the www folder with the duet web control
do i need to set that myself?
Following the "New Method" i dont have to add this...
that is still required. without this there is no web interface
ok - think i may have found it... ill try this thx
Shoot! cracked it..
The link i used was here:
https://duet3d.dozuki.com/Wiki/Firmware_Overview
scroll to "SD Card Structure" explains in full - lovely....
Thanks for ur help dude!
In future, when updating the firmware use the main zip file from the release. This contains any required files including the web interface files and everything will get updated all in one go.
For instance, now that you're on 2.05.1 you can upload the zip file for 3.0 and then 3.1.1 to get fully up to date.
Upload the zip file as is, don't extract it, to the system tab in DWC. To get to 3.1.1 you need to update to 3.0 first to get all the required files for RRF3.
https://github.com/Duet3D/RepRapFirmware/releases/download/3.0/Duet2and3Firmware-3.0.zip
https://github.com/Duet3D/RepRapFirmware/releases/download/3.1.1/Duet2and3Firmware-3.1.1.zip
You would also need to update your config files to work with RRF3.
Thanks Phaedrux, i will do. I am sticking with 2.05 for now because I managed to get my 3 pin switch type z probe working. I tried everything on RR3 and i just couldn't get it working. It was connected to the zprobein using sensor type5 as stated in the online instructions (as type 4 not supported). Config was pointed to zprobe in using C".......". I am following a few posts on here with people having the same issues currently unsolved - if they can solve them i will update.
thanks for the time to help!
Which would those be? link?
You could post your RRF3 config.g as well in case it's just a simple syntax error. What probe are you using specifically?
