Strange BLTouch issue. Hightmap it off while printing
the 2 z connectors on the duet actually run in series rather than in parallel.
from the linked site
Note that the Z driver (drive 2 on Duet2) has a dual socket wired in series for powering two z motors at once.
@Veti ohhh okey so that are some bad news i see haha okey. I will give the independent z setup a try.
@RocketPat said in Strange BLTouch issue. Hightmap it off while printing:
for now change this to
M584 X0 Y1 Z2:4 E3 ; set drive mappingconnect the second z motor to e1 and place the jumpers on the second z connector.
that way you are using 2 motors for now.
@Veti okey i only need to change that or do i have to do more suff i am reading that hole article for the frist time now and i am kinda scared to set up everythig new again. I will do a quick backup and give it a try.
that changes allows you to use 2 motors for now.
you still need to do the rest later.my guess for now is that you are losing steps because of the 6v dual z setup.
okey i am doing a quick first layer print and see what is happening, looking good so far. Nothing exploded.
So now i did quite a bit testing and i got a much better result.
Also the true leveling is working now. But i still have too low presure on the left side. I can get a print startet now and it would be working but maby my current is too low now.
did you measure the real offset of the probe?
yep i startet at x100 y100 and moved to x117 y143 what means that the offset should be -17 and -43
okey now i got a new problem, after i restarted the board the hightmap is getting generated but is not used. The motors dosen't correct my print anymore.
Can you post your homeall/homez? Where are you probing on the bed to set z0? It looks like you're using a corner rather than the center of the bed.
this is my home all
; homeall.g ; called to home all axes ; generated by RepRapFirmware Configuration Tool v3.1.4 on Sat Oct 03 2020 22:18:40 GMT+0200 (Mitteleuropäische Sommerzeit) G91 ; relative positioning G1 H2 Z5 F6000 ; lift Z relative to current position G1 H1 X-245 Y-285 F1800 ; move quickly to X and Y axis endstops and stop there (first pass) G1 H2 X5 Y5 F6000 ; go back a few mm G1 H1 X-245 Y-285 F360 ; move slowly to X and Y axis endstops once more (second pass) G90 ; absolute positioning G1 X118 Y185 F6000 ; home Z G30 ; home Z by probing the bed ; Uncomment the following lines to lift Z after probing ;G91 ; relative positioning ;G1 Z5 F100 ; lift Z relative to current position ;G90 ; absolute positioning
and this is home z
; homez.g ; called to home the Z axis ; ; generated by RepRapFirmware Configuration Tool v3.1.4 on Sat Oct 03 2020 22:18:40 GMT+0200 (Mitteleuropäische Sommerzeit) G91 ; relative positioning G1 H2 Z5 F6000 ; lift Z relative to current position G90 ; absolute positioning G1 X20 Y55.5 F6000 ; go to first probe point G30 ; home Z by probing the bed ; Uncomment the following lines to lift Z after probing ;G91 ; relative positioning ;G1 Z5 F100 ; lift Z relative to current position ;G90 ; absolute positioning
@Phaedrux in the home all i am using the middle of my bed
do you still have the G29 in the start script?
yep right after i home all
M107 ;M190 S45 ;set bed temperature and wait for it to be reached G28 ;Home axis G29 M109 S210 ; M107 ; Turn layer fan off G21 ; Set to metric change to G20 if you want Imperial G90 ; Force coordinates to be absolute relative to the origin G0 X0 Y0 F9000 ; Go to front G0 Z0.15 ; Drop to bed G92 E0 ; zero the extruded length G1 X80 E6 F780.000 ; Extrude filament in a 8cm line G92 E0 ; zero the extruded length G1 E-1 F780.000 ; Retract a little G1 X80 F4000 ; Quickly wipe away from the filament line G1 Z0.3 ; Raise and begin printing.
while printing use M122 to check if mesh compensation is active
So i think its on, but i am not sure why the offset is 0
M122 === Diagnostics === RepRapFirmware for Duet 2 WiFi/Ethernet version 3.1.1 running on Duet WiFi 1.02 or later Board ID: 08DJM-9178L-L4MSJ-6J1F4-3S06M-193YP Used output buffers: 3 of 24 (7 max) === RTOS === Static ram: 27980 Dynamic ram: 94072 of which 44 recycled Exception stack ram used: 576 Never used ram: 8400 Tasks: NETWORK(ready,716) HEAT(blocked,1224) MAIN(running,1632) IDLE(ready,80) Owned mutexes: WiFi(NETWORK) === Platform === Last reset 00:02:49 ago, cause: software Last software reset at 2020-10-25 16:47, reason: User, spinning module GCodes, available RAM 8424 bytes (slot 3) Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x04417000 BFAR 0xe000ed38 SP 0xffffffff Task MAIN Error status: 0 MCU temperature: min 29.0, current 29.8, max 30.3 Supply voltage: min 11.8, current 12.0, max 12.4, under voltage events: 0, over voltage events: 0, power good: yes Driver 0: ok, SG min/max 0/517 Driver 1: standstill, SG min/max 0/495 Driver 2: ok, SG min/max not available Driver 3: ok, SG min/max 0/432 Driver 4: ok, SG min/max not available Date/time: 2020-10-25 16:50:37 Cache data hit count 279758463 Slowest loop: 154.49ms; fastest: 0.12ms I2C nak errors 0, send timeouts 0, receive timeouts 0, finishTimeouts 0, resets 0 === Storage === Free file entries: 9 SD card 0 detected, interface speed: 20.0MBytes/sec SD card longest read time 3.4ms, write time 2.2ms, max retries 0 === Move === Hiccups: 0(0), FreeDm: 166, MinFreeDm: 157, MaxWait: 15080ms Bed compensation in use: mesh, comp offset 0.000 === MainDDARing === Scheduled moves: 99, completed moves: 88, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 CDDA state: 3 === AuxDDARing === Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 CDDA state: -1 === Heat === Bed heaters = 0 -1 -1 -1, chamberHeaters = -1 -1 -1 -1 Heater 0 is on, I-accum = 0.0 Heater 1 is on, I-accum = 0.5 === GCodes === Segments left: 1 Movement lock held by null HTTP is idle in state(s) 0 Telnet is idle in state(s) 0 File is doing "G1 X13.453 Y68.416 E30.30764" in state(s) 0 USB is idle in state(s) 0 Aux is idle in state(s) 0 Trigger is idle in state(s) 0 Queue is idle in state(s) 0 Daemon is idle in state(s) 0 Autopause is idle in state(s) 0 Code queue is empty.
that is fine. why do you think its not working?
i was just wondering about the 0.000, but still i have that strange issue that my map is kinda flipped around. The right side is too far up and the left side is too far down... its doing the opposite of what the mesh is giving out.
another possibility could be sagging linear rods causing a tilt in the hotend carriage.
