Homing issues on a Delta with Duet 2
Thank you for looking into this
The config came from the online configuration tool, delta parameters came from an "old" mks_robin config file for the QQ-S.
Only the Z-probe switch has been inverted through manual editing.
The
M119
log:10/19/2020, 3:58:23 PM: m119: Endstops - X: not stopped, Y: not stopped, Z: not stopped, Z probe: not stopped 10/19/2020, 3:58:34 PM: m119: Endstops - X: not stopped, Y: not stopped, Z: at min stop, Z probe: not stopped 10/19/2020, 3:58:43 PM: m119: Endstops - X: at min stop, Y: not stopped, Z: not stopped, Z probe: not stopped 10/19/2020, 3:58:52 PM: m119: Endstops - X: not stopped, Y: at min stop, Z: not stopped, Z probe: not stopped 10/19/2020, 3:59:13 PM: m119: Endstops - X: not stopped, Y: at min stop, Z: not stopped, Z probe: at min stop
config.g
; Configuration file for Duet WiFi (firmware version 2.03) ; executed by the firmware on start-up ; ; generated by RepRapFirmware Configuration Tool v3.1.4 on Mon Oct 19 2020 11:02:18 GMT+0200 (Central European Summer Time) ; General preferences G90 ; send absolute coordinates... M83 ; ...but relative extruder moves M550 P"Legionare" ; set printer name M665 R130 L280 B130 H370 ; Set delta radius, diagonal rod length, printable radius and homed height M666 X0 Y0 Z0 ; put your endstop adjustments here, or let auto calibration find them ; Network M552 S1 ; enable network M586 P0 S1 ; enable HTTP M586 P1 S0 ; disable FTP M586 P2 S0 ; disable Telnet ; Drives M569 P0 S0 ; physical drive 0 goes forwards M569 P1 S0 ; physical drive 1 goes forwards M569 P2 S0 ; physical drive 2 goes forwards M569 P3 S0 ; physical drive 3 goes forwards M584 X0 Y1 Z2 E3 ; set drive mapping M350 X16 Y16 Z16 E16 I1 ; configure microstepping with interpolation M92 X100.00 Y100.00 Z100.00 E417.00 ; set steps per mm M566 X1200.00 Y1200.00 Z1200.00 E1200.00 ; set maximum instantaneous speed changes (mm/min) M203 X12000.00 Y12000.00 Z12000.00 E12000.00 ; set maximum speeds (mm/min) M201 X1000.00 Y1000.00 Z1000.00 E1000.00 ; set accelerations (mm/s^2) M906 X1000 Y1000 Z1000 E800 I30 ; set motor currents (mA) and motor idle factor in per cent M84 S30 ; Set idle timeout ; Axis Limits M208 Z0 S1 ; set minimum Z ; Endstops M574 X1 Y1 Z1 S1 ; set active low and disabled endstops ; Z-Probe M558 P4 I1 H5 F120 T6000 ; set Z probe type to switch and the dive height + speeds G31 P500 X0 Y0 Z16.2 ; set Z probe trigger value, offset and trigger height M557 R85 S20 ; define mesh grid ; Heaters M305 P0 T100000 B4138 R4700 ; set thermistor + ADC parameters for heater 0 M143 H0 S120 ; set temperature limit for heater 0 to 120C M305 P1 T100000 B4138 R4700 ; set thermistor + ADC parameters for heater 1 M143 H1 S260 ; set temperature limit for heater 1 to 260C ; Fans M106 P0 C"Effector" S0 I0 F500 H-1 ; set fan 0 name, value, PWM signal inversion and frequency. Thermostatic control is turned off ; Tools M563 P0 S"HotEnd" D0 H1 F0 ; define tool 0 G10 P0 X0 Y0 Z0 ; set tool 0 axis offsets G10 P0 R0 S0 ; set initial tool 0 active and standby temperatures to 0C ; Custom settings are not defined ; Miscellaneous M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; set voltage thresholds and actions to run on power loss
homedelta.g
; homedelta.g ; called to home all towers on a delta printer ; ; generated by RepRapFirmware Configuration Tool v3.1.4 on Mon Oct 19 2020 11:02:18 GMT+0200 (Central European Summer Time) G91 ; relative positioning G1 H1 X455 Y455 Z455 F1800 ; move all towers to the high end stopping at the endstops (first pass) G1 H2 X-5 Y-5 Z-5 F1800 ; go down a few mm G1 H1 X10 Y10 Z10 F360 ; move all towers up once more (second pass) G1 Z-5 F6000 ; move down a few mm so that the nozzle can be centred G90 ; absolute positioning G1 X0 Y0 F6000 ; move X+Y to the centre
@Meki said in Homing issues on a Delta with Duet 2:
This should be
M574 X2 Y2 Z2 S1
for high end endstops.If you're a new user to Duet and this is a new build, it might be a good time to jump to RRF v3.1.1 since you're getting a fresh config from the config tool anyway.
Updating the firmware is easy as uploading two zip files.
https://github.com/Duet3D/RepRapFirmware/releases/download/3.0/Duet2and3Firmware-3.0.zip
https://github.com/Duet3D/RepRapFirmware/releases/download/3.1.1/Duet2and3Firmware-3.1.1.zip
First upload the 3.0 zip file as is without extracting. Then after it updates, do the same for 3.1.1 zip file.
Then you can upload the config file set from the web tool for RRF3.
M305 P1 T100000 B4138 R4700 ; set thermistor + ADC parameters for heater 1your thermistor settings are wrong. look up the correct beta value in your thermistor documentation.
@Phaedrux said in Homing issues on a Delta with Duet 2:
M574 X2 Y2 Z2 S1
Well, I've upgraded to RRF 3, had a little issue with the
iap4e.bin
file, bot solved it... I'm now running RRF 3.1.1, but still the grinding is there on the endstops and my z-probe has stopped producing any results... it's locked toat min stop
... at least the endstops sayat max stop
when triggered manually...So, z-probe broke, and the towers still want to blow off...
I'm guessing that the z-probe pin now expects to be on the z-probe-in pin instead of e0_stp as in the RRF2...
@Veti Thanks, but I've got no idea what type of thermistor is in place... FLSUN has been making changes and documentation is scarce to say the least... at least it's a cartridge type instead of the original bare glass bead version...
Can you post your updated config.g and homedelta.g please
marlin says its
1 : 100k thermistor - best choice for EPCOS 100k (4.7k pullup) -
@jay_s_uk
config.g; Configuration file for Duet WiFi (firmware version 3) ; executed by the firmware on start-up ; ; generated by RepRapFirmware Configuration Tool v3.1.4 on Tue Oct 20 2020 07:47:37 GMT+0200 (Central European Summer Time) ; General preferences G90 ; send absolute coordinates... M83 ; ...but relative extruder moves M550 P"Legionare" ; set printer name M665 R130 L280 B130 H370 ; Set delta radius, diagonal rod length, printable radius and homed height M666 X0 Y0 Z0 ; put your endstop adjustments here, or let auto calibration find them ; Network M552 S1 ; enable network M586 P0 S1 ; enable HTTP M586 P1 S0 ; disable FTP M586 P2 S0 ; disable Telnet ; Drives M569 P0 S0 ; physical drive 0 goes backwards M569 P1 S0 ; physical drive 1 goes backwards M569 P2 S0 ; physical drive 2 goes backwards M569 P3 S0 ; physical drive 3 goes backwards M584 X0 Y1 Z2 E3 ; set drive mapping M350 X16 Y16 Z16 E16 I1 ; configure microstepping with interpolation M92 X100.00 Y100.00 Z100.00 E417.00 ; set steps per mm M566 X1200.00 Y1200.00 Z1200.00 E1200.00 ; set maximum instantaneous speed changes (mm/min) M203 X12000.00 Y12000.00 Z12000.00 E12000.00 ; set maximum speeds (mm/min) M201 X1000.00 Y1000.00 Z1000.00 E1000.00 ; set accelerations (mm/s^2) M906 X1000 Y1000 Z1000 E800 I30 ; set motor currents (mA) and motor idle factor in per cent M84 S30 ; Set idle timeout ; Axis Limits M208 Z0 S1 ; set minimum Z ; Endstops M574 X2 S1 P"xstop" ; configure active-high endstop for high end on X via pin xstop M574 Y2 S1 P"ystop" ; configure active-high endstop for high end on Y via pin ystop M574 Z2 S1 P"zstop" ; configure active-high endstop for high end on Z via pin zstop ; Z-Probe M558 P4 C"^zprobe.in" I1 H5 F120 T6000 ; set Z probe type to switch and the dive height + speeds G31 P500 X0 Y0 Z16.2 ; set Z probe trigger value, offset and trigger height M557 R85 S20 ; define mesh grid ; Heaters M308 S0 P"bedtemp" Y"thermistor" T100000 B4138 ; configure sensor 0 as thermistor on pin bedtemp M950 H0 C"bedheat" T0 ; create bed heater output on bedheat and map it to sensor 0 M307 H0 B1 S1.00 ; enable bang-bang mode for the bed heater and set PWM limit M140 H0 ; map heated bed to heater 0 M143 H0 S120 ; set temperature limit for heater 0 to 120C M308 S1 P"e0temp" Y"thermistor" T100000 B4138 ; configure sensor 1 as thermistor on pin e0temp M950 H1 C"e0heat" T1 ; create nozzle heater output on e0heat and map it to sensor 1 M307 H1 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit ; Fans M950 F0 C"fan0" Q500 ; create fan 0 on pin fan0 and set its frequency M106 P0 C"Effector" S0 H-1 ; set fan 0 name and value. Thermostatic control is turned off ; Tools M563 P0 S"HotEnd" D0 H1 F0 ; define tool 0 G10 P0 X0 Y0 Z0 ; set tool 0 axis offsets G10 P0 R0 S0 ; set initial tool 0 active and standby temperatures to 0C ; Custom settings are not defined ; Miscellaneous M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; set voltage thresholds and actions to run on power loss T0 ; select first tool
homedelta.g
; homedelta.g ; called to home all towers on a delta printer ; ; generated by RepRapFirmware Configuration Tool v3.1.4 on Tue Oct 20 2020 07:47:37 GMT+0200 (Central European Summer Time) G91 ; relative positioning G1 H1 X455 Y455 Z455 F1800 ; move all towers to the high end stopping at the endstops (first pass) G1 H2 X-5 Y-5 Z-5 F1800 ; go down a few mm G1 H1 X10 Y10 Z10 F360 ; move all towers up once more (second pass) G1 Z-5 F6000 ; move down a few mm so that the nozzle can be centred G90 ; absolute positioning G1 X0 Y0 F6000 ; move X+Y to the centre
@Veti Thanks! I mean it!
Nothing looks incorrect in your homing files so I don't see why the endstops aren't triggering correctly.
In the M558, P4 is no longer supported and P5 should be used instead.
https://duet3d.dozuki.com/Wiki/Gcode#Section_M558_in_RepRapFirmware_Num_3 -
@jay_s_uk Z-probe is fixed, thanks!
And believe my, I'm just as baffled...
M119
reports that all the endstops are in the neutral state and when I'm going around, triggering them manuallyM119
reports that the endstops are triggered... -
