Piezo Orion + RRF 3.... Problems
So it works! Thank you for your help. But now I have the next problem. How can I use the orion correctly? How do I set z. no matter what I do . He starts printing in the air. With rrf3 I determine z with 92z0 right? Then I create a mesh. What do I have to enter in his? I'm still new to rrf. before marlin sorry. do not quite understand all of this yet
@chop now you need to manually figure out the Z offset of the probe and put it in the config.
- super important is that you heat up your bed and nozzle before you home Z with the orion
- super important that you clean a nozzle before you probe (so heat up, wipe, retract, wipe is what I do, visually inspect when nozzle is sitting above center of the bed that nozzle is clean)
- after you home Z, you then need to find the "offset"
this offset is normally in the range of 0 to -0.1mm depending on how sensitive your orion is and how fast you probe so it's basically the travel your bed does during a trigger delay. how to setup this offset ... ppl have different preferences, what I do is I'd leave nozzle in the center of the bed (homing position) and do
G0Z1
this should have your nozzle close to the bed but not touching it
disable soft limits
M564 S0 H0
now I put piece of paper between nozzle and bed and start reducing this value
G0Z0.5
G0Z0.3
G0Z0.2
G0Z-0.2
...till I get to point that paper is being grabbed by the nozzle
this position need to be your Z0 so see how far you are from it (you know what Z value you gave it), change the sign of that value and put in the config of the probe (G31, the Z value):
e.g.:G31 X0 Y0 Z-0.1 P250
hope this helps
btw, do this while everything is HOT and nozzle is clean. Otherwise not much point in using orion, as if you probe cold those are not real value during print.... this is why I like the durable print surfaces like printbite as if you have those soft print surfaces they can dislike the hot nozzle so then you might want to work hot but heat up the bed to your print temperature but heat up the nozzle to lower temp like 100-120C enough for it to "get bigger" but not hot enough to damage the print board if you mess something up
useful read: https://duet3d.dozuki.com/Wiki/Test_and_calibrate_the_Z_probe
one hint, since digging hot nozzle into print bed is a real solution when you do this first time I suggest you use a PCB on top of your print bed, or use glass as your print surface for the first test... so both probe over the hard surface that's temperature resistent (pcb/FR4 or glass) and start the first print on top of such surface to be sure you got the probing and configuration (offset) properly calibrated
going further, one other hint .. before you start printing, make sure that ORION Is ok and that you are not drowning in noise .. so run a test probing same point many times
@arhi ty . I will try. But, how to set z0 corect? After z0 i can set offset !? Right? Once i get the offset. I have to tell the Slicer to use the mesh?
@arhi said in Piezo Orion + RRF 3.... Problems:
G0Z1
disable soft limits
M564 S0 H0
G0Z0.5
G0Z0.3
G0Z0.2
G0Z-0.2
hope this helps
Make sure the dynamic test is successful (Z probe stops when it senses the bed) before doing this.
Cancel any currently active mesh compensation with M561
Use the X and Y jog buttons to position the nozzle over the centre of the bed
Jog the nozzle down until it is just touching the bed or just gripping a sheet of paper. If the firmware doesn't let you jog it down far enough, send M564 S0 to disable axis limits.
Once you have the nozzle touching the bed, send command G92 Z0 to tell the firmware that the head is at Z=0
Jog the head up by 5 to 10mm
Send command G30 S-1. The nozzle will descend or the bed rise until the probe triggers and the Z height at which the probe stopped will be reported. If you are using a nozzle-contact Z probe, the trigger height will be slightly negative. For any other type of Z probe where the probe triggers before the nozzle contacts the bed, it will be positive.
Repeat from step 5 two or three times to make sure that the trigger height is consistent.
In Duet Web Control, go to Settings -> System Editor and edit the config.g file. Set the Z parameter in the G31 command to the trigger height that was reported. Save the file.
Open config-override.g and check that there are no G31 commands in it. If you find any, delete those lines and save the file.
To apply the new trigger height, restart the Duet by sending M999 or pressing Emergency Stop.Thats what i do...print starts mid air
testing the repeatability - very important with piezo
G28 M401 G30 P0 X151 Y161 Z-9999 G30 P1 X151 Y161 Z-9999 G30 P2 X151 Y161 Z-9999 G30 P3 X151 Y161 Z-9999 G30 P4 X151 Y161 Z-9999 G30 P5 X151 Y161 Z-9999 G30 P6 X151 Y161 Z-9999 G30 P7 X151 Y161 Z-9999 G30 P8 X151 Y161 Z-9999 G30 P9 X151 Y161 Z-9999 S-1 M402
change X and Y values to be in the center of your bed
more details here: https://forum.duet3d.com/topic/6962/m48-measure-z-probe-repeatability-and-print-to-serial-output/4 -
@chop said in Piezo Orion + RRF 3.... Problems:
what is your G31 config line now?
what does yourG31
report when you execute it?
did you run repeatability macro? -
@chop that is nicely repeatable, you have it working good I'd say
you need to change your G31, if you are printing in the air you need to lower the value more into negative... zo try Z-0.1 or Z-0.15 or even more Z-0.2 till you get satisfying first layer. I never seen it need more then -0.15 for ppiezo but .. if I didn't see it, it does not mean it does not exist
also - did you probe with heated nozzle?! if you are not probing with nozzle and bed at printing temperature that can account for a wrong (too high) required offset
@arhi i prob @ 80 on bed and 130 on nozzle
@chop those temps should be ok, just increase the offset a bit (absolute increase, the value need to go more in the negative)
@arhi if my bed isnt good levelt. i have to make a grid? with my current z0? and the orion knows where the bes is + or -? or i need g29 s1?
What thats mean?
means that your config is not ok
you need to first setup G31 with proper offset
then you need to home
then you need to G29 -
@arhi what is z=0 Datum?
@chop it compares the middle height of probed points with homed Z, the error is over 1.3mm .. this usually happens when you home, have wrong offset change offset and then do G29 without homing again ... I suggest you change config, reset board, home, g29, again change config, reset board, home, g29 ... until you are happy ... you can run g29 multiple times but any time you change config / execute G31 you reboot board, home, then g29
That z datum error message usually means you've loaded a heightmap before you've used G30 to set Z0 first. Or you've used an endstop to set z0 rather than the probe.
@Phaedrux i User the probe as endstop.
Is this Configuration correct? :
M208 X300 Y300 Z250 S0 ; set axis maxima; Endstops
M574 Z1 S2 ; configure Z-probe endstop for low end on Z; Z-Probe
M558 P5 C"^!zprobe.in" H5 F300 T15000 ; set Z probe type to switch and the dive height + speeds
G31 X0 Y0 Z-0.05 P250 ; set Z probe trigger value, offset and trigger height
M557 X5:300 Y5:300 S20 ; define mesh grid -
That looks fine, but you must be using G30 in your homeall.g. Also make sure you do NOT have G29 S1 in your config.g
