BLTouch Homing in wrong direction
Used reprap firmware config tool tool to create new config .g file but now bltouch isn't deploying it does self test fine on powering up the printer but doesn't deploy with M280 P0 Z10.
here is my new config .g now
; generated by RepRapFirmware Configuration Tool v3.1.4 on Thu Oct 01 2020 12:28:30 GMT+0100 (British Summer Time); General preferences
M550 P"Creality CR-10" ; set printer name; Network
M552 S1 ; enable network
M586 P0 S1 ; enable HTTP
M586 P1 S0 ; disable FTP
M569 P0 S0 ; physical drive 0 goes backwards
M569 P2 S0 ; physical drive 2 goes backwards
M92 X80.00 Y80.00 Z400.00 E415.00 ; set steps per mm
M203 X60000.00 Y60000.00 Z30000.00 E1200.00 ; set maximum speeds (mm/min)
M906 X1000 Y1000 Z1000 E1000 I30 ; set motor currents (mA) and motor idle factor in per cent
M208 X310 Y320 Z400 S0 ; set axis maxima; Endstops
M574 Z1 S2 ; configure Z-probe endstop for low end on Z; Z-Probe
M950 S0 C"exp.heater7" ; create servo pin 0 for BLTouch
M558 P9 C"^zprobe.in" H5 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds
G31 P500 X0 Y0 Z3.7 ; set Z probe trigger value, offset and trigger height
M557 X50:280 Y50:280 S50 ; define mesh grid; Heaters
M307 H1 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit; Fans
M106 P0 S0 H1 T60 ; set fan 0 value. Thermostatic control is turned on
M106 P1 S1 H-1 ; set fan 1 value. Thermostatic control is turned off; Tools
M563 P0 S"Extruder 1" D0 H1 F0 ; define tool 0
here is home z
; homez.g
; called to home the Z axis
; generated by RepRapFirmware Configuration Tool v3.1.4 on Thu Oct 01 2020 12:28:31 GMT+0100 (British Summer Time)
G91 ; relative positioning
G90 ; absolute positioning
G1 X50 Y50 F6000 ; go to first probe point
G30 ; home Z by probing the bed; Uncomment the following lines to lift Z after probing
;G91 ; relative positioning
;G90 ; absolute positioning -
@chris said in BLTouch Homing in wrong direction:
G31 P500 X0 Y0 Z3.7
In your config.g file there is this line related to the Z probe.
Being a BLTouch the P parameter should be 25.
And I cannot image how the X and Y offsets could be 0. Those values are saying that the BLTouch pin is right where the nozzle is, along the X and Y axes.
As to the probe self-testing but not working you need to verify that the wiring is correct. It's getting power but it seems it may not be getting the control signal.
Replace your zprobe section and deploy and retract macros with the ones I posted above. I took your values from your original config and brought them forward. The one you just generated doesn't have that.
Was the deploy and retract working before?
M280 P0 Z10.
That should be S10 not Z10
yeah before I upgraded to v 3.1.1 yeah sorry was M280 P0 S10
@fcwilt Sorry this was g31
G31 P50 X46.5 Y0 Z3.7 ; set Z probe trigger value, offset and trigger height
This post is deleted! -
@Phaedrux yeah still no joy with G31 S-1 or M280 P0 S10. even when copied config u posted above using bltouch on heater 7 pwm on duet expansion breakout board. Obviously is wired correctly as does self test fine when power applied to the printer. Just not deploying.
Those values look reasonable. But I believe that P50 should be P25.
@fcwilt Wouldn't have thought that would have stopped it deploying though isn't that just trigger value?
Self test only requires that the power and ground connections be correct.
If the control signal from the duet that triggers the probe deployment doesn't get to the probe then it won't work.
So either the configuration of the Z probe doesn't match the pin you are using to trigger the probe OR something has happened to the wiring .
Can you post a photo of how you're connected? Are you connecting to the expansion pins on the duet or to a separate breakout board?
No it wouldn't cause it to fail to deploy but it can affect the accuracy of the readings - once you get it working.
@Phaedrux
here is an image bltouch pwm on heater 7 pwm and the switch wires on z probe in. was working fine before upgrading to v3.1.1.I've not seen that little board before. Does it always use heater 7 for the Z probe?
yeah just makes heater 7 and heater 6 available from the ide / ribbon pin connector
In that case I would suggest removing the breakout board entirely. You can connect directly to the needed pins on the expansion port. Using the breakout board is likely changing the name of the pin being used for the M950 definition, but I'll have to check what that is. In the meantime, just connect the BLtouch directly to the expansion pins as shown here.
@Phaedrux just for the heater pwm pins
And you verified the connector you are using is the heater 7 connection?
I wasn't able to determine which connector did what.
used multimeter to prove continuity between the pins on idc ribbon cable and heater pwm pins
