BLTouch Homing in wrong direction
@chris said in BLTouch Homing in wrong direction:
I am getting an error saying unable to reach point now.
When are you getting that and what exactly does it say?
cheers says,
Skipping grid point (40.0, 270.0) because Z probe cannot reach it
this is G31
G31 P25 X46.5 Y0 Z3.70
It can't reach point x40 because the probe is offset by 46.5
Alter your M557 grid points to account for the probes X offset.
M557 X50:205 Y5:165 S20 for example
will try cheers
issue I am having is saying G30 Probe zero not found
When are you getting that message?
What is in your config.g now? homeall.g? -
As I understand it when trying to probe the point where Z=40 you got the error message about the probe not reaching it.
Then you changed M557 to use X50:205.
And you made no other changes?
In you rother thread you just updated to 3.1.1, did you also get a new config set?
yeah updated here is my new config .g
; generated by RepRapFirmware Configuration Tool v3.1.4 on Mon Sep 28 2020 10:10:20 GMT+0100 (British Summer Time); General preferences
M550 P"My Printer" ; set printer name; Network
M552 S1 ; enable network
M586 P0 S1 ; enable HTTP
M586 P1 S0 ; disable FTP
M586 P2 S1 ; enable Telnet; Drives
M569 P0 S0 ; physical drive 0 goes backwards
M92 X80.00 Y80.00 Z400.00 E415 ; set steps per mm
M566 X720.00 Y720.00 Z18.00 E600.00 ; set maximum instantaneous speed changes (mm/min)
M203 X6000.00 Y6000.00 Z180.00 E3000.00 ; set maximum speeds (mm/min)
M201 X750 Y750 Z100 E5000 ; set accelerations (mm/s^2)
M906 X1000 Y1000 Z800 E1000 I30 ; set motor currents (mA) and motor idle factor in per cent
M208 X305 Y330 Z400 S0 ; set axis maxima; Endstops
M574 Z1 S2 ; Define Z to use Probe. Home to Min; Z-Probe
M307 H7 A-1 C-1 D-1 ; Disable the 7th Heater to free up PWM channel 5
M558 P9 H5 F500 T4000 X0 Y0 Z1 ; Set Z probe type/mode 5. H=Dive Height. F=Speed the bed moves
G31 P25 X46.5 Y0 Z3.70 ; Z probe trigger value, offset in relation to nozzle. And trigger height adjustment
M557 X50:280 Y45:310 S50 ; define mesh grid; Heaters
M308 S0 P"bedtemp" Y"Thermistor" T100000 B4138 ; configure sensor 0 as thermistor on pin bedtemp
M307 H0 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit; Fans
M950 F0 C"fan0" Q500 ; create fan 0 on pin fan 0
M106 P0 S1 H1 T60 ; enable thermostatic control on fan 0 heater 1 sensor 1
M950 F1 C"fan1" Q500 ; create fan 1 on pin fan 1
M106 P1 S0 H-1 ; disable thermostatic control on fan 1; Tools
G10 P0 R0 S0 ; set initial tool 0 active and standby temperatures to 0C; Automatic power saving
M911 S21 R23 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; Set voltage thresholds and actions to run on power loss; Default firmware retraction configuration
M207 S3.2 R-0.1 F3600 T1200 Z0 ; Set 3.2mm retraction, -0.1 restart, 3600 mm/min feed rate, 1200 mm/min restart feed rate, no z change; Other settings
G29 S1 ; Enable automatic bed mesh compensation
M572 D0 S0.16 ; Enable pressure-advance
M915 X Y S10 F1 R1 ; Enable stall detection for X and Y axis with a sensitivity of 10 and report only
M915 Z S0 F1 R1 ; Enable stall detection for Z axis with a sensitivity of 10 and report only; Miscellaneous
M501 ; Load saved parameters from non-volatile memory -
Don't put this in config.g because it will load the heightmap before you have even homed the printer. A better place to put it is in your slicer start gcode after you've done a G28 to home all axis.
The zprobe section is still formatted for RRF2. In RRF3 you should have something more like this:
; Z-Probe M950 S0 C"exp.heater7" ; create servo pin 0 for BLTouch M558 P9 C"^zprobe.in" H5 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds G31 P25 X46.5 Y0 Z3.6 ; set Z probe trigger value, offset and trigger height M557 X50:280 Y45:310 S50 ; define mesh grid
; deployprobe.g ; called to deploy a physical Z probe ; ; generated by RepRapFirmware Configuration Tool v3.1.4 on Wed Sep 30 2020 15:12:19 GMT-0600 (Central Standard Time) M280 P0 S10 ; deploy BLTouch
; retractprobe.g ; called to retract a physical Z probe ; ; generated by RepRapFirmware Configuration Tool v3.1.4 on Wed Sep 30 2020 15:12:33 GMT-0600 (Central Standard Time) M280 P0 S90 ; retract BLTouch
getting this error now
G28 Warning: Obsolete use of S parameter on G1 command. Use H parameter instead. -
It looks like you didn't take the full config file set from the configurator as suggested in your other thread. It would have made all the changes needed for RRF3.
That warning is telling you that your homing files are using G1 S1 and G1 S2 and the S should be changed to H. (G1 S is now used for laser power when in laser mode)
; homeall.g ; called to home all axes ; ; generated by RepRapFirmware Configuration Tool v3.1.4 on Wed Sep 30 2020 15:29:23 GMT-0600 (Central Standard Time) G91 ; relative positioning G1 H2 Z5 F6000 ; lift Z relative to current position G1 H1 X-235 Y-215 F1800 ; move quickly to X and Y axis endstops and stop there (first pass) G1 H2 X5 Y5 F6000 ; go back a few mm G1 H1 X-235 Y-215 F360 ; move slowly to X and Y axis endstops once more (second pass) G90 ; absolute positioning G1 X-31.5 Y15 F6000 ; go to first bed probe point and home Z G30 ; home Z by probing the bed
Used reprap firmware config tool tool to create new config .g file but now bltouch isn't deploying it does self test fine on powering up the printer but doesn't deploy with M280 P0 Z10.
here is my new config .g now
; generated by RepRapFirmware Configuration Tool v3.1.4 on Thu Oct 01 2020 12:28:30 GMT+0100 (British Summer Time); General preferences
M550 P"Creality CR-10" ; set printer name; Network
M569 P2 S0 ; physical drive 2 goes backwards
M92 X80.00 Y80.00 Z400.00 E415.00 ; set steps per mm
M203 X60000.00 Y60000.00 Z30000.00 E1200.00 ; set maximum speeds (mm/min)
M906 X1000 Y1000 Z1000 E1000 I30 ; set motor currents (mA) and motor idle factor in per cent
M208 X310 Y320 Z400 S0 ; set axis maxima; Endstops
M574 Z1 S2 ; configure Z-probe endstop for low end on Z; Z-Probe
G31 P500 X0 Y0 Z3.7 ; set Z probe trigger value, offset and trigger height
M557 X50:280 Y50:280 S50 ; define mesh grid; Heaters
M307 H1 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit; Fans
M106 P0 S0 H1 T60 ; set fan 0 value. Thermostatic control is turned on
M106 P1 S1 H-1 ; set fan 1 value. Thermostatic control is turned off; Tools
M563 P0 S"Extruder 1" D0 H1 F0 ; define tool 0
here is home z
; homez.g
; called to home the Z axis
; generated by RepRapFirmware Configuration Tool v3.1.4 on Thu Oct 01 2020 12:28:31 GMT+0100 (British Summer Time)
G1 X50 Y50 F6000 ; go to first probe point
G30 ; home Z by probing the bed; Uncomment the following lines to lift Z after probing
;G91 ; relative positioning
;G90 ; absolute positioning -
G31 P500 X0 Y0 Z3.7
In your config.g file there is this line related to the Z probe.
Being a BLTouch the P parameter should be 25.
And I cannot image how the X and Y offsets could be 0. Those values are saying that the BLTouch pin is right where the nozzle is, along the X and Y axes.
As to the probe self-testing but not working you need to verify that the wiring is correct. It's getting power but it seems it may not be getting the control signal.
Replace your zprobe section and deploy and retract macros with the ones I posted above. I took your values from your original config and brought them forward. The one you just generated doesn't have that.
Was the deploy and retract working before?
M280 P0 Z10.
That should be S10 not Z10
yeah before I upgraded to v 3.1.1 yeah sorry was M280 P0 S10
@fcwilt Sorry this was g31
G31 P50 X46.5 Y0 Z3.7 ; set Z probe trigger value, offset and trigger height
This post is deleted! -
@Phaedrux yeah still no joy with G31 S-1 or M280 P0 S10. even when copied config u posted above using bltouch on heater 7 pwm on duet expansion breakout board. Obviously is wired correctly as does self test fine when power applied to the printer. Just not deploying.
