Temprature sensor error unknown temperature sensor channel
now my zprobe doesnt deploy
on the bright side the temp probe is showing temp, but when i tried to heat the hotend i got an error it was too slow.
Alright you're getting somewhere.
Have you uploaded the 3.0 and 3.1.1 zip files?
@Phaedrux said in Temprature sensor error unknown temperature sensor channel:
Alright, if 3.0 is installed you should try replacing the DWC files with the zip linked above. That may get you back on track.
Once in the web interface, just upload the whole 3.0 zip file as is to the /sys folder in DWC. Then upload the 3.1.1 zip file. Don't extract them first.
@Phaedrux yes mate, when sending the M115 command i now get firmware 3.1.1
The heaters will need to be PID tuned. That should get rid of the too slow error.
Here's how: https://duet3d.dozuki.com/Guide/Ender+3+Pro+and+Duet+Maestro+Guide+Part+4:+Calibration/40#s161
For the probe please post your config.g and deployprobe.g and retractprobe.g macros from the /sys folder. Also homeall.g
Copy and paste the text here.
@Phaedrux the z probe code
M950 S0 C"exp.heater3" ; create servo pin 0 for BLTouch
M558 M558 P9 H5 F100 T2000 ; set Z probe type to bltouch and the dive height + speeds
G31 X0 Y0 Z0 P25 ; set Z probe trigger value, offset and trigger height
M557 X15:215 Y15:195 S20 ; define mesh grid -
@Phaedrux deploy probe M280 P3 S10 I1 ; deploy BLTouch
retract probe M280 P3 S90 I1 ; retract BLTouch
homeall G91 ; relative positioning
G1 H1 X-505 Y-455 F3000 ; move quickly to X and Y axis endstops and stop there (first pass)
G1 H2 X5 Y5 F6000 ; go back a few mm
G1 H1 X-505 Y-455 F600 ; move slowly to X and Y axis endstops once more (second pass)
G90 ; absolute positioning
G1 X15 Y15 F6000 ; go to first bed probe point and home Z
G30 ; home Z by probing the bed; Uncomment the following lines to lift Z after probing
;G91 ; relative positioning
;G90 ; absolute positioning -
In the deploy and retract files change the P3 to P0 and remove the I1
@Phaedrux i changed the macro test files to P0 and delted the I1 but didnt work, re added the I1 and the macros work, but when i try to home z i get this error message?
G28 Z
Error: in file macro line 9: G30: Z probe 0 not found
Error: Homing failed -
thanks everyone for your help, it is really appreciated !
@JTM said in Temprature sensor error unknown temperature sensor channel:
Does that line in your config.g actually have double M558 at the start?
Can you post your full config.g?
@Phaedrux copy and pasted full config.g file :
M550 P"My Printer" ; set printer name; Network
M552 S1 ; enable network
M586 P0 S1 ; enable HTTP
M586 P1 S0 ; disable FTP
M92 X80.00 Y80.00 Z400.00 E420.00 ; set steps per mm
M906 X1200 Y1200 Z1500 E1200 I30 ; set motor currents (mA) and motor idle factor in per cent
M208 X500 Y450 Z500 S0 ; set axis maxima; Endstops
M574 Z1 S2 ; configure Z-probe endstop for low end on Z; Z-Probe
M557 X15:215 Y15:195 S20 ; define mesh grid; Heaters
M308 S0 P"bedtemp" Y"thermistor" T100000 B3950 ; configure sensor 0 as thermistor on pin bedtemp
M307 M307 H0 B0 S1.00 ; disable bang-bang mode for the bed heater and set PWM limit
M308 S1 P"spi.cs1" Y"rtd-max31865" ; configure sensor 1 as thermocouple via CS pin spi.cs1
M950 H1 C"e0_heat" T1 ; create nozzle heater output on e0heat and map it to sensor 1
M307 H1 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit; Fans
;Miscellaneous
M575 P1 S1 857600 -
M557 X15:215 Y15:195 S20 ; define mesh gridYou've got M558 in there twice. Take one of them out.
M575 P1 S1 857600
That should be B57600 not 8
This post is deleted! -
@Phaedrux Thanks for the help mate, did as you suggested and went to home all axis and got
G28 X
Operation has been cancelled -
I suggest going through this guide to ensure endstops are working and motors are moving are going the right direction.
https://duet3d.dozuki.com/Guide/Ender+3+Pro+and+Duet+Maestro+Guide+Part+3:+Commissioning/39
@Phaedrux Thanks for all your help Mate, still going through the checks, the motors and end stops seem to all be wired correctly and moving the right way, i keep getting this message when homing z
G28 Z
Error: Homing failedi will keep looking
the M280 deploy and retract macros work but homing doesnt activate the probe so im guessing the Gcode for homing is missing something?
please post your revised config so we can see your current
M558
line that configures your z probe -
@bearerthis is the config.g file
;Miscellaneous
M575 P1 S1 B57600
M501 -
i think you might need
C"^zprobe.in"
added to the line withM558
?M558 P9 C"^zprobe.in" H5 F100 T2000 ; set Z probe type to bltouch and the dive height + speeds
edit: presuming thats where your zprobe is connected?
