unusual/unnerving noises + error codes
@PR1OR said in unusual/unnerving noises + error codes:
'Response too long see console'
And if you go to the console do you see the result?
How do you have the endstops wired? The two wires from the endstops should be connected to the outer two pins of the board connector. Doesn't really matter which wire goes where.
https://duet3d.dozuki.com/Guide/Ender+3+Pro+and+Duet+Maestro+Guide+Part+1:+Wiring/37#s119
 @Phaedrux said in unusual/unnerving noises + error codes:
so that was the result :s
Below is a picture of the wiring, ive been using dupont wire until ive made sure they are wired correctly. but from what you are saying the seem to be fine. The LEDs are on (green, i read somewhere they should be red but i assume this was an old/new board) when the the endstop switch isnt pressed. When it is it turns off. So i found from wiring diagram that the LEDs didnt correspond to the plugs like it does in the diagram
just had a thought and checked the axis limits as the ender 3 pro has a bigger print area. i have now updated that but still having issues
could it be something to do with the gcodes for the end stops?
Like the changing S to H?
M574 X1 Y1 S3 ; set endstops controlled by motor stall detection
M574 Z1 S2 ; set endstops controlled by probe -
M574 X1 Y1 S3 ; set endstops controlled by motor stall detectionS3 is stall detection. Try S1.
@Phaedrux updated to S1 and i got this
G28
Error: Failed to enable endstops -
however i played with it a little and S2 works but it only moves each axis by a couple of mm before stoping
but it does say its homed which i think is getting somewhere
M574 Y1 S1 P"ystop" ; configure active-high endstop for low end on Y via pin ystopTry that instead
It looks like you had stall detection for homing selected in the configurator so it didn't have any endstop switches defined.
From what i seen in the video im wondering are you sure the z stepper is wired correctly
It sounds like one of the steppers is not paired properly y moves then x .... does it start the noise before it hits the x stop?? If so you wont know the z is correct untill it hits the x stop if the shaking starts then ...when you hit the xstop i would say the z stepper is causing the problem with the strpper fighting itself... i noticed that the x gantry didnt start down. It might be the video. Or just meill watch it again
What i do is start homming then manualy trip the limit to see if it in fact work.. just cause the led goes out doent mean the g code responded
M574 Y1 S1 P"ystop" ; configure active-high endstop for low end on Y via pin ystopPerfect thank you!! this has worked!! i can now home my X and Y axis
is there anything for the Z probe though?
i get this as a return when homing all
Error: in file macro line 9: G30: Z probe 0 not found
Error: Homing failed -
So it was as Phaedrux had said above the code wasnt correct. Once id checked/sorted the wiring out it was only happening when both X and Y got to the end stop
If you're still having problems with the probe please post your config.g.
@Phaedrux
; generated by RepRapFirmware Configuration Tool v3.1.4 on Tue Sep 15 2020 08:55:40 GMT+0100 (British Summer Time); General preferences
M550 P"Duet 2 Wifi" ; set printer name; Network
M552 S1 ; enable network
M586 P0 S1 ; enable HTTP
M586 P1 S0 ; disable FTP
M569 P0 S0 ; physical drive 0 goes backwards
M569 P1 S1 ; physical drive 1 goes backwards
M92 X80.00 Y80.00 Z400.00 E93.00 ; set steps per mm
M566 X1200.00 Y1200.00 Z24.00 E300.00 ; set maximum instantaneous speed changes (mm/min)
M203 X30000.00 Y30000.00 Z300.00 E1500.00 ; set maximum speeds (mm/min)
M201 X500.00 Y500.00 Z100.00 E5000.00 ; set accelerations (mm/s^2)
M906 X400 Y400 Z400 E800 I30 ; set motor currents (mA) and motor idle factor in per cent
M84 S300 ; Set idle timeout; Axis Limits
M208 X-5.5 Y-10 Z0 S1 ; set axis minima
M208 X220 Y220 Z250 S0 ; set axis maxima; Endstops
;M574 X1 Y1 S3 ; set endstops controlled by motor stall detection
;M574 Z1 S2 ; set endstops controlled by probe; Endstops
M574 Y1 S1 P"ystop" ; configure active-high endstop for low end on Y via pin ystop; Z-Probe
M307 H64 A-1 C-1 D-1 ; disable heater on PWM channel for BLTouch
M558 P9 H2.5 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds
G31 P25 X-31 Y0 Z0.6 ; set Z probe trigger value, offset and trigger height
M557 X20:215 Y20:215 S20 ; define mesh grid; Heaters
M305 P0 T98801 B4185 R4700 ; set thermistor + ADC parameters for heater 0
M305 P1 T98801 B4185 R4700 ; set thermistor + ADC parameters for heater 1
M106 P2 S1 I0 F500 H0:1 T45 ; set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned on; Tools
;G10 P0 X0 Y0 Z0 ; set tool 0 axis offsets
;G10 P0 R0 S0 ; set initial tool 0 active and standby temperatures to 0C; Custom settings are not defined
M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; set voltage thresholds and actions to run on power loss -
ok we'll have to convert more of your config.g over to use RRF3 syntax.
If you send M98 P"config.g" what errors do you get?
M98 P"config.g"
M98 P"config.g"
HTTP is enabled on port 80
FTP is disabled
TELNET is disabled
Error: in file macro line 44: M307: parameter 'H' too high
Error: Missing Z probe pin name(s)
Error: Invalid Z probe index
Error: M305 has been replaced by M308 and M950 in RepRapFirmware 3
Error: Heater 0 does not exist
Error: Heater 1 does not exist
Error: Fan number 0 not found
Error: Fan number 1 not found
Error: Fan number 2 not found -
The fans aren’t connected so that will be why they can’t be found
I've made a config for you to try using the web configurator tool.
First make a backup of your /sys folder in DWC by putting check boxes next to all the files and then right clicking and selecting download as zip. Then save it to you computer. That will be a backup of your current config files.
Here download this and change the extension from .txt to .zip. And then upload the whole zip file as is (don't extract it) to the /sys folder in DWC.
Reboot and it should be a bit closer to working I think.
; Configuration file for Duet WiFi (firmware version 3) ; executed by the firmware on start-up ; ; generated by RepRapFirmware Configuration Tool v3.1.4 on Wed Sep 16 2020 13:12:28 GMT-0600 (Central Standard Time) ; General preferences G90 ; send absolute coordinates... M83 ; ...but relative extruder moves M550 P"Duet2Wifi" ; set printer name ; Network M552 S1 ; enable network M586 P0 S1 ; enable HTTP M586 P1 S0 ; disable FTP M586 P2 S0 ; disable Telnet ; Drives M569 P0 S0 ; physical drive 0 goes backwards M569 P1 S0 ; physical drive 1 goes backwards M569 P2 S1 ; physical drive 2 goes forwards M569 P3 S1 ; physical drive 3 goes forwards M584 X0 Y1 Z2 E3 ; set drive mapping M350 X16 Y16 Z16 E16 I1 ; configure microstepping with interpolation M92 X80.00 Y80.00 Z400.00 E93.00 ; set steps per mm M566 X900.00 Y900.00 Z12.00 E1200.00 ; set maximum instantaneous speed changes (mm/min) M203 X6000.00 Y6000.00 Z180.00 E1200.00 ; set maximum speeds (mm/min) M201 X500.00 Y500.00 Z20.00 E250.00 ; set accelerations (mm/s^2) M906 X600 Y600 Z600 E600 I30 ; set motor currents (mA) and motor idle factor in per cent M84 S30 ; Set idle timeout ; Axis Limits M208 X-5.5 Y-10 Z0 S1 ; set axis minima M208 X220 Y220 Z250 S0 ; set axis maxima ; Endstops M574 X1 S1 P"xstop" ; configure active-high endstop for low end on X via pin xstop M574 Y1 S1 P"ystop" ; configure active-high endstop for low end on Y via pin ystop M574 Z1 S2 ; configure Z-probe endstop for low end on Z ; Z-Probe M950 S0 C"exp.heater3" ; create servo pin 0 for BLTouch M558 P9 C"^zprobe.in" H5 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds G31 P500 X-31 Y0 Z0.6 ; set Z probe trigger value, offset and trigger height M557 X9.5:215 Y5:195 S20 ; define mesh grid ; Heaters M308 S0 P"bedtemp" Y"thermistor" T98801 B4185 ; configure sensor 0 as thermistor on pin bedtemp M950 H0 C"bedheat" T0 ; create bed heater output on bedheat and map it to sensor 0 M307 H0 B0 S1.00 ; disable bang-bang mode for the bed heater and set PWM limit M140 H0 ; map heated bed to heater 0 M143 H0 S120 ; set temperature limit for heater 0 to 120C M308 S1 P"e0temp" Y"thermistor" T98801 B4185 ; configure sensor 1 as thermistor on pin e0temp M950 H1 C"e0heat" T1 ; create nozzle heater output on e0heat and map it to sensor 1 M307 H1 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit ; Fans M950 F0 C"fan0" Q500 ; create fan 0 on pin fan0 and set its frequency M106 P0 C"Heatsink" S0 H-1 ; set fan 0 name and value. Thermostatic control is turned off M950 F1 C"fan1" Q500 ; create fan 1 on pin fan1 and set its frequency M106 P1 C"PartCooling" S1 H1 T45 ; set fan 1 name and value. Thermostatic control is turned on ; Tools M563 P0 S"PrintHead01" D0 H1 F0 ; define tool 0 G10 P0 X0 Y0 Z0 ; set tool 0 axis offsets G10 P0 R0 S0 ; set initial tool 0 active and standby temperatures to 0C ; Custom settings are not defined ; Miscellaneous M575 P1 S1 B57600 ; enable support for PanelDue M501 ; load saved parameters from non-volatile memory M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; set voltage thresholds and actions to run on power loss T0 ; select first tool
I took the values from your current config.g. It assumes that your BLTouch is connected to heater pin 3 on the expansion header.
Error: Homing failedSo im still getting this error :s
