No Axis Movement
For M 564 I just tried "home all"
@1d1 said in No Axis Movement:
i dont undestand what you mean
M564 requires a parameter. on its own it does nothing.
bearer posted a link to the documentation. if you had read that you would have seen that you need to issue
M564 S0 H0
edit: It states
On some types of printer (e.g. Delta and SCARA), movement before homing may be prohibited regardless of the H parameter. -
can you post your homedelta.g ?
I entered M564 in the UI Gcode console, then tried to home. After sending the M564 it told me that movement outside the bed not possible, but homing was.
As for documentation link, I didn't and still don't see one. I'll add the M564 S0 H0 to the config.
Home delta g: ; homedelta.g
; called to home all towers on a delta printer
; generated by RepRapFirmware Configuration Tool v2.1.8 on Thu Apr 23 2020 23:27:15 GMT-0700 (Pacific Daylight Time)
G91 ; relative positioning
G1 H1 X251 Y251 Z251 F3600 ; move all towers to the high end stopping at the endstops (first pass)
G1 H2 X-5 Y-5 Z-5 F3600 ; go down a few mm
G1 H1 X10 Y10 Z10 F360 ; move all towers up once more (second pass)
G1 Z-5 F9000 ; move down a few mm so that the nozzle can be centred
G90 ; absolute positioning
G1 X0 Y0 F9000 ; move X+Y to the centre -
look at bearer's post. the commands G92 and M564 are links.
is there a response when you send G28?
No action with the M564 S0 H0 in either config.g or homedelta g
no as i posted thats not allowed on a delta
I'll try it. Didn't realize those were links....
Movement! Not the correct movement, but all three axes moved From G92 X0 Y0 Z0 with the extruder at the bed, and centered.
M574 X2 Y2 Z2 S0 ; set active high endstops
Have you got active low (normally open, or NO), or active high endstops (normally closed, NC)? See https://duet3d.dozuki.com/Wiki/Connecting_endstop_switches#Section_Microswitch
If you send M117, and the endstop reports triggered already, it may explain lack of movement. Change S0 to S1.If you change anything in config.g, you need to reset the board, or send M98 P"config.g" to use those changes. Or input gcodes (temporarily, until the next reset) in the gcode console/command line.
I've verified the endstops as being NC (changed to S1) and both X and Y move normally. Z isn't moving at all and the endstops are not triggering the axis movements of X and Y. On the board, the endstop lights are on and go off when manually triggering each end stop switch. For M117, the endstops are not triggered until I push them and each one is registering on the proper tower.
I'm going to try Z on a different driver... -
OK. Z works fine on X driver, so I think the Z is bad. Can I run Z from E1 if I change the position in the config?
Can you post the results of M122 and send M98 P"config.g" and post any error messages that come up?
Yes, you'd change the M574 z to use the driver number you want.
Closer yet. All axis moving normally now with Z on E1 (4). But the endstops are still not stopping movement or triggering. Yes, I changed the z end stop to E1.
Here is M122:
RepRapFirmware for Duet 2 WiFi/Ethernet version 2.0(RTOS) running on Duet WiFi 1.02 or later
Board ID: 08DGM-956GU-DJMSN-6JTDA-3S46Q-TUQHH
Used output buffers: 3 of 20 (8 max)
Static ram: 28380
Dynamic ram: 95928 of which 16 recycled
Exception stack ram used: 276
Never used ram: 6472
Task NETWORK ready, free stack 324
Task HEAT blocked, free stack 1256
Task MAIN running, free stack 3592
Last reset 00:01:34 ago, cause: software
Last software reset at 2020-09-15 17:08, reason: User, spinning module GCodes, available RAM 6472 bytes (slot 0)
Software reset code 0x0003 HFSR 0x00000000, CFSR 0x00000000, ICSR 0x0441f000, BFAR 0xe000ed38, SP 0xffffffff
Error status: 0
Free file entries: 10
SD card longest block write time: 0.0ms
MCU temperature: min 32.3, current 32.6, max 32.9
Supply voltage: min 24.1, current 24.2, max 24.4, under voltage events: 0, over voltage events: 0
Date/time: 2020-09-15 17:09:43
Slowest loop: 4.79ms; fastest: 0.07ms
Hiccups: 0, StepErrors: 0, LaErrors: 0, FreeDm: 240, MinFreeDm 240, MaxWait: 0ms, Underruns: 0, 0
Bed compensation in use: none
Segments left: 0
Movement lock held by null
http is idle in state(s) 0
telnet is idle in state(s) 0
file is idle in state(s) 0
serial is idle in state(s) 0
aux is idle in state(s) 0
daemon is idle in state(s) 0
queue is idle in state(s) 0
Code queue is empty.
=== Network ===
Slowest loop: 72.51ms; fastest: 0.01ms
HTTP sessions: 1 of 8- WiFi -
Network state is running
WiFi firmware version 1.21
WiFi MAC address 5c:cf:7f:76:71:a9
WiFi Vcc 3.29, reset reason Turned on by main processor
WiFi flash size 4194304, free heap 13864
WiFi IP address 192.168.1.54
WiFi signal strength -44dBm, reconnections 0, sleep mode modem
and M98 "config.g"... nothing comes up
- WiFi -
Under machine properties:
X No -99 mm 99 mm 20 mm/s 300 mm/s 2000 mm/s² 800 mA
Y No -99 mm 99 mm 20 mm/s 300 mm/s 2000 mm/s² 800 mA
Z Yes 201 mm 200 mm 20 mm/s 300 mm/s 2000 mm/s² 800 mA
E0 Yes n/a n/a 10 mm/s 13.33 mm/s 2000 mm/s² 600 mAWhich can't be right...
The first thing I would suggest you do is update the firmware.
Download that zip file, then upload it as is to the /sys folder in DWC. That should prompt it to update everything.
Done. Nothing lost but nothing gained. Goes up on all axes, hits endstops and then bangs away until I hit Emergency Stop.
M115: FIRMWARE_NAME: RepRapFirmware for Duet 2 WiFi/Ethernet FIRMWARE_VERSION: 2.05.1 ELECTRONICS: Duet WiFi 1.02 or later FIRMWARE_DATE: 2020-02-09b1
