Impossible to set extruder micro stepping above 16ms
@observatoer next I would check content of start.g and if babystepping or pressue advance change the E by disabling them.
@JoergS5 Looks OK to me.
G29 S1 P"heightmap.csv" ; Load the height map from file and activate bed compensation.
G90 ; use absolute coordinates
M83 ; extruder relative modeM98 P"0:/sys/G828.g" ; home if not homed
M98 P"0:/sys/G832.g" ; if not already leveled, level bed and re-home Z; prime nozzle
G1 X0 Y0 F99999.0 ; Go home
G1 Z0.15 ; lower extruderG1 X2 Y20 Z0.3 F5000.0 ; move to start-line position
G1 X2 Y200.0 Z0.3 F1500.0 E15 ; draw 1st line
G1 X2 Y200.0 Z0.4 F5000.0 ; move to side a little
G1 X3 Y20 Z0.4 F1500.0 E30 ; draw 2nd line
G92 E0.0And the two calls look clean, too:
; G828.g
; Conditional variant of G28 home command.
; Homes all axes if not already homed.
if !move.axes[0].homed || !move.axes[1].homed || !move.axes[2].homed
G28; G832.g
; Conditional variant of G32 bed command.
; Perform bed leveling if not already leveled.
if move.calibration.numFactors == 0 ; if leveling has not yet been performed...
G32 ; level bed
G28 Z ; re-home Z
else
echo "Bed already leveled. Skipping..." -
@observatoer then I have no more ideas at the moment. I would remove and disable or comment out all and readd step by step to find the reason. It is also possible that there is a bug somewhere, because you have a lot of settings, macros etc. To be sure it's not IdeaMaker I would try a different program and g-code file first.
@JoergS5 Thank you for your time and hints!
@observatoer sorry that I could not help. I think it's something trivial, a syntax error e.g., but I didn't see one.
Maybe M350 E16 I0 changing the E without interpolation behaves other than expected. You could try changing it to I1 as a test.
@observatoer I have one more idea: according the information in some threads like https://forum.duet3d.com/topic/4939/m350-not-working-wrt-m584/6 the order of the drives seem to play a role in the M584 command. In you config you have E first, so this may not be seen as an extruder drive in some code for other program parts. You could try changing
M584 E0 X1 Y2 Z3:4:5
to
M584 X1 Y2 Z3:4:5 E0 -
If anyone thinks that M350 is not behaving as described in the wiki GCodes page, please supply files that replicate the different behaviour.
@JoergS5 That would make sense and I will give it a try. Stii the change will be a bag of hurt to get the order of the z drives and the related measurements for ABL right.
Thank you very much for your help! I will report, how this turns out. -
@dc42 I guess, this tread is full of all related logs and describes the issue in detail. Still I understand, it's a pain to go thru the logs.
One of the reports says that the steps/mm changes when starting a print, but I didn't see a print file posted. Also, the config files have changed, so it's hard to be sure what the current ones look like.
@dc42 Thank you, this was the right question.
Ideamaker is setting the E value to 822s/mm and writes this at the beginning of the code.
That was the reason, why this issue came up.Thanks again and I guess, the solution is found.
