Duet 2 Wifi + BLtouch issues on Ender 5 pro
@alxndr My motors seem correct....
Two wrongs can make a right , eg if you are homing in the wrong
direction and your motor are in the wrong direction it will look right.Look at your config file :
M558 P9 C"^zprobe.in" H5 F100 T2000 ;
M950 S0 C"exp.heater3" ; define GPIO/Servo pin index
M557 X0:220 Y0:220 S25 ; define mesh grid
G31 X-45 Y-4 Z3.737 ; <------------- just change this to Z0 ---------
M307 H3 A-1 C-1 D-1 ;What I'm saying is get it to home with crashing into the bed , then you can find the true offset .
Have you changed the homing files ? and does m401 and m402 work ?
@peter247 i havent had a chance to test m401 and m402 yet as im still at work. ill do those tests after work and get back to you! thanks so much for helping. im learning and progressing so much! ill reply back with my test results asap!
Going to bed soon I`m in the UK , so bits to check.
(1) See if m401 and m402 works
(2) You need to change all the homing files
(3) press home x then press the x micro-switch does it stop , PANIC if not
(4) press home y then press the y micro-switch does it stop, PANIC if not
(5) press home all and see which way the head goes now to home ( with your finger on the emergency stop), I think your motors direction is wrong x , y , z ) it is the M569 commands in the config.g
(6) get it to home all axis correct without the nozzle hitting to bed. -
@peter247 so homing z works fine now. ive got it all set up with the homey homex and homez and homeall....now im having a stupid little annoying issue......220 isnt the bed size? the bed size is actually 235!! wtf...creality advertises it as 220 but when i measure it, its actually 235!! do i need to change everything now?
@alxndr said in Duet 2 Wifi + BLtouch issues on Ender 5 pro:
M208 X220 Y220 Z300 S0 ; set axis maximaYou can change your axis limits with the M208 commands.
This may mean you need to change your M557 grid spacing a bit.
You also need to make sure that the homing moves in your homing files are long enough to hit the endstops if they are at the opposite end already.
You might find this series of guides helpful
https://duet3d.dozuki.com/Guide/Ender+3+Pro+and+Duet+Maestro+Guide+Part+3:+Commissioning/39
@alxndr the bed size is actually 235!! wtf
The 220 x 220 is the printable size !!
A cr10s pro says 300x300 , but the bed is 320x310
a ender 5 plus says 350x350 , but the bed is 370x377if you print at 0:0 you can't print on fresh air so the bed is always bigger than the printable area.
When it X and Y homes is that under the bed , just check that all the printable area is under the bed . -
@alxndr I tend to use the P parameter rather than the S parameter with M557. This sets the number of points to probe, rather than the spacing between them. Then, if you change the probe area, it still probes the same number of points, evenly spaced, without having to calculate the probe spacing yourself. It's also quicker to change if you want to change the number of probe points in the mesh. So:
M557 X35:185 Y35:185 S50
(which probes X and Y at 35, 85, 135 and 185, so 4 points in each axis for a total of 16 points)
becomes:
M557 X35:185 Y35:185 P4
To increase or decrease the number of probe points, you just change the P parameter.Ian
@peter247 i just dont get something...if the physical bed is 235x235, why are my axis limits 220x220? I mean...dont i base my bed center off of the actual bed size? nowhere in the gcode shows the ACTUAL bed size of 235x235. Am i doing something wrong? because if i go from left to right, it goes from 0 to 220...
as for everything else, homing works and the bltouch works deploys and retracts properly! m401 and m402 confirmed working!!
what are the next steps? do i have to remove the lines for my z endstop?
@droftarts this is great to know! thank you!
@alxndr When you home X, then move to X0, is the nozzle on the edge of the bed? If it's over the bed, there will be some of the bed you cannot use. Same at the other end of the X axis, and for Y minimum and maximum. You can always adjust M208 to increase the axis limits, so long as the nozzle can physically reach the position.
If you home X, and X=0 is off the bed, you need to know how far it is to the edge of the bed. For example, if you jog the X axis 10mm for the nozzle to be over the bed, then you would set
M208 X-10 S1
. This tells the firmware where the bed is in relation to the X endstop. Then move the X to the far side of the bed (with X0 on the edge of the bed) to see the full X axis limit; this might be X240, but the nozzle is off the bed on the other side, but is on the edge at X235. So setM208 X235 S0
. Repeat for the Y axis. This should give you the maximum printable area.Use of M208 is explained more fully here: https://duet3d.dozuki.com/Wiki/Centering_the_bed_or_setting_the_bed_origin
Edit: when you are testing where the limits are, you may need to go beyond the current M208 limits. Send
M564 S0 H0
, which will allow moves outside the print volume and before axes are homed. Use carefully!Ian
@droftarts this is something ill have to check once i get home from work. I'm in EST time zone (Canada). So i'll only get to check this later today. thanks for the explanation. I dont fully understand but i do kind of understand lol i just dont see how the printer knows that the bed is 235 but only 220 is used. But ill test as you recommended and try to understand. I think it would be easier if i get to see it for myself.
@alxndr
o.k I'll have my go again at explaining it.( my example thought experiment)
The maximum travel is 400mm , but the print area is only 300mm eg the size of the glass is 300mm , but the maximum distance between the left and right end stops is 400mm.
if it homed left or right it would be 100mm from edge of the glass , So you would need to add a offset which would add or subtract 100mm so 0mm and 300mm was over glass.
BUT I THINK in your case, when your print homes it is 10mm from the right edge of the printer and say "I'm homed and set to 220mm" , now if you do a G1 X0 this would move it 220mm to the left and now the nozzle would be 15mm from the left edge.
SO IT DEPEND ON how it is homed, is it about 10-15mm from the edge of the bed or over it ? -
Well it doesn't, but if the endstop is off the edge of the bed, and you want 0,0 to be the corner of the printable area, the difference in negative movement from 0,0 to the endstop is captured by setting the M208 minima to a negative value, as droftarts showed above.
Visual aid. This shows the endstops coinciding with the printable area, but if the nozzle travels off the bed to hit tne endstop, that extra movement is captured by the negative M208 minima.
@peter247 so homing works fine now. Bltouch deploys and retracts with homeall and homez.
Do I need to remove the endstop line? M574 I think? Or am I ready to print? I have no macros set either so I'm not sure if I should have those.
@alxndr
Do I have to remove the end stop line for Z stop ?No you don't have to remove it , but it is not doing anything !!!
So the answer is :- do need to remove it No , Should I remove it Yes. -
@peter247 also i checked and basically the edge of the bed is where the endstop is at and that reads as 0 for both x and y. so thats good right?
second, is there a guide out there for easily configuring the z steps and making sure my nozzle is at the right height in relation to the bed? ive tried to search but cant seem to find anything specifically for this
@alxndr
Nope , 0mm left <> right 220mm , 0mm front , 220 backSo does it home to the right / back and did you use my homing files ?.
it should home right and say 220mm
Sound to me that the motor direction and the homing macro are running in the wrong direction too.
@peter247 it does home to the right back. yes i used your homing files. not sure what value it shows though as i dont remember. I would have to check tonight after work.
if i do need to fix it, is it an easy fix? just so that i have them ahead of time.
@alxndr
I'm lost want happening if it not showing 220 , 220 homed !!! .
I take it you are using more or less the config.g file you posted at the start.
**** o.k , just looked at your config.g and found the problem ****; Endstops M574 X1 S1 P"xstop" ; configure active-high endstop for low end on X via pin xstop M574 Y1 S1 P"ystop" ; configure active-high endstop for low end on Y via pin ystop M574 Z1 S1 P"zstop" ; configure active-high endstop for low end on Z via pin zstop
M574 X1 S1 , what does this mean ?
Xnnn Position of X endstop: 1 = low end, 2 = high end.
Snnn Endstop type: 0 = active low endstop input, 1 = active high endstop inputS1 is correct for it works.
Now for the bit you have wrong X1 and Y1 , which means it homes to the left / front , X1,Y1 this need to be changed to X2,Y2 home to the right / back.**** IMPORTANT BIT ****
it is homing right and back because the motor directions are wrong like I said yesterday .; Drives M569 P0 S1 ; physical drive 0 goes forwards <---- M569 P1 S1 ; physical drive 1 goes forwards <---- M569 P2 S0 ; physical drive 2 goes backwards M569 P3 S1 ; physical drive 3 goes backwards
Make P0 and P1 motors S0 not S1 , like this.
; Drives M569 P0 S0 ; physical drive 0 goes forwards <---- M569 P1 S0 ; physical drive 1 goes forwards <---- M569 P2 S0 ; physical drive 2 goes backwards M569 P3 S1 ; physical drive 3 goes backwards
