Ir probe
hi new bed.g file does thi look correct
M561
; Probe the bed at 4 points
G30 P0 X15 Y15 H0 Z-99999
G30 P1 X15 Y235 H0 Z-99999
G30 P2 X235 Y235 H0 Z-99999
G30 P3 X235 Y15 H0 Z-99999 S -
ok i found out that since i have my ir sencor 30mm in fount of my nozzel and the nozel is set at x0 and y0 with no roo m to move anywhere i have to reset bed.g looking like this
M561; Probe the bed at 4 points
G30 P0 X35 Y15 H0 Z-99999
G30 P1 X35 Y235 H0 Z-99999
Ok now i have this set up all i do now is. Home all hit the funny key (wavey line with arrow pionting up the anther one pionting down) let do its
Thing then print ?? -
Thing then print ??errrr, don't know where you see that key. Are you using the Web interface or Panel Due? On the web interface, in the Machine Control section, there are buttons clearly labelled (from top to bottom), Home All, Home X, Home Y and Home Z. I don't have a Panel Due so can't comment on how they might be labelled but what you describe with arrows pointing up and down sounds more like the baby stepping feature.
Ian the button he is referring to is the Autocal button for a delta and you only see if the Duet is configured as a delta and in that case you dont get the Homex/y/z buttons either.
Doug
No im configured as a coerxy
And yes its on the pannel due. On the line where home all hone x ..home y..home..z and far left of screen is the auto cail bottonYes hitting that botton dose the four piont test ive set up in bed.g
So is that it done hit home.all ..then auto cal then print
Are have i missed a step -
Doug
Doug, - didn't know that - you guys with Delta's always have to complicate things :).
Anyway, it seems our man is sorted.
Cheers
Eh just pointing it out lol by the way can you let me know what that insulation material that you use under the bed is called It would be appreciated
Me ? Cardboard
Thermopanel or some such name. It's main use is for underfloor heating.
I use cork sheet.
Is it that green fibrous stuff?
I have used cork on my existing machine but was looking for any other alternative for the new one?
Doug
Doug
Sort of but it's more rigid. It's a sort of fibres glass mesh sandwich with the green fibre stuff as the filling. I can't find the exact board that I bought but this one looks the same. http://www.theunderfloorheatingstore.com/insulation-boards/electric/prowarm-trade-backer-pro-tile-backer-board. I think when I researched it that the thermal conductivity was much lower than the equivalent thickness of cork. My bed frame is 400mm x 400mm made of 2020 extrusion and I just laid the board on it and put the aluminium tooling plate on top and drilled through the whole lot. Being semi rigid, the insulation doesn't need glueing or anything to prevent it from sagging.
Apologies to the OP, we seem to have hijacked his thread.
ok how do i adjust the probe high from bed with out manly moving it i.e i want to make it closer
G31 P600 X0 Y0 Z1.50 ; Set Z probe trigger value, offset and trigger height
Adjust the Z value
yes i see now it stops at my set high 1.50 on home but gose to 0 when printing and i can still lower 0 with move keys my bad i see how it works now
is it possible to set up a 9 point bed meshing ?
