Need help to config file for ender 3 pro
@Roei3d said in Need help to config file for ender 3 pro:
M906 X700 Y700 Z700 E800 I30 ; set motor currents (mA) and motor idle factor in per cent
Try 600 for X and Y, if slightly loosening the belt doesn't help.
What slicer are you using? Does it have any acceleration and jerk control enabled that may be changing it to a different value than what you have specified in your config?
Can you share a sliced gcode file?
@Phaedrux I use cura no jerk and acceleration not enabled in cura, when igi home I upload my last minion print gcode
@Phaedrux XYZ NO INFIIL.gcode
this is my gcode xyz cube 0 infiil itray chang m906 to x600 y600 no change -
If you do a simple cylinder do you also see the ringing pattern? That would indicate something other than corner ringing that would start strong at a change in direction and then lessen as it moves away from the edge. It's quite hard to tell from those silver prints since the fronts aren't illuminated.
Can you post a video of it printing?
@Phaedrux https://youtu.be/nBy0lpH--Uk
In cylinder I hardly see anything.
Try lowering the acceleration and jerk for the Y axis. Perhaps the big heavy mirror is making it shake on direction changes.
@Phaedrux yaaaaaaaa I fix it thnks for your help. My hotend and cooling part fan was Vibrates slightly
It's due to their frequency settings.
I couldn't find a frequency that would make them stop vibrating.
So I returned to ender 3 stock fun and changed frequency now Hard to see ringing Thank you so much for your time and for your help.
And everyone who helped
You think I should change my config like before? -
Well you can try increasing your speed values as part of your tuning.
Maybe see here: https://forum.duet3d.com/topic/14250/tuning-jerk-accel-speed-settings/3
@Phaedrux thnks my last print look very good thnks for your help
ihave problem whit my duet web when irun macro iget blank status i seeonly "ok"
if change to dwc1 isee all' how to fix it ? -
@Roei3d Are you running Firmware 3.1.1 and DWC 3.1.1 now? If you're still running firmware 2.x you either need to upgrade to 3.1.1 or change your DWC version to something like 2.0.7 that came with firmware 2.05.1
@Phaedrux yes iam ruining
RepRapFirmware for Duet 2 WiFi/Ethernet version 2.05.1 running on Duet WiFi 1.02 or later
so ineed to upgrade my firmware to 3 ?
or downgrade swc to 2.0.7?
Yes. First I would try just uploading the 2.0.7 DWC zip file and see if you still have the problem. Updating to RRF3 is a bit more involved and would require updated config.g. By contract, changing the DWC version is as easy as uploading the version you want to try.
https://github.com/Duet3D/RepRapFirmware/releases/download/2.05.1/DuetWebControl-SD-2.0.7.zip
@Phaedrux great thanks i try now
@Roei3d Hello! Are you using the stock fans? What are the frequency values that you are using now? Could you please share your current config.g? Thanks!
@bettodiaz hii yes now ihave tock fun only the board fun i change
this my config
M569 P0 S0 ; physical drive 0 goes backwards
M92 X79 Y79 Z396 E408 ; set steps per mm
M566 X1000 Y1000 Z24 E2500 P1 ; set maximum instantaneous speed changes (mm/min)
M203 X6000 Y6000 Z900 E6000 ; set maximum speeds (mm/min)
M201 X500.00 Y500.00 Z100.00 E5000.00 ; set accelerations (mm/s^2)
M906 X688 Y688 Z688 E810 I30 ; set motor currents (mA) and motor idle factor in per cent
M208 X235 Y235 Z240 S0 ; set axis maxima; Endstops
M574 Z1 S2 ; set endstops controlled by probe; Filament runout sensor ;Filament run-out sensor triggers a pause
M591 D0 P2 C3 S1; Z-Probe
M307 H3 A-1 C-1 D-1 ; disable heater on PWM channel for BLTouch
M558 P9 H2.5 F350 T6000 ; set Z probe type to bltouch and the dive height + speeds
G31 P500 X-40 Y-12 Z9.562 ; set Z probe trigger value, offset and trigger height
M557 X30:220 Y30:220 S40 ; define mesh grid; Heaters
M305 P0 T98801 B4185 R4700 ; Set thermistor + ADC parameters for heater 0
M143 H0 S100 ; Set temperature limit for heater 0 to 120C
M305 P1 T98801 B4185 R4700 ; Set thermistor + ADC parameters for heater 1
M143 H1 S250 ; Set temperature limit for heater 1 to 280C; Fans
M106 P0 S0 I0 H-1 ; set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
M106 P1 S0 I0 H1 T45 ; set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
M106 P2 S0.8 I0 F20 H1:0 T45 ; set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned on; Tools
M563 P0 S"hotend" D0 H1 F0 ; define tool 0
G10 P0 R0 S0 ; set initial tool 0 active and standby temperatures to 0C; Pressure Advance
M572 D0 S0.35; Miscellaneous
M501 ; Load saved parameters from non-volatile memory
T0 ; Select first tool; BLTouch startup
G4 S2 ; Pause a couple seconds
M280 P64 S160 ; Clear any alarms
M402 ; retract pin just in case; Custom settings are not defined
M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; set voltage thresholds and actions to run on power loss -
@Phaedrux you are the king of duet work great thnks
