Homing advice
@agent0810 said in Homing advice:
Should i swap the fan to an always on port?
No, swap the hotend fan and the part cooling fan plugs.
but if i want -z to go down shouldnt 0 be at the bottom?
No, 0 is when the nozzle is touching the bed and +Z means the bed is going down as the print gets taller. It's a bit different with a bed that moves in Z as opposed to a bed that stays put and the nozzle raises. But think of it as the print gets bigger as the nozzle and bed get further apart. The print starts at 0 and grows.
The extruder is still crashing into the stops right away when i send a print job
So the print head isn't moving around the center area of the bed? But you can jog the print head around the entire bed area without problem?
and i dont have any fillament coming out yet.
Double check your extruder wiring. Which driver are you connected to?
If you remove your filament and then send
M302 P1
to allow cold extrusion you should then be able to use the extrusion dialogue to move the extruder motor back and forth. Does that work? -
swapped the fan plugs and now the front one is on.
so when i do home all, everything goes to where it is supposed to but the z is at 0 at the top, so it cant go lower right? shouldnt it home at 300 something? im having issues moveing the bed.
when i send a print the print head crashes for a bit, then it goes around like its printing but no fillament comes out.
Ran the M302 P1 and nothing happened.
@Phaedrux
when i hit z+ it tries to go up right now, and its already at the top from homing. -
+Z should move the bed down. If that's not the case, we need to change the direction of rotation of the z motor like we did with the X Y.
;drives M569 P2 S1 ; physical drive 2 goes forwards
Change that to S0 and test again that +z moves the bed down.
That could just be it homing again because there is a G28 in the start gcode. If it's already at the endstops it will back off slightly and then home again. Then it will try and do the prime line part, and then start the print. So as long as it ends up moving around the center area of the bed I think that's ok.
Ok we need to see if the extruder motor is actually working. After you send
M302 P1
that allows the extruder motor to move without being heated up. So if you have removed the filament you should be able to test the motor by sending extrude commands from the web interface. -
the extrude and retract buttons are greyed out on the web interface even after the M302 P1 command
How bout if you heat up the hotend to 180?
@Phaedrux got it up to 160 and now i can retract and extrude
@Phaedrux
M120 M83 G1 E10 F300 M121
Warning: Tool 0 was not driven because its heater temperatures were not high enough or it has a heater fault -
@Phaedrux
at 180 seems to be working. i can see it moving -
Alright, so at least we know the extruder is moving and extruding now.
Next you should go through the extruder calibration to set the correct steps per mm.
https://duet3d.dozuki.com/Guide/Ender+3+Pro+and+Duet+Maestro+Guide+Part+4:+Calibration/40#s165
@Phaedrux said in Homing advice:
so retract is pushing out filament and extrude is pulling it back......
In that case we must change the motor direction once again
Change S1 to S0
I was able to print! My temp tower didn’t come out so hot though. What sorta things do I need to look into to fix?
Now that you have things working somewhat, you should go through the following guides to confirm correct operation and then do some calibration steps.
https://duet3d.dozuki.com/Guide/Ender+3+Pro+and+Duet+Maestro+Guide+Part+3:+Commissioning/39
And
Went through them both and it helped a bunch but I feel like there is still some room for improvement. Thoughts?
