Simplify3D send gcode directly to Duet 2 Maestro?
@Thalios Can't argue with that. I bought the software 3 years ago when CURA was a bit of a joke and I still think slic3r requires you to be an expert before you can be a beginner. And nothing but may PrusaSlicer does supports better than S3D. (IMO)
DLC
s3d with curl upload file without a problem (as long as you keep space and utf8 characters away from the file name
yes, s3d is a joke these days
no, not all slicers support printing to network (if by "network" we consider RRF and Octoprint)... for e.g. I moved to IdeaMaker from Simplify3D as IM IMHO works better than PS/Slic3r/Cura attm (especially part with supports), IM still does not support printing to RRF/Octoprint
(it does support printing to network but only to raise3d printers).. but is not a dealbreaker for me...
@arhi So far as I can see, the IdeaMaker slicer looks like a repackaged and jazzed up Simplify3D. All of the same knobs, just in different places. Except IM actually tells you what gcode programmable parameters are where instead of us having to do string scans to figure them out as with S3D.
It does somethings I don't understand yet, but with time I can figure out how to optimize.
Thanks for the tip. I use CURA to do complex supports with the "Tree support" feature, otherwise I use S3D. IM gives me another tool in the toolbox to experiment with since S3D engineers have apparently gone into hiding and are no longer updating the software. Don't get me wrong, S3D is uber powerful and very capable. It is just a bit stale with no updates in well over a year. I am still glad that I have it, and use it all the time.
DLC
@bearer Yeah, but it makes the Duet RepRap firmware throw errors left and right. Still prints, but I like a cleaner interface...
DLC
what errors does it throw?
@dlc60 errors while uploading?
for e.g. in s3d put postprocessing:
path\to\rrf3.bat "[output_filepath]"
and rrf3.bat
@echo off for %%a in (%1) do ( set filepath=%%~dpa set filename=%%~na set extension=%%~xa ) set if=%filepath%%filename%%extension% G:\bin\curl-7.50.3-win64-mingw\bin\curl.exe "http://ender5.local.lan/rr_delete?name=gcodes/%filename%%extension%" G:\bin\curl-7.50.3-win64-mingw\bin\curl.exe --data-binary "@%if%" "http://ender5.local.lan/rr_upload?name=gcodes/%filename%%extension%"
and no errors, everything works as expected
@dlc60 said in Simplify3D send gcode directly to Duet 2 Maestro?:
Yes, very similar. I was told by someone that they started by copying how s3d and then diverged slowly through time .. I like it, the releases do not come out as often as cura/slic3r/ps but it's actively developed. The only thing I don't like is that "preview" don't know about offsets so if your origin is in center of the screen and not left front corner preview does not properly show where your print will be on the bed
Actually a lot more knobs; IMO organized a little bit better. but yes
S3D engineers have ...
you mean s3d engineer. according to glasdoor "review" by ppl that used to be working for s3d there's only one working on the code - the owner.
I used it a lot 'cause I knew it best, but these days I can't remember last time I started it to do something with it.
prety smooth, but i would add the hostname as the second parameter maybe?
@arhi said in Simplify3D send gcode directly to Duet 2 Maestro?:for e.g. in s3d put postprocessing:
path\to\rrf3.bat "[output_filepath]" ender5.local.lan
and rrf3.bat
@echo off set printerhost=%2 for %%a in (%1) do ( set filepath=%%~dpa set filename=%%~na set extension=%%~xa ) set if=%filepath%%filename%%extension% G:\bin\curl-7.50.3-win64-mingw\bin\curl.exe "http://%printerhost%/rr_delete?name=gcodes/%filename%%extension%" G:\bin\curl-7.50.3-win64-mingw\bin\curl.exe --data-binary "@%if%" "http://%printerhost%/rr_upload?name=gcodes/%filename%%extension%"
yes, that makes sense with more than one rrf3 printer in da house
are there other printers?! ... you should count yourself lucky there has been a sharp decline in burning people at the stake in recent years
@Phaedrux When started I get a message that says "Response too long, seen console", in the console I get:
File Octopus_full_FastPLA.gcode selected for printing
Error: Bad command: --------------------------2242fc1e338db141
Error: Bad command: Content-Disposition: form-data
Error: Bad command: Content-Type: application/octet-streamand when complete, instead of "Print Complete" I get:
Error: Bad command: --------------------------c6128f590dee1f59--
Finished printing file 0:/gcodes/Octopus_full_v5.5.gcode, print time was 3h 0mDLC
show us the script you used? think that was resolved by --data-binary
Just out of curiosity why is it desired to send gcode directly from a slicer rather than select the gcode file in DWC?
My prints take a hour or more to complete. Having to save the file from the slicer and select it in DWC adds maybe 30 seconds. To my mind that is not worth worrying about.
Like I said, just curious.
given multiple iterations of a part its easy to mess up naming or something; exporting from Fusion/CAD to slicer and straight to printer not only makes the workflow faster it also reduces the possibility to make mistakes?
@bearer said in Simplify3D send gcode directly to Duet 2 Maestro?:
curl -F "file=@[output_filepath]" "maestro/rr_upload?name=gcodes/[output_filename].gcode"
curl "http://maestro/rr_gcode?gcode=M32[output_filename].gcode"
curl "http://maestro/rr_disconnect"I tried -data-binary, it gave me an error and didn't print. How best to use that option?
DLC
@fcwilt I rarely open DWC at all anymore honestly. Upload from the slicer and then adjust from paneldue if needed. DWC if I need to make config changes or something more complicated. The PC or laptop I'm slicing on is rarely near the printer itself.
@Phaedrux said in Simplify3D send gcode directly to Duet 2 Maestro?:
Ah... I did not think about that.
None of my printers (current or past) had local panels - much preferred using the computer dedicated to printing - a central place to monitor all printers. Not to mention being able to check from any computer, tablet or mobile phone in the house.
Thanks for the feedback.
like shown in the linked thread and the batch file arhi posted. posting the exact error you get may help identify whats causing it to not work for you.
@bearer Kind of hard to show. It did absolutely nothing. Nothing at S3D, nothing in the console, no error displayed. So, I guess that was vague of me - it errored out by doing nothing at all.
curl --data-binary "@[output_filepath]" "http://192.168.1.184/rr_upload?name=gcodes/[output_filename].gcode"
curl "http://192.168.1.184/rr_disconnect"BTW, I am on a Windows 10 box and I do have curl available, and the --data-binary is an allowed option.
DLC
May be beneficial to have an official doc on how to upload and start jobs using Curl, and to make the Duet's end point more friendly for such operations if they are not.
