Cura Script to Automatically Probe Only Printed Area
@DK90, if you use panel due and prusaslicer (and maybe cura, didn't try), try to enable Support Remaining Time in the Printer Settings | General, tab. This will include M73 time markers in the gcode that which cause the post processing script to show remaining hours and minutes in the Standby fields of Panel Duet (ignore the '-' prefix).
This time estimation is much more consistent than the ones provided by Duet.
@zapta Thank you for the info. I will try it. That sound good.
@zapta I'm sorry to say that, but it does not work properly yet.
The script givesM557 X-10:32 Y-10:32 P3:3
where it should deliver
M557 X-32:32 Y-32:32 P3:3
for a testcube in the middle of the bed with some mm of skirt
total dimensions +/- 21.xx mm
@tcj what are your probe offsets?
Probe offsets wouldn't matter.
Posting the gcode would be helpful though.
@tcj, try to run the script manually and see what it prints. To do that, run it from command line with the same arguments you have in the slicer and also add the name of the gcode file at the end of the command line.
When I run it I get prints like this
MESHABLE area: 30.0:280.0,30.0:280.0 Opening gcode file: /var/folders/dt/1t1sf6d574d3l023pknh_754000cbj/T/.PrusaSlicer.upload.7e0e-12b6-1a76-0282 Read 83648 lines Parsing state = ParsingState.WAITING_FOR_LAYER1 ;Automesh: begin layer 0 Parsing state = ParsingState.IN_LAYER1 ;Automesh: begin layer 1 Parsing state = ParsingState.LAYER1_DONE First layer print areas: 92:189,131:210 printArea: 92:189,131:210 Will use 4 x 3 mesh points Marker: M557 TBD ; marker for automesh script Inserted: M557 X82:199 Y121:220 P4:3
(if you prefer, post your gcode file and command line parameters and I can test it here)
C:\Users\tcj-a>C:\Users\tcj-a\AppData\Local\Programs\Python\Python38-32\python.exe C:\Users\tcj-a\Documents\scripts\duet3d_automesh.py C:\Users\tcj-a\Desktop\single_wall_box.gcode --meshable=-185:185,-185:185 MESHABLE area: -185.0:185.0,-185.0:185.0 Opening gcode file: C:\Users\tcj-a\Desktop\single_wall_box.gcode Read 7472 lines Parsing state = ParsingState.WAITING_FOR_LAYER1 ; Automesh: begin layer 0 Parsing state = ParsingState.IN_LAYER1 ; Automesh: begin layer 1 Parsing state = ParsingState.LAYER1_DONE First layer print areas: 0:22,12:22 printArea: 0:22,12:22 Will use 3 x 3 mesh points Marker: M557 TBD ; parameters will be set automatically Inserted: M557 X-10:32 Y2:32 P3:3
obviously the script does not handle negative numbers as needed, because the first layer print area is -22:-22, 22:22
@tcj, thanks for the example and for your patient.
I made a fix and am now getting the output below. The problem existed in the original code posted in this thread, parsing only non negative x and y values.
MESHABLE area: -100.0:100.0,-100.0:100.0 Opening gcode file: single_wall_box.gcode Read 7472 lines Parsing state = ParsingState.WAITING_FOR_LAYER1 ; Automesh: begin layer 0 Parsing state = ParsingState.IN_LAYER1 ; Automesh: begin layer 1 Parsing state = ParsingState.LAYER1_DONE First layer print areas: -22:22,-22:22 printArea: -22:22,-22:22 Will use 3 x 3 mesh points Marker: M557 TBD ; parameters will be set automatically Inserted: M557 X-32:32 Y-32:32 P3:3
https://github.com/zapta/misc/blob/master/duet3d_automesh/duet3d_automesh.iml
@zapta thank you
@zapta said in Cura Script to Automatically Probe Only Printed Area:
Does this bring it closer to working for Delta's? Or at least probing a square area of the circular bed?
@Baenwort, what are the special requirements for delta compared to a cartesian?
The current script finds the bounding rectangle of the first layer's print (negative numbers are ok) and generates a M557 command with X and Y ranges and number of probe points.
In case of a delta, the bounding rectangle can have points outside the round print area but I presume the duet will ignore them.
Edit: for delta, if objects are placed in the center, it's possible to compute the radius from (0, 0) and issue a M557 with a R param.
I'm also having an issue when getting the post processing script to run. I am getting this:
Post-processing script C:\Users\Jack\AppData\Local\Programs\Python\Python38-32\python.exe "C:\Program Files\PrusaSlicer-2.2.0+win64-202003211145\PrusaSlicer-2.2.0+win64-202003211145\duet3d_automesh.py" on file C:\Users\Jack\Documents\3D Printing\Stuff\Flex Tube Support.gcode failed. Error code: 1
Any ideas on what I may be doing wrong?
This is my full start gcode script:M82 ;absolute extrusion mode G21 ;metric values G90 ;absolute positioning M82 ; set extruder to absolute mode M107 ;start with the fan off G29 S2; clears existing bed heightmap ; For automesh M557 TBD ; parameters will be set automatically G28; home all G32; motorized gantry plane correction G32; G32; Repeated 3 times to ensure its correct G29 Mesh Bed compensation G1 Z20 F6000 ;move the platform down 15mm G1 F100 E9 ;extrude 9mm of feed stock G92 E0 ;zero the extruded length
@Red-Sand-Robot
Double check the content of the script.
I just tried yesterday and was getting the same error.
The first time I downloaded, I right clicked the link and selected "download link" or some such.
Problem was it downloaded the whole HTML page, not just the python script. (DOH!)
After copying and pasting just the script content it worked fine. -
@Red-Sand-Robot, I would suggest to first run it manually from the command line. It will give you more information on what's going on. (after verifying that the script download is ok per OwenD's suggestion)
@zapta Command line? As in my computer or PrusaSlicer? Sorry, the programming side of things isn't my forte.
@Red-Sand-Robot, it seems that you work on windows. I meant commands types in the DOS window. I don't have here a Windows computer but others here may be able to explain it better.
@zapta Yes, I work on windows. Haven't made the jump to attempt to learn Linux or associated stuff yet though I suppose I should if I ever want to use a RPI for anything useful.
When I ran the script from the command prompt window, I received this output:
C:\Users\Jack>AppData\Local\Programs\Python\Python38-32\python.exe "C:\Users\Jack\Documents\3D Printing\PrusaSlicerScript\duet3d_automesh.py" usage: duet3d_automesh.py [-h] [--meshable MESHABLE] [--margin MARGIN] [--spacing SPACING] [--min_points {2,3,4,5,6,7,8,9,10,11,12,13,14,15,16,17,18,19,20,21,22,23,24,25,26,27,28,29,30,31,32,33,34,35,36,37,38,39,40,41,42,43,44,45,46,47,48,49}] [--max_points {2,3,4,5,6,7,8,9,10,11,12,13,14,15,16,17,18,19,20,21,22,23,24,25,26,27,28,29,30,31,32,33,34,35,36,37,38,39,40,41,42,43,44,45,46,47,48,49}] [--first_layer_start FIRST_LAYER_START] [--first_layer_end FIRST_LAYER_END] file_path duet3d_automesh.py: error: the following arguments are required: file_path
Does that look like it is functioning correctly? I'm guessing that the
file_path
argument is talking about the .gcode file, but if not that would indicate an error with how I'm calling the script from what I understand. -
@zapta Figured out that my main issue was that I never changed the meshable area parameters to match my machine. I guess I just assumed when it says "default" that the script would also parse that stuff from the slicer, but in hindsight the script doesn't function that way, it only looks at the .gcode file after it has been output by the slicer.
Leaving output up as an example of what it looks like the user does not properly define the meshable area in regards to their machine. My machine has -100:100,-100:100 for a meshable area.
C:\Users\Jack>C:\Users\Jack\AppData\Local\Programs\Python\Python38-32\python.exe C:\Users\Jack\Documents\3D-Printing\PrusaSlicerScript\duet3d_automesh.py C:\Users\Jack\Documents\3D-Printing\Stuff\flex_tube_support2.gcode MESHABLE area: 30.0:280.0,30.0:280.0 Opening gcode file: C:\Users\Jack\Documents\3D-Printing\Stuff\flex_tube_support2.gcode Read 33095 lines Parsing state = ParsingState.WAITING_FOR_LAYER1 ; Automesh: begin layer 0 Parsing state = ParsingState.IN_LAYER1 ; Automesh: begin layer 1 Parsing state = ParsingState.LAYER1_DONE First layer print areas: -13:13,-48:48 printArea: -13:13,-48:48 Traceback (most recent call last): File "C:\Users\Jack\Documents\3D-Printing\PrusaSlicerScript\duet3d_automesh.py", line 371, in <module> main() File "C:\Users\Jack\Documents\3D-Printing\PrusaSlicerScript\duet3d_automesh.py", line 218, in main mesh_area.clip_to(MESHABLE_AREA) File "C:\Users\Jack\Documents\3D-Printing\PrusaSlicerScript\duet3d_automesh.py", line 165, in clip_to self.x_span.clip_to(other_rect.x_span) File "C:\Users\Jack\Documents\3D-Printing\PrusaSlicerScript\duet3d_automesh.py", line 126, in clip_to self.__check() File "C:\Users\Jack\Documents\3D-Printing\PrusaSlicerScript\duet3d_automesh.py", line 105, in __check fatal_error(f'Invalid range value: {self}') File "C:\Users\Jack\Documents\3D-Printing\PrusaSlicerScript\duet3d_automesh.py", line 83, in fatal_error raise Exception('Fatal error: ' + message) Exception: Fatal error: Invalid range value: 30.0:23
@Red-Sand-Robot, I think we are almost there
Can you post here your file flex_tube_support2.gcode ? I will try to run it myself and check that error.
Edit: to set your own meshable area, add to the command line the following flag:
--meshable=-100:100,-100:100
@zapta Would
go after the output path specification in PrusaSlicer? I just manually changed the default in the script.parser.add_argument('--meshable', default="-100:100,-100:100", help='Bed meshable area x1:x2,y1:y2')
Here is the .gcode file. I have my 0,0 point in the center of the build plate. I know that you previously added support for negative positional values so I don't think that would be the issue
