Cura Script to Automatically Probe Only Printed Area
@tcj, I made the change. Can you give it another try?
@zapta thank you for the effort, but ist does not work yet
only defining the default meshable area within the script (line 50) bydefault="-185:185,-185:185"
works,
but when adding<path to your python3> <path_to_the_duet3d_automesh.py file> --meshable "-185:185,-185:185"
to the Post-processing script, it fails
@tcj, try this syntax for the flags (notice the '=')
--meshable=-30:250,-3:280
Thank you
@zapta said in Cura Script to Automatically Probe Only Printed Area:
Hello, i have the following error when i am trying to ad the postprocess
can some one help me please?Thanks
Post-processing script C:\Users\Dominic\AppData\Local\Programs\Python\Python36-32\python.exe C:\Program Files\Prusa3D\PrusaSlicer\duet3d_automesh.py file on file D:\2_Projekte\3D Druck\2_Modelle\28_R2D2_Did3D\R2D2_Did3D_SW_FullPack_h\STL_Final\zumdruckenbereit\Cube_PLA_Center foot_0.2mm_PET_2h24m.gcode failed. Error code: 2 ```~~~~
@DK90 the space in "Program Files" leads to this error
change it toC:\Users\Dominic\AppData\Local\Programs\Python\Python36-32\python.exe "C:\Program Files\Prusa3D\PrusaSlicer\duet3d_automesh.py"
notice the "
@tcj said in Cura Script to Automatically Probe Only Printed Area:
Oh thank you now ot works
but wehn i start the print, there is now mesh leveling ....
where is my error?Start G-Code
M83 ; extruder relative mode M140 S[first_layer_bed_temperature] ; set bed temp M190 S[first_layer_bed_temperature] ; wait for bed temp ; For automesh M557 TBD ; parameters will be set automatically G28 ;home ;G29 S1 P"heightmap.csv"; Hoehenkarte Laden M109 S[first_layer_temperature] ; wait for extruder temp ;G29 S1 P"heightmap.csv"; Hoehenkarte Laden ; Reinigungs Fahrt G1 X-3.0 Y-10 F1500.0 ; go outside print area G92 E0.0 G1 Z0 G1 E8 ; Purge Bubble G1 X60.0 E9.0 F1000.0 ; intro line G1 X100.0 E12.5 F1000.0 ; intro line G92 E0.0
G-Code layer change setting
; Automesh: begin layer [layer_num]
@DK90 said in Cura Script to Automatically Probe Only Printed Area:
and it never will without G29
this is a part of my start sequence
M140 S[first_layer_bed_temperature] M104 S[first_layer_temperature] M116; wait for temperatures to be reached ; For automesh M557 TBD ; parameters will be set automatically G28 ; home G29 ; mesh
oh yes that sounds good....that was my mistake...:D Thank you
@DK90, if you use panel due and prusaslicer (and maybe cura, didn't try), try to enable Support Remaining Time in the Printer Settings | General, tab. This will include M73 time markers in the gcode that which cause the post processing script to show remaining hours and minutes in the Standby fields of Panel Duet (ignore the '-' prefix).
This time estimation is much more consistent than the ones provided by Duet.
@zapta Thank you for the info. I will try it. That sound good.
@zapta I'm sorry to say that, but it does not work properly yet.
The script givesM557 X-10:32 Y-10:32 P3:3
where it should deliver
M557 X-32:32 Y-32:32 P3:3
for a testcube in the middle of the bed with some mm of skirt
total dimensions +/- 21.xx mm
@tcj what are your probe offsets?
Probe offsets wouldn't matter.
Posting the gcode would be helpful though.
@tcj, try to run the script manually and see what it prints. To do that, run it from command line with the same arguments you have in the slicer and also add the name of the gcode file at the end of the command line.
When I run it I get prints like this
MESHABLE area: 30.0:280.0,30.0:280.0 Opening gcode file: /var/folders/dt/1t1sf6d574d3l023pknh_754000cbj/T/.PrusaSlicer.upload.7e0e-12b6-1a76-0282 Read 83648 lines Parsing state = ParsingState.WAITING_FOR_LAYER1 ;Automesh: begin layer 0 Parsing state = ParsingState.IN_LAYER1 ;Automesh: begin layer 1 Parsing state = ParsingState.LAYER1_DONE First layer print areas: 92:189,131:210 printArea: 92:189,131:210 Will use 4 x 3 mesh points Marker: M557 TBD ; marker for automesh script Inserted: M557 X82:199 Y121:220 P4:3
(if you prefer, post your gcode file and command line parameters and I can test it here)
C:\Users\tcj-a>C:\Users\tcj-a\AppData\Local\Programs\Python\Python38-32\python.exe C:\Users\tcj-a\Documents\scripts\duet3d_automesh.py C:\Users\tcj-a\Desktop\single_wall_box.gcode --meshable=-185:185,-185:185 MESHABLE area: -185.0:185.0,-185.0:185.0 Opening gcode file: C:\Users\tcj-a\Desktop\single_wall_box.gcode Read 7472 lines Parsing state = ParsingState.WAITING_FOR_LAYER1 ; Automesh: begin layer 0 Parsing state = ParsingState.IN_LAYER1 ; Automesh: begin layer 1 Parsing state = ParsingState.LAYER1_DONE First layer print areas: 0:22,12:22 printArea: 0:22,12:22 Will use 3 x 3 mesh points Marker: M557 TBD ; parameters will be set automatically Inserted: M557 X-10:32 Y2:32 P3:3
obviously the script does not handle negative numbers as needed, because the first layer print area is -22:-22, 22:22
@tcj, thanks for the example and for your patient.
I made a fix and am now getting the output below. The problem existed in the original code posted in this thread, parsing only non negative x and y values.
MESHABLE area: -100.0:100.0,-100.0:100.0 Opening gcode file: single_wall_box.gcode Read 7472 lines Parsing state = ParsingState.WAITING_FOR_LAYER1 ; Automesh: begin layer 0 Parsing state = ParsingState.IN_LAYER1 ; Automesh: begin layer 1 Parsing state = ParsingState.LAYER1_DONE First layer print areas: -22:22,-22:22 printArea: -22:22,-22:22 Will use 3 x 3 mesh points Marker: M557 TBD ; parameters will be set automatically Inserted: M557 X-32:32 Y-32:32 P3:3
https://github.com/zapta/misc/blob/master/duet3d_automesh/duet3d_automesh.iml
@zapta thank you
Does this bring it closer to working for Delta's? Or at least probing a square area of the circular bed?
@Baenwort, what are the special requirements for delta compared to a cartesian?
The current script finds the bounding rectangle of the first layer's print (negative numbers are ok) and generates a M557 command with X and Y ranges and number of probe points.
In case of a delta, the bounding rectangle can have points outside the round print area but I presume the duet will ignore them.
Edit: for delta, if objects are placed in the center, it's possible to compute the radius from (0, 0) and issue a M557 with a R param.
