Can "extruder control" control buttons be customized?
I've never intentionally used the default feedrate of 30 mm/s, and 100 mm/s is completely out of the question. If I accidentally click "Extrude" without switching to a slower feedrate, 9 times out of 10 it will chew up the filament beyond recovery before it will extrude anything. I think it would be fantastic if a) the feedrate values on the buttons could be customized, and/or b) the default value on startup could also be customized. Is this possible?
The higher feed rates are for loading and unloading filament. But I rarely use feed rates other than 5 and 100mm/sec. So I agree that most of the available speeds are not useful. What would you like to see instead?
