Blown driver
Spent today refitting my Delta with the Duet Wifi, initially had a problem with the Z axis running in reverse, and after some diagnostics smelt toasted circuitry and now the Z axis doesn't run at all!
Put the original Duet 0.85 back in and its running fine!
could someone please confirm the function of M584, if I run M584 X0 Y1 Z4 E3 would that let me use the spare driver for the Z axis? any other changes that should be made?
I'm sorry to hear of your misfortune. Do you think you shorted the Z motor output? If not, ask for a replacement under warranty.
M584 Z4 will remap the Z axis to the 5th driver. Put it before the M906 command.
Pretty sure there was no opportunity for a short circuit. at the time I thought I had an open circuit/damaged wire etc, so was swapping out the suspect cable with one from my Fisher…. the running backwards was pretty weird though
You didn't swap that cable with the power applied to the board, did you?
