Newbie Seeking Help
Have you extracted the latest DWC into the /www folder?
Can you should the contents of that folder?
Is it correct?
That looks correct.
Your config files should be part of the sys folder and not in their own separate directory.
Can you get an output of M122 and M115? That can be done through YAT
I suggest you check that the files in /www are accessible on the Duet. To do this, send the following command from YAT:
M20 P"/www"
So i have /www separate & /sys separate.
The /config/sys & /config/www directory & files, i was just trying to see if that would solve the problem.
This post is deleted! -
It does remember my SSID, just not my IP address.
Do i need to port forward? i have an Asus GT-AC5300 router.
This is interesting. Does this mean i can't see my /sys files?
If so why?
They should not be sub-directories of /config.
It does imply that.
I would suggest copying everything off the SD card and formatting it with the SD card formatter https://www.sdcard.org/downloads/formatter/
I would also suggest only copying across the /sys and /www folders.
Thankyou. I have deleted those other files. Checked /sys folder again.
But still no DWC !!!!
@turbo3000 I would go back to basics. Please post your config.g just incase.....
M588 "*"M587 with only the S & P parameters, so it gets the address from the router as opposed to being defined, just incase........................
Get DWC working first then progress from that.
So M20 "/www" does not show anything? It did on your post @ 16:40.:confused:
Regards,
Paul -
; Configuration file for Duet WiFi (firmware version 2.00)
; generated by RepRapFirmware Configuration Tool v2.1.8 on Fri May 01 2020 01:28:58 GMT+1000 (Australian Eastern Standard Time); General preferences
M550 P"My Printer" ; set printer nameM667 S1 ; select CoreXY mode
M552 S1 ; enable network;M552 P192.168.1.120
;M554 P192.168.1.255
;M553 P225.255.255.0M586 P0 S1 ; enable HTTP
M586 P1 S0 ; disable FTP
M569 P2 S0 ; physical drive 2 goes backwards
M92 X80.00 Y80.00 Z4000.00 E98.00 ; set steps per mm
M566 X600.00 Y600.00 Z12.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
M203 X18000.00 Y18000.00 Z180.00 E1500.00 ; set maximum speeds (mm/min)
M201 X3000.00 Y3000.00 Z100.00 E10000.00 ; set accelerations (mm/s^2)
M906 X950 Y950 Z950 E950 I30 ; set motor currents (mA) and motor idle factor in per cent
M208 X330 Y330 Z400 S0 ; set axis maxima; Endstops
M574 X1 Y1 Z1 S0 ; set active low and disabled endstops; Z-Probe
M558 P5 H5 F0 T6000 ; set Z probe type to switch and the dive height + speeds
G31 P600 X0 Y0 Z0 ; set Z probe trigger value, offset and trigger height
M557 X15:215 Y15:195 S20 ; define mesh grid; Heaters
M106 P2 S1 I0 F500 H1 T45 ; set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned on; Tools
M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; set voltage thresholds and actions to run on power loss -
Which browser are you using?
Does it work any better if you enter this in the address bar:
http://192.168.1.120/index.html
PS - firmware version 2.0 is rather old!
i got something !!!!
I think the reason may be that the version of Duet Web Control you are using is much later than the version of the main firmware. Firmware 2.0 was designed to work with a much older version of DWC.
I suggest you upgrade to firmware 2.05.1. Download Duet2CombinedFirmware from https://github.com/dc42/RepRapFirmware/releases/tag/2.05.1 and copy it into /sys on the SD card. Put the card back in the Duet, start the Duet, and send M997 from YAT. After 30 seconds, reconnect form YAT and send M115 to see if the update was successful.
@dc42 said in Newbie Seeking Help:
M115
Ok the firmware update worked perfectly, however, this problem remains!
should i force the static IP in the config.h file?
Now is the time to follow this:
https://duet3d.dozuki.com/Guide/1.)+Getting+Connected+to+your+Duet/7
You will already be at about step 6, with what you've done.
